Просмотров в теме 7298   Ответов в теме 14   Подписчиков на тему 4   Добавили в закладки 0
Старый 27.03.2014, 22:35 Автор темы   1
Администратор
Аватар для Admin
Сказал(а) спасибо: 4331
Поблагодарили: 10697 раз(а) в 2546 сообщениях
По умолчанию Новинка! Armytek Tornado
Выпуск нового фонаря Tornado от Armytek планируется к осени 2014 года.
Ориентировочная стоимость порядка € 540.00
Информация доступная на данный момент...
Directly pre-order price is only approximate and put up for sale will probably be lower than it is now referred to
The term reintroduction July to September
Mega powerful handheld LED flashlight ArmyTek Tornado with an incredible 10,800 lumens output
With such power to impress everyone in which any area. This is the light that must have really any enthusiast of small LED lights or anyone who needs enormous power for professional or business purposes.
Parameters:
Power: 10,800 lumens LED
Using LED: 4 x Cree MT-G2 LED - with a lifetime of 50 000 h
Light range: lists the brooding yards - with lighting the large area
It has four separate lights without parabolic curves.
Density of light: lux
Power supply: 8 x 18650 - not included.
Indication voltage battery pack (battery)
Rechargeable: Yes, from the network but also with 110/220V 12V car
Working voltage: V
The inner shell, battery contains a special balancer for the use of all types of batteries
Endurance: hour minutes
It has several modes:
Endurance pays 8 x 18650 Li-ion 3400mAh battery
Water resistant by:
Body made ​​of high quality aluminum alloy finished with hard anodized.
Ultra-clear tempered glass lens with impact resistant
The most effective electronics špaciálne protected against shock!
Dimensions and weight:
Length only: mm
Reflector diameter: mm
Body Diameter: mm
Weight: grams!
Weight with battery: g
Package includes: 1 x ArmyTek Tornado, case, spare O-ring
Represent the actual performance LED light ArmyTek Tornado from ArmyTek!
It has incredible electronics that all makes it home to overcome a few points.
Stamina 8 x 18650 3400mAh AmpMax - hour? minutes
This lamp is not any competing brand!
Definitely a top-notch product that actually in each direction powerhouses competing lamps!
Waterproof to 10 meters - suitable for diving in plitčinách.
This model belongs to the category Throw (very powerful thrower light)
Lamp was designed to reach a very large light accompanied with an output of 10,800 lumens!
It is extremely shock resistant and water as each lamp by brand ArmyTek.
Light range is better than the competition!
10 year warranty.
Armytek shop (29.03.2014), shruzzzz (27.03.2014), surf839 (28.03.2014), Svetogor (29.03.2014), Tamagotchi (27.03.2014), Светлячок (28.03.2014)
Старый 27.03.2014, 22:38   2
Tamagotchi
Аватар для Tamagotchi
Сказал(а) спасибо: 3333
По умолчанию Re: Новинка! Armytek Tornado
Старый 27.03.2014, 22:56   3
Weight: grams!
вес всё ещё в граммах... 999 грам - это ещё не килограм
Монстр!
да ломали тут уже такой, на 6х18650...
Старый 27.03.2014, 23:40   4
oleg235
Сказал(а) спасибо: 25
Эээ... И что?
ТМ26 с апнутой батареей и заменёнными диодами и оптикой, но без экрана.
Старый 28.03.2014, 00:05   5
И что?
будет там 10000+. в общем то больше и ничего. отметились после
дивной задницы из дуплета MT-G2
100 Вт +\- жалкие проценты - и в руках инструмент для клеймения неверных. если рука долго выдержит
Старый 28.03.2014, 00:47   6
Roman1993
Велотурист
Аватар для Roman1993
Последняя активность: 22.12.2025 13:07
Сказал(а) спасибо: 6
Поблагодарили: 44 раз(а) в 38 сообщениях
Значит этот фонарь теперь не самый мощный в мире (как заявляют на сайте), но зато может быть всё ещё самый дорогой.
Roman1993 вне форума   Ответить с цитированием Вверх
Старый 28.03.2014, 00:53   7
Последняя активность: 06.01.2026 21:39
Посмотреть сообщение Сообщение от Roman1993 :
Они просто за пределы сайта никогда не выходили, потому что самые мощные фонари эти
Старый 28.03.2014, 02:17   8
virus_59
Аватар для virus_59
Последняя активность: 03.01.2017 23:40
Сказал(а) спасибо: 239
Поблагодарили: 263 раз(а) в 170 сообщениях
Прикольно, у них есть фонарь на 100500 люмен
И всего за 2878 евро
Фонари: ZebraLight SC600w Mk II XM-L2, ZebraLight H602w XM-L2, Sunwayman M11R Sirius Titanium. Велосвет: Nitecore TM26 3800, Philips SafeRide 80, B&M Ixon IQ Premium. Зарядки: LiitoKala lii-100 (2шт). Аккумуляторы: Samsung ICR18650-32A 4,35/3200, Panasonic Eneloop BK-3MCCE/2000, Panasonic Eneloop Pro BK-3HCCE/2550. Powerbank: Xiaomi 10000 mAh. Мультиметры: UNI-T UT81B, UNI-T UT33B.
virus_59 вне форума   Ответить с цитированием Вверх
Старый 28.03.2014, 04:59   9
Roman1993
Велотурист
Но как их можно сравнивать, они же не на литие вроде.
100500 - символично, теперь надо сделать на овер9000 люмен)
Старый 28.03.2014, 12:33   10
SuperFonarik.ru
Аватар для SuperFonarik.ru
Последняя активность: 04.10.2024 12:03
Сказал(а) спасибо: 243
Нам пока не попадались светодиодники, которые бы переплюнули Polarion PH/PF50 по качеству света и дальнобойности.
SuperFonarik.ru вне форума   Ответить с цитированием Вверх
Старый 28.03.2014, 12:42   11
halfcat
Аватар для halfcat
Последняя активность: 09.01.2015 22:10
http://www.turboled.sk/Army... продают что ли уже?)
roche f12, ТМ26
halfcat вне форума   Ответить с цитированием Вверх
Старый 29.03.2014, 02:00   12
Armytek shop
Последняя активность: 08.04.2014 23:20
Интересно было бы их сравнить.
Armytek shop вне форума   Ответить с цитированием Вверх
Старый 29.03.2014, 13:53   13
Посмотреть сообщение Сообщение от SuperFonarik.ru :
галогеновый милионник на 100 Вт лампочке - 3 500 000 кандел. и лупит дальше, и свет приятнее. ЧСХ, стоит 1000 рублёв...
Старый 29.03.2014, 14:25   14
Romanko
Сказал(а) спасибо: 274
На станковый пулемёт его ставить что ли?
Старый 08.04.2014, 21:41   15
SuperFonarik.ru
Не-а, вообще ни в какое сравнение не идет. Как-то даже неинтересно сравнивать 100Вт галогенку и 50Вт HID. В галогенке и люмен меньше, и фокусировка преужасная. И светит ближе, и, по сути, вообще фигово светит, ну и обычно весит как связка поларионов
В лучшем случае тягаются короткодуговые лампы, но они обычно в прожекторах фокусируются либо широким пятном вширь, либо узким лазером вдаль, либо что-то невнятное посередине, а такого шикарного света, как у Polarion - не встречалось.
Но замечание, впрочем, было про светодиодники
Время генерации страницы 0.10577 секунды с 15 запросами
