Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 5623   Ответов в теме 9   Подписчиков на тему 6   Добавили в закладки 0
Старый 29.07.2015, 18:56 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Charger Micro 18650 Battery USB
This is a fairly cheap usb charger with a very simple and robust design. The body of the charger is in aluminum.
I got it from Gearbest (sku:132117301).
The only packing for this charger was a bag (I got it in a DHL envelope).
Power input is a micro usb connector.
The top of the pack is partial transparent and the indicator leds are mounted on the circuit board below.
Blue is no battery or charging finished. Red is charging.
The charger has a long spring, this allows battery sizes from 65mm to above 70mm (Long batteries may be a bit difficult to remove).
With the charger body of aluminium I was a bit worried about this situation, but the aluminium has some surface treatment that makes it nonconductive. Until this is worn off, the charger works fine.
With unprotected cells there will be a risk when the surface treatment is worn off, but not as much with protected cells (The protection will temporary disable the cell).
The charger can handle 70 mm long battery including flat top cells.
Measurements charger
  • When not powered it will discharge a battery with less than 1uA
  • Below 2.9 volt the charger will charge with 100 to 150mA (Higher current at lower voltage).
  • Above 2.9 volt is use regular charge current.
  • When battery is full it will discharge with less than 2uA
  • If battery drops below 4.10 volt the charger will resume charging.
  • Will not restart charging if a cell is reinserted or power cycled.
The charge curve is a nice CC/CV curve with 100mA termination.
With other capacities the time varies.
No problem with the old cell.
This time I added 1ohm, this is a weak usb power supply and a long cable, as can be seen the charger could easily handle it, but it do try to charge with full current.
M1: 38,4°C, M2: 39,4°C, HS1: 41,3°C
The aluminium construction assures that there is only small temperature differences.
M1: 37,3°C, M2: 39,7°C, HS1: 46,0°C
The charge controller (HS1) is the only thing that generates heat.
The charger starts immediately.
Slowly increasing the battery voltage from 0 volt shows no suprise, at low voltage the charger will use a lower current.
Conclusion
This is a nice small and simple charger that works well. Longer batteries can require a bit of finger strength to get out.
I have only one worry with it and that is how long the isolating surface treatment will last (Shorting a high current battery is not a good idea).
Note: Flat top with the plus pole below the isolation will be safe enough.
Notes
The charger was supplied by gearbest for a review.
Here is an explanation on how I did the above charge curves: How do I test a charger
Alex TG (30.07.2015), blindnick (30.07.2015), krax (29.07.2015), m72 (04.08.2015), ne4epur (29.07.2015), Qwertus (29.07.2015), vorsmann (29.07.2015)
Старый 29.07.2015, 19:42   2
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Последняя активность: Вчера 15:39
Сказал(а) спасибо: 10212
По умолчанию Re: Test/Review of Charger Micro 18650 Battery USB
конкурент для ML102 ,хотя нет пауэрбанка нет, а так класная и стильная штука ,еще анодировать.
In Fino verytas
Старый 30.07.2015, 16:33   3
ML102_4.35V
Последняя активность: 30.01.2025 23:26
Сказал(а) спасибо: 66
ML102_4.35V вне форума   Ответить с цитированием Вверх
vorsmann (30.07.2015)
Старый 30.07.2015, 18:44   4
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
да верно. просто хочется функционал мл102
Старый 03.08.2015, 21:29   5
MSS
Аватар для MSS
Сказал(а) спасибо: 529
HKJ, они есть разных версий. С разными контроллерами.
TP4057, ME4057, TF5056
m72 (04.08.2015)
Старый 21.08.2015, 09:56   6
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Анодирование не протошнило бы. Ввиду того что длинные акки входят в нее впритык дабы избегнуть КЗ
Старый 21.08.2015, 11:17   7
Сказал(а) спасибо: 6714
дабы избегнуть КЗ
слой анодирования - отличный диэлектрик
Старый 21.08.2015, 12:23   8
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
При условии что оно есть а там не пойми какой то то ли краской то ли лаком покрыт корпус.
[Исправлено: vorsmann, 21.08.2015 в 12:24]
Старый 21.08.2015, 12:26   9
MSS
Аватар для MSS
там лак
Старый 21.08.2015, 12:52   10
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Вот что ясно. лак тоже хорошо но анодирование было б лучше и скорее долговечнее.
Время генерации страницы 0.12606 секунды с 15 запросами
