Просмотров в теме 3236   Ответов в теме 7   Подписчиков на тему 1   Добавили в закладки 0
Старый 26.10.2011, 11:47 Автор темы   1
Последняя активность: 21.06.2013 06:09
По умолчанию What wavelength of IR LED should I use for a nightvision illuminator?
I want LED's that can illuminate an area with IR beam that can be seen by a digital camera.
Obella вне форума   Ответить с цитированием Вверх
Старый 26.10.2011, 12:54   2
По умолчанию Re: What wavelength of IR LED should I use for a nightvision illuminator?
you must use the IR-filter (filtering visual light) for your camcorder.
and 3...5 W IR light.
this should be nice night vision camera....
Старый 26.10.2011, 22:39   3
alpg88
Аватар для alpg88
Сказал(а) спасибо: 472
Посмотреть сообщение Сообщение от Obella :
any ir light is visible in digital camera, even remote controls, which are usualy 940nm, but if you actually want to illuminate something, not just make light visible by camera, you need 850nm leds,
there is an easy way to tell them apart, 940nm are not visible by eye even in complete darkness, 850,otoh, emmit slight red glow, barely noticable by eye.
if that little light is not wanted, you could use simple ir pass filter, which is any color negative has at the begining of the roll, or any overexposed shot, after development, that dark portion will block that visible red glow, but not ir light.
now that is as far as the leds go, most cameras otoh have ir block filters, which blocks ir (most of it), so even with good ir leds, you will still not see leds illuminate much, to be effective light source you need sony camera with nightshot option, only in that mode your leds will be usefull as an illumination device.
[Исправлено: alpg88, 26.10.2011 в 22:42]
Старый 26.10.2011, 22:49   4
Virgo_Style
Аватар для Virgo_Style
Последняя активность: Вчера 21:34
Сказал(а) спасибо: 1372
В принципе, IR-фильтр может быть удален, но это не так уж просто.
Старый 26.10.2011, 23:08   5
alpg88
Аватар для alpg88
в большинстве случаев это напыление на саму матрицу, точнее ее стеклишко, я пробывал соскебать, травить, нифига не вышло, только матрици убил.
Старый 26.10.2011, 23:15   6
Virgo_Style
мучал canon'ы и sony - успешно.
Старый 26.10.2011, 23:29   7
alpg88
Аватар для alpg88
не я издевался над security камерами, их у меня много раньше было, на фотики рука бы не поднялась
Старый 26.10.2011, 23:53   8
Virgo_Style
а я специально выцеплял с ebay б/у фотоаппараты баксов за 20 и экспериментировал) Потом, когда немного осмелел - поднялась рука на canon s1, после просмотра видео на youtube. И то у матрицы шлейф порвал, пришлось заказывать новую.
Время генерации страницы 0.09390 секунды с 15 запросами
