Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 4659   Ответов в теме 8   Подписчиков на тему 4   Добавили в закладки 1
Старый 16.02.2016, 18:26 Автор темы   1
Модератор своих разделов
Аватар для HKJ
Thumbs down Test/Review of Charger Bowei HC-103W
This charger is a very cheap LiIon charger that supports a wide variety of LiIon sizes.
The charger is powered from the mains and is universal voltage (100-240 VAC 47/63 Hz). It has a foldable EU plug and it does not fit modern outlets where the holes are below the surface of the outlet.
The charger has one led, that will be red when charging and green at other times.
The charger uses the usual slider constrution and support from 30mm to 69mm, this means it will not support long protected 18650 cells.
The + pole is below the surface of the plastic, this means that it do not support flat top batteries.
The charger can only handle up to 69mm long cells, but only button top cells.
Measurements
The charger do not use a CC/CV algorithm, but constant current and terminates on voltage. The termination is around 4.45 volt, this is way to high and not very safe.
Due to this, I did not do any more tests on the charger, instead I found a screwdriver.
Tear down
I had to remove 3 screws to open it.
There is very few parts in this charger.
The chip is a very small through hole chip, here I have placed a normal sized chip besides it.
There is no safety distance between mains and low volt side on this charger (About 0.5mm, it is supposed to be above 6mm).
Both testing with 2500 volt and 5000 volt between mains and low volt side failed, making the charger unsafe everywhere in the world
Conclusion
There is only one thing to say about this charger: Stay away
It do not fit the mains outlets, it cannot charge in a safe way and it is dangerous to touch when plugged in.
Notes
Here is an explanation on how I did the above charge curves: How do I test a charger
Поблагодарили: 11 раз(а)
Admin (16.02.2016), alexsav (16.02.2016), barena (16.02.2016), Dima.shym (17.02.2016), Garrik (16.02.2016), gukase (17.02.2016), kDn (17.02.2016), Labour (16.02.2016), vorsmann (17.02.2016), Waryag (17.02.2016), Константин Филиппов (16.02.2016)
Старый 17.02.2016, 09:15   2
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Последняя активность: 28.12.2025 16:35
Сказал(а) спасибо: 10203
По умолчанию Re: Test/Review of Charger Bowei HC-103W
Да видно гуано редкостное.
In Fino verytas
Старый 17.02.2016, 13:22   3
Waryag
Аватар для Waryag
Сказал(а) спасибо: 3647
Наоборот, очень даже распостраненное гуано. В бандлы с разнофаерами других и не кладут.
Старый 17.02.2016, 13:24   4
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Это сарказм а не дифирамбы.
Старый 17.02.2016, 14:16   5
ML102_4.35V
Последняя активность: 30.01.2025 23:26
Сказал(а) спасибо: 66
очевидно автору делать нечего раз на такой фуфел тратит время
ML102_4.35V вне форума   Ответить с цитированием Вверх
Старый 17.02.2016, 14:22   6
Dima.shym
Аватар для Dima.shym
Последняя активность: 23.11.2023 21:59
Сказал(а) спасибо: 532
Посмотреть сообщение Сообщение от ML102_4.35V :
Почему же теперь можно людям аргументировано ткнуть носом почему овно это овно
Let the voice of reason shine ©
Dima.shym вне форума   Ответить с цитированием Вверх
Старый 17.02.2016, 14:35   7
NazarSunrise
Turn Day into Night
Аватар для NazarSunrise
Сказал(а) спасибо: 1744
лодочки, без Сержа, скучно..
NazarSunrise вне форума   Ответить с цитированием Вверх
Старый 17.02.2016, 21:51   8
ML102_4.35V
Посмотреть сообщение Сообщение от Dima.shym :
это было ясно и без HKJ. достаточно одного взгляда на плату.
Старый 17.02.2016, 21:59   9
Dima.shym
Да вам с нами на ясно а побробуйте объяснить это людям которые ищут налобники "для близы дешовие" и по 500 р для работы? Или покупаят комплект с подобнимы зарядами итп итд...
vorsmann (18.02.2016)
Время генерации страницы 0.12215 секунды с 15 запросами
