Просмотров в теме 3090   Ответов в теме 2   Подписчиков на тему 2   Добавили в закладки 0
Старый 25.02.2015, 21:32 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Eizfan IMR26650 3500mAh (Gold)
Official specifications:
  • Model No.: IMR 26650
  • Rated capacity: 3500mAh
  • Nominal voltage: 3.7V
  • Size: Diameter 26.13, height 65.56mm
  • Weight: 95g
  • Resistance: 23±2 mOhm
  • Temperature range: -20~+60 ºC
  • Monthly Self-discharge rate: < 0.5%
  • Temperature range: Discharge: -20~+60 ºC, Charge: 0~45 ºC
  • Maximum discharging current: 35A
  • Maximum charging current: 6.5A
  • Maximum pulse discharging current: 65A
A high current 26650 battery according to specifications, as can be seen below that is not correct.
When the test was finished and I removed the battery from my test station the plastic wrapper was damaged due to heat, as was my test station.
This means that the curves for the second battery may be a little bit off, due to the damaged test station as was my next few battery test, until I discovered the damage and fixed it and has started a retest of the affected batteries.
Some of the differene at high current is probably due to the damaged test station, but the capacity difference in the 0.2A track cannot be from that.
The curves looks like the battery can deliver 30A, but obvious it gets to hot doing it.
Conclusion
The batteries has some capacity difference, this means that they must not be used in series and I would stay well below 30A when using them.
Notes and links
The batteries was supplied by Efan for review.
Старый 03.03.2015, 13:30   2
ML102_4.35V
Последняя активность: 30.01.2025 23:26
Сказал(а) спасибо: 66
По умолчанию Re: Test/Review of Eizfan IMR26650 3500mAh (Gold)
ML102_4.35V вне форума   Ответить с цитированием Вверх
Старый 03.03.2015, 13:53 Автор темы   3
HKJ
Аватар для HKJ
Посмотреть сообщение Сообщение от ML102_4.35V :
MNKE inside?
I do not know it, the cell is unmarked.
Время генерации страницы 0.10558 секунды с 15 запросами
