Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 5843   Ответов в теме 9   Подписчиков на тему 7   Добавили в закладки 0
Старый 15.01.2016, 19:31 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Charger Skilhunt M1
Skilhunt M1
Skilhunt usual sells flashlights, but has recently started on chargers. This charger is a universal 1 channel charger that can handle multiple chemistries and battery sizes. It does also work as a power bank.
I got the charger in a cardboard box with specifications on it.
The pack contained the charger, a usb cable and a instruction sheet.
The charger is powered from micro usb and has a full size usb connector for power bank output.
The charger has two red leds to show selected current and four blue leds in a row to select voltage and show battery level.
The button has multiple functions:
When a battery is put into a powered charger, it can be used to select LiIon voltage (NiMH is selected automatic).
When charger is powered a long press (2 seconds) will change between 0.5A and 1A charge current.
A fast click when charging will show the selected battery type.
When used as a power bank a press on the button will turn the usb power on.
The charger uses the typical slider construction, it can handle batteries from 33mm to 70mm.
The charger can handle 70mm long batteries, inclusive flat top cells, this means most protected cells.
Measurements charger
  • LiIon and NiMH Batteries will be discharged with 0.1mA when power is off.
  • Charges LiIon batteries with 0.5mA when connected to power.
  • Charges NiMH batteries with 2.2mA when connected to power.
  • When battery is 0 volt the charger will charge with 3mA, this is enough to reset a protection.
  • From 0.25 volt on the battery the charger will reconize it and start charging.
  • Between 0.25 volt and 1.6 volt a battery is assumed to be NiMH.
  • Between 1.6 volt and 2.2 volt the charger will charge with less than 2mA and not allow selection of battery type.
  • Above 2.2 volt a battery is assumed to be LiIon.
  • Charger will not restart if battery voltage drops.
  • Charger will restart charging after power loss, or battery insertion.
Charging 4.20 volt LiIon
The charger has a fine CC/CV voltage charge curve, it starts reducing current a bit early, due to voltage constrains, this will give slightly longer charge time.
No surprise on these two cells.
Reducing the charge current to 0.5A works fine, except the termination current is not reduced (Cells will miss the last few percent of the charge).
With this older cell the current reduction starts very early as expected.
Good charging on these smaller cell, again the higher termination current means a few percent loss in capacity.
Adding a resistor in series with the usb power supply to simulate a long cable or weak supply did not prevent the charger from doing a good job, but it needed some more time.
M1: 35,1°C, M2: 37,7°C, M3: 44,4°C, HS1: 48,3°C
M1: 34,4°C, M2: 35,0°C, M3: 38,6°C, HS1: 50,5°C
The charger needs some time to start up, this is because it is waiting for voltage selection.
There is no problem with changing current while charging.
Charging 4.35 volt LiIon
The 4.35 volt charge works as expected.
Charging 3.60 volt LiIon
Both LiFePO4 cells is charged fine, but the voltage is a bit high (This is not a big problem with LiFePO4).
Charging NiMH
This is a good NiMH charge with -dv/dt termination and no trickle charge.
Using 0.5A charge current the -dv/dt signal is nearly gone, but the charger do termination when the battery is full.
On this cell it looks like a voltage termination.
Here it is again a -dv/dt termination.
This cell is nearly hopeless to termination on, but the charger did stop.
The AAA cell is stopped on voltage.
Fast detection of a full cell, this is voltage termination.
M1: 33,7°C, M2: 40,0°C, M3: 31,9°C, HS1: 49,6°C
The charger is also slow to start with NiMH, but it is not possible to select any other battery type.
There is no problem with changing current while charging. The charger uses the typical pulsing, where it can measure voltage with current off.
Power bank
  • USB output will turn off after 10 seconds with less than 63mA load.
  • When input power is applied, usb output will be off.
  • Mode button can be used to turn usb output on.
  • USB output is coded as usb charger (DCP).
USB output can deliver 1.3A before it starts dropping, the overload protection first kicks in at 2A.
Running with 0.5A load looks very good.
Increasing to 1A do have some problems the last 5 minutes, but generally works fine.
The noise is fairly good at 0.5A load with 21mV rms and 200mVpp
At 1A the noise increases, but is still acceptable with: 40mV rms and 310mVpp
Conclusion
The charger is not perfect, it has a few small issues, but nothing serious with any of the functions.
This makes it a good charger for all supported batteries and also a good power bank.
Notes
The charger was supplied by Skillhunt for a review.
Here is an explanation on how I did the above charge curves: How do I test a charger
Read more about how I test USB power supplies/charger
[Исправлено: HKJ, 16.01.2016 в 15:31]
Поблагодарили: 25 раз(а)
Artemha (16.01.2016), barena (15.01.2016), belsa (16.01.2016), blindnick (15.01.2016), Dima.shym (15.01.2016), ezuxen (30.01.2016), Garrik (15.01.2016), Georgiy (16.01.2016), m72 (19.01.2016), Magvay (15.01.2016), moto-moto (15.01.2016), PopovSergej (16.01.2016), ppi1 (16.01.2016), rpdoctor (16.01.2016), Svetogor (23.01.2016), Tamagotchi (15.01.2016), togico (15.01.2016), Vyacheslav Demeshko (27.01.2016), Waryag (16.01.2016), witalen (15.01.2016), wxp (16.01.2016), yurezz (15.01.2016), Алексей Михайлович (15.01.2016), Андрей Светлов (15.01.2016), _CKAT_ (15.01.2016)
Старый 16.01.2016, 09:02   2
Artemha
Аватар для Artemha
Последняя активность: 10.07.2021 17:32
Сказал(а) спасибо: 29
По умолчанию Re: Test/Review of Charger Skilhunt M1
Skilhunt M1=LiitoKala lii - 100 and similar problems
Artemha вне форума   Ответить с цитированием Вверх
Старый 16.01.2016, 11:50 Автор темы   3
HKJ
Аватар для HKJ
I am working on the Lii-100.
Поблагодарили: 8 раз(а)
AEDe (16.01.2016), Dima.shym (16.01.2016), m72 (19.01.2016), rpdoctor (25.01.2016), Svetogor (23.01.2016), Vyacheslav Demeshko (27.01.2016), Waryag (16.01.2016), Андрей Светлов (16.01.2016)
Старый 20.04.2016, 22:48   4
Незнайка
Последняя активность: 13.02.2018 00:10
Сказал(а) спасибо: 30
Где найти перевод на русский язык,всего, что написано выше на марсианском?
Незнайка вне форума   Ответить с цитированием Вверх
Старый 20.04.2016, 22:51   5
Посмотреть сообщение Сообщение от Незнайка :
В гуглотранслейте
В Цветочном городе
Старый 20.04.2016, 22:55   6
Незнайка
В гуглотранслейте
В Цветочном городе
Вас понял! Жаль, что всё так.... печально)))
Старый 21.04.2016, 16:26   7
barbosik
Аватар для barbosik
Последняя активность: 04.08.2016 10:04
Сказал(а) спасибо: 9
Посмотреть сообщение Сообщение от HKJ :
Sorry, not clear. :-) You mean that lii-100 not so bad? You use it regulary? It's your main charger for LI-ION?
barbosik вне форума   Ответить с цитированием Вверх
Старый 21.04.2016, 17:41   8
VovanV
_
Сказал(а) спасибо: 2401
barbosik, ит воз минт зат хиз нау тестинг лии-100 фо энозэ ревью
Старый 21.04.2016, 17:48   9
barbosik
Аватар для barbosik
Понимаю ваш юмор, но тестер упомянул Литокалу именно в обзоре Скилханта. Сам. Вот я и задал вопрос здесь. Мне так показалось более уместным. А обзор Литокалы от HKJ я видел, разумеется. И меня интересует не юмор в данном случае, а то, пользуется ли такой известный тестер Литокалой как основной зарядкой. То, что он написал по-английски, мне не совсем понятно.
Старый 21.04.2016, 17:58   10
VovanV
_
barbosik, сравните даты непонятного поста и обзора литокалы, про это я вам и написал. Ну а чем он пользуется можно посмотреть по ссылкам в конце обзоров в т.ч. и на аккумуляторы.
Время генерации страницы 0.14992 секунды с 15 запросами
