8583
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
LiitoKala Lii-100
![]() LiitoKala has made a couple of analyzing charger, but this model cannot do any analyzing, it is a small universal charger that handles 3 types of LiIon and NiMH, it addition to this it can also work as a power bank. The packaing was very simple, being just a plastic bag. The pack contained the charger and a usb cable. The charger is powered from micro usb and has a full size usb connector for power bank output. ![]() The charger has two red leds to show selected current and four blue leds in a row to select voltage and show battery level. The button has multiple functions: When a battery is put into a powered charger, it can be used to select LiIon voltage (NiMH is selected automatic). When charger is powered a long press (2 seconds) will change between 0.5A and 1A charge current. A fast click when charging will show the selected battery type. When used as a power bank a press on the button will turn the usb power on. The charger uses the typical slider construction, it can handle batteries from 33mm to 70mm. ![]() ![]() ![]() The charger can handle 70mm long batteries, inclusive flat top cells, this means most protected cells. Measurements charger
Charging 4.20 volt LiIon ![]() The charger has a fine CC/CV voltage charge curve, it starts reducing current a bit early, due to voltage constrains, this will give slightly longer charge time. ![]() ![]() No surprise on these two cells. ![]() Reducing the charge current to 0.5A works fine, except the termination current is not reduced (Cells will miss the last few percent of the charge). ![]() With this older cell the current reduction starts very early as expected. ![]() ![]() Good charging on these smaller cell, again the higher termination current means a few percent loss in capacity. Adding a resistor in series with the usb power supply to simulate a long cable or weak supply did not prevent the charger from doing a good job, but it needed some more time. ![]() M1: 32,4°C, M2: 31,4°C, M3: 40,0°C, HS1: 48,8°C ![]() The charger needs some time to start up, this is because it is waiting for voltage selection. ![]() There is no problem with changing current while charging. Charging 4.35 volt LiIon ![]() The 4.35 volt charge works as expected. Charging 3.60 volt LiIon ![]() ![]() Both LiFePO4 cells is charged fine, but the voltage is a bit high (This is not a big problem with LiFePO4). Charging NiMH ![]() This is a fine NiMH charge with voltage termination and no trickle charge. When using voltage termination without a top-off charge the batteries will be slightly below full capacity. ![]() Using 0.5A charge current is also stopped on voltage termination. ![]() On this cell it looks like a voltage termination. ![]() Here it is -dv/dt termination. ![]() My new powerex cell is stopped on -dv/dt. ![]() The AAA cell is stopped on voltage. ![]() Fast detection of a full cell, this is voltage termination. ![]() M1: 35,4°C, M2: 34,2°C, M3: 41,9°C, HS1: 53,5°C ![]() The charger is also slow to start with NiMH, but it is not possible to select any other battery type. ![]() There is no problem with changing current while charging. The charger uses the typical pulsing, where it can measure voltage with current off. Power bank
![]() USB output can deliver 1.3A before it starts dropping, the overload protection first kicks in at 2A. ![]() Running with 0.5A load looks very good. ![]() 1A output also looks very good. ![]() The noise is fairly good at 0.5A load with 20mV rms and 170mVpp ![]() At 1A the noise increases, but is still acceptable with: 38mV rms and 310mVpp Conclusion It looks like this model often is a bit high in charge voltage, but within allowable tolerances. I did not see any problems real with it. This makes it a good charger for all supported batteries and also a good power bank. Notes Here is an explanation on how I did the above charge curves: How do I test a charger Read more about how I test USB power supplies/charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
| Поблагодарили: 17 раз(а) |
Alex TG (10.02.2016), Angry Zeka (11.02.2016), Dima.shym (11.02.2016), drsleep (08.02.2016), LEV-UA (21.03.2016), m72 (09.02.2016), molvinec (14.02.2016), PopovSergej (11.02.2016), Qwertus (08.02.2016), rpdoctor (13.02.2016), Svetogor (12.02.2016), Tamagotchi (08.02.2016), vdavid (08.02.2016), Waryag (10.02.2016), witalen (11.02.2016), yurezz (11.02.2016), Андрей Светлов (08.02.2016)
Регистрация: 07.09.2015 Последняя активность: 21.11.2020 14:11
Сказал(а) спасибо: 95
Поблагодарили: 121 раз(а) в 78 сообщениях
Ну чего, Millerа в помойку?
ну зачем сразу в помойку. 100 в режиме повербанка не удобная, 18650 выпадает из нее при малейшем чихе, да и в этом режиме греется. Носить мл 102 удобней будет.
Я себе МЛ 102 оставил в качестве ПБ и дополнительно ЗУ, а литокалу в качестве ЗУ и дополнительно ПБ.
Регистрация: 25.01.2015 Последняя активность: 16.02.2025 22:50
Сказал(а) спасибо: 268
Регистрация: 09.04.2011 Последняя активность: 30.12.2024 07:20
Сказал(а) спасибо: 1048
Зато габариты совсем другие ml102 по прежнему очень актуальна, была мысль отказаться от нее, но как портативный пауэр банк liitokala крайне неудобна.
ArmyTek Predator G109.1, Ferei 520(334 CREE XP-G2), Lux-RC FL33, Mag-Lite 3D Led, Mini Mag-Lite led pro+, Roche F12 Tir, XENO E03, Б44, Thrunite Ti. |
Регистрация: 04.11.2013 Последняя активность: 07.04.2021 14:31
Сказал(а) спасибо: 118
Поблагодарили: 93 раз(а) в 78 сообщениях
Не забывайте, что литрокала еще и никельметалгидрид кушает, т.ч. эта поуниверсальнее будет нежели Miller. Миллер на подарок пошел.
Бери примeр с лучших, и ты увидишь, как берут примeр с тебя |
Регистрация: 10.04.2014 Последняя активность: 01.02.2025 23:02
Сказал(а) спасибо: 864
да господи, хай кушает, только как часто внезапно нужно зарядить никель?) не все пожертвуют мобильностью в угоду универсальности
Регистрация: 21.01.2014 Последняя активность: 30.01.2025 23:26
Сказал(а) спасибо: 66
миллер меньше раза в два, имеет бОльший ток заряда (1,33А в стоке) отдает не 1,3А а 1,7А. но достойный конкурент у миллера безусловно появился.
ML102_4.35V, Да у меня всё равно оба есть.
А вот китайский английский на заднике с ошибками
Почти не ждун
Регистрация: 15.02.2012 Последняя активность: 06.11.2021 14:48
Сказал(а) спасибо: 217
Поблагодарили: 274 раз(а) в 136 сообщениях
Приехала зарядка, пока изучаю. С защищенными 18650 от AW (на 2600, скольки-то летней давности) не дружит, нужен магнитик на плюсовой контакт. LG HG2 и Sanyo GA (плюс выдается чуть больше, чем у LG) - без проблем.
