18180 16 9 0 |
11.03.2014, 17:44 | 1 |
Регистрация: 13.08.2013 Последняя активность: 13.03.2016 07:28 Адрес: Пермь
Сказал(а) спасибо: 764
Поблагодарили: 557 раз(а) в 210 сообщениях
Zebralight H600F MkII
Герой очередного обзора – Zebralight H600F MkII. Отдельно хочу поблагодарить Siegtek.ru, который быстро отреагировал и отправил выбранный налобный фонарь.
Для начала характеристики самого производителя: LED: Cree XM-L2 Cool White (Norminal CCT 6300K) Light Output (runtimes) High: H1 1038 Lm (PID, approx 2 hr) or H2 630 Lm (PID, approx 2.5 hrs) / 335 Lm (3.9 hrs) / 152 Lm (11 hrs) Medium: M1 65 Lm (30 hrs) or M2 30 Lm (66 hrs) / 11 Lm (172 hrs) Low: L1 3.5 Lm (16 days) or L2 0.4 Lm (2.5 months) / 0.06 Lm (4.6 months) / 0.01 Lm (5.5 months) Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1 Light output are ANSI out the front (OTF) values. Runtimes tested (and parasitic drain estimated) using ZL631 batteries. Runtimes of the two PID controlled levels (1038Lm and 630Lm) vary greatly with ambient temperature and air circulation. Operating Voltage Range: 2.7V - 4.2V Battery: One 18650 size (up to 69mm) 3.6/3.7V li-ion rechargeable. Batteries are not included in the package. Parasitic Drain: Negligible (much less than the self discharging of a battery) Beam Type Floody beam from frosted lens, with 90 degree beam spread Dimensions Head Diameter: 0.95 inch (24.2 mm) Length: 3.85 inch (97.8 mm) Weight 1.4 oz (39 gram) Features PID thermal regulated outputs (1020Lm and 620Lm) Battery capacity indicator (LED flashes 1-4 times, 4 short clicks to start) Automatic stepping down from High to Medium, and from Medium to Low when battery capacity is low Builtin over-discharging protection (2.7V cutoff) Durable electronic soft-touch switch Smart user interface provides fast and easy access to all brightness levels and beacon-strobes. Precision machined unibody casing from premium grade aluminum bar stocks Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing Durable natural hard anodized finish (Type III Class I) Sealed and potted LED driver circuitry Battery reverse polarity protection Tempered optical grade glass Waterproof to IPX7 (2 meters, 30 minutes) Итак, как обычно, жесткая небольшая картонная коробка с наклейкой на боку, на которой есть название фонаря и адрес. Внутри у нас лежат: 1. Сам фонарь 2. Резинка для налобного крепления. Широкая, весьма тугая – видно, что сделана из качественного материала. 3. 2 запасные уплотнительные резинки в пакетике. 4. Ну и инструкция на фонарь. Вполне все ясно, хоть и на английском языке. Сам фонарь без аккумулятора очень легкий (всего 39г, даже меньше, чем сам аккумулятор). Цвет приятный, слегка матовый. В руке лежит замечательно. Анодирование отличное, медная проволока не царапает корпус, остается только след, который легко стирается. Правда, под лупой нашел пару крайне мелких вмятин (невооруженным глазом и не заметно совсем), которые, видимо, с завода, потому что анодирование не задето (наверное, огрехи производства корпусов до анодирования). Но в любом случае, это уже придирки перфекциониста))) Качество корпуса и анодирования я бы оценил на максимальный балл. Размеры тоже радуют – совсем немногим больше аккумулятора 18650. Крышка имеет насечку, благодаря чему удобно ее раскручивать/закручивать. Фонарь умеет стоять на задней крышке, да и на голове тоже легко стоит. Тело фонаря ребристое, с двумя выделяющимися проточками, предназначенными для наголовного крепления. Клипсы в стандартной комплектации нет, можно только если купить дополнительно. У меня в наличии была только от h52 клипса, но 52-я имеет диаметр 19мм, а 600-я около 20мм, поэтому я не стал пробовать ее. Впрочем, раньше пробовал надеть клипсу от Armytek Wizard на H600w MKII – анодирование не было повреждено. Идем дальше – голова фонаря выделяется немного большими размерами, что понятно, так как в ней располагается не только сам светодиод с рефлектором, но и драйвер с кнопкой. Да уж, ZebraLight на славу постаралась сделать все максимально компактно. Голова имеет ребра для лучшего охлаждения, всего их 8 штук. С торца расположена утопленная черного цвета кнопка. То что она утоплена – это хорошо, так как риск случайного нажатия значительно снижается. Ход кнопки достаточно мягкий – в первых фонарях этой версии многие жаловались на тугую кнопку, видимо, производители это учли и исправили. В действительности, у меня был несколько ранее H600w MKII – кнопка была заметно туже той, которая в герое сегодняшнего обзора H600F MKII. Нажимать кнопку, когда фонарь находится на голове, немного неудобно по началу, но быстро привыкаешь и даже двойные-тройные клики делать очень просто. Взглянем на диод и рефлектор… эх, ничего и не видно, стекло то матовое. Остается только стальным безелем любоваться ))) Перейдем теперь к крышке. Раскручивается легко (насечка этому очень способствует), но в то же время с усилием. На внутренней части крышки располагается золотистая пружинка, не очень жесткая, но упругая. Резьба хорошо смазана, нареканий нет. Присутствует уплотнительное колечко. Внутри фонаря также есть пружинка для плюсового контакта аккумулятора. Аккумуляторы свободно помещаются в корпус фонаря, с платой защиты тоже, правда закручивается крышка намного туже. Да и вообще в самом фонаре есть защита от переразряда, поэтому лично для себя вообще не вижу смысла использовать защищенные аккумуляторы конкретно в этом фонаре. На этом с внешним осмотром все. Качественный корпус, с красивым «легким» дизайном, что еще сказать. Перейдем к управлению – в инструкции много букв, но все достаточно просто и легко – три основным уровня, в каждом из которых 2 подуровня. Причем один из этих подуровней (точней второй) можно дополнительно запрограммировать (выбрать из нескольких вариантов). Плюс дополнительно есть режим со стробами. Описывать здесь полностью управление, думаю не к чему. В русском варианте инструкция на H600F MKII есть здесь. Очень порадовало наличие индикации уровня заряда аккумулятора. Четыре быстрых клика и фонарь начнет моргать (1,2,3 или 4 раза, видимо от 0 до 25, от 25 до 50, от 50 до 75 и от 75 до 100). Измерил токи потребления с аккумулятора во всех режимах. Аккумулятор был LG 18650D1, который до 4.35 заряжается. Сначала измерил на одном (напряжение 4,25В), затем на другом (напряжение 3,97В). Результаты следующие: 1038 Lm – 3.30 А / 3.75 А 630 Lm – 1.40 А / 1.56 А 335 Lm – 0.49 А / 0.53 А 152 Lm – 0.21 А / 0.23 А 65 Lm – 108 mA / 115 mA 30 Lm – 50.3 mA / 54.2 mA 11 Lm – 19.9 mA / 21.0 mA 3.5 Lm – 7.28 mA / 7.83 mA 0.4 Lm – 1.79 mA / 1.85 mA 0.06 Lm – 0.91 mA / 0.93 mA 0.01 Lm – 0.74 mA / 0.75 mA Средние и минимальные группы – очень удачны – можно легко подобрать нужные режимы. А вот максимальная группа мне не так понравилась. Визуально 1038Lm и 630Lm очень близки, а также 152Lm и 335Lm. Но это все в контексте моих нужд по свету и рантайму. А так очень даже все продумано и сделано для большинства потребностей. Кстати, в инструкции написано о PID-контроле режимов 1038 и 630. Включил при комнатной температуре на максимум – температура головы фонаря быстро поднялась в район 50 градусов и на протяжении примерно получаса держалась ниже 55 (около 52-53), так что термоконтроль хорошо работает. Кстати, в комнате было около 22-23 градусов. Попытался искусственно повысить температуру. Прогретый до 52 градусов фонарь выключал и тут же включал в турбо режиме. Он быстро сбавлял яркость. Максимум что удалось – до 56 поднять. Так что, думаю, даже в жаркую летнюю ночь фонарь не перегрееется. Стабилизация работает отлично – включил фонарь и он светит с одной яркостью, пока аккумулятор не просядет до определенной границы, после чего происходит степдаун, т.е. переход на уровень ниже (имеется в виду уровни H, M, L). Стоит еще отметить, что в режимах 1038Lm и 630Lm есть термоконтроль, который снижает яркость, если происходит перегрев фонаря. Перейдем теперь к свету - температура светодиода заявлена 6300К. До того, как первый раз включил H600F MKII, ожидал увидеть белый с оттенками синего/голубого. Однако, увидел немного другое – просто белый свет, практически без оттенков, как, например, у H52w – розовая засветка и зеленый хотспот. Заливка равномерная, плавно снижаемая яркость к краям. Светит практически на 180 градусов, хотя заявлено 90 градусов, но матовое стекло делает свое дело и свет попадает везде. Возникает много вопросов по поводу того, что фонарь на лбу отсвечивает на нос. Лично мне нет, да и на очки тоже не отсвечивает. Попробовал подобрать максимальный угол наклона фонаря, при котором он еще не отражается от носа. Но по факту такой большой угол и не нужен вовсе. Вот пара картинок по форме светового пятна. Ну и напоследок проверим заявленную водонепроницаемость уровня IPX-7 – положил работающий фонарик в стакан воды, пролежал он там около получаса на максимальном режиме – после этого был тут же тщательно проверен, протечек не обнаружил. Вывод: IPX-7 подтвержден. Хотя, думается, что ZebraLight просто перестраховывается, не указывая на IPX-8. Вот немного фотографий: В итоге, ZebraLight H600F MKII – хороший функциональный налобник с многочисленными режимами, с рассеянным белым светом без ярко выраженных оттенков, компактный, легкий, правда клипсы не хватает. [Исправлено: ip_86, 13.03.2014 в 09:49] |
Поблагодарили: 14 раз(а) |
66magic99 (12.03.2014), blackwolf762 (12.03.2014), Garrik (11.03.2014), Linx (11.03.2014), Tankist_20 (11.03.2014), Tim_ON (11.03.2014), ujeen (16.11.2014), virus_59 (17.03.2014), Yurik (11.03.2014), Борян (14.03.2014), Славный (14.11.2014), Штанга (15.11.2014), Юрий2014 (17.11.2017), _rider (11.03.2014)
11.03.2014, 19:17 | 3 |
Регистрация: 23.08.2012 Последняя активность: Сегодня 16:33 Адрес: State of Decay
Записей в дневнике: 3 Сказал(а) спасибо: 6423
Поблагодарили: 4311 раз(а) в 2387 сообщениях
Re: Zebralight H600F MkII
ura75gan, собственно
тож такую хАчЮ, но NW only |
11.03.2014, 21:35 | 4 |
ip_86, Вы его завтра-послезавтра проверьте на наличие конденсата. Помню у кого-то было такое, сразу после теста всё хорошо, а через день вода в рефлекторе.
ZL (W) H32 custom, H602 custom, H602, H600, H600f, SC60tir, SC62tripl, SC63; SC600, SC600Mk3; Relight;Olight; Tank; EagleTac; Spark; Sun-n; Niteye + кучка |
11.03.2014, 21:57 | 5 | |
фонарных дел любитель
Регистрация: 27.05.2012 Последняя активность: Сегодня 07:46 Адрес: орехово-зуево
Записей в дневнике: 4 Сказал(а) спасибо: 2686
Поблагодарили: 2439 раз(а) в 1366 сообщениях
фонапарк |
12.03.2014, 11:56 | 6 | ||
А вообще, производителем не заявлялась полная водонепроницаемость. IPX-7 допускает: Цитата:
14.03.2014, 11:37 | 7 |
Регистрация: 20.12.2013 Последняя активность: 06.04.2017 09:44 Адрес: МО Лыткарино
Сказал(а) спасибо: 18
Спасибо за отчет! Хороший агрегат!
Особенно в сравнении с UF-H3 |
ip_86 (14.03.2014)
23.09.2014, 17:11 | 8 |
Регистрация: 12.05.2014 Последняя активность: 24.04.2024 23:28 Адрес: Долгопрудный-Лобня-Москва
Записей в дневнике: 1 Сказал(а) спасибо: 790
Поблагодарили: 752 раз(а) в 539 сообщениях
Фонарь нормально переносит LG которые 4,35В заряжаются? Драйвер не сильно портится при этом?
фонари Zebralight |
23.09.2014, 17:53 | 9 | |
Единственное, что на некоторых зебрах на максимуме наблюдается небольшое мерцание на первых нескольких секундах работы (при полностью заряженном аккумуляторе). |
Поблагодарили: 3 раз(а) |
14.11.2014, 18:09 | 10 |
Регистрация: 17.02.2012 Последняя активность: Вчера 08:33 Адрес: Караганда
Сказал(а) спасибо: 967
Поблагодарили: 248 раз(а) в 155 сообщениях
Скажите, а в нем именно стекло? Не пластик? Оттенок не искажает?
Loki_mihal (06.03.2017)
14.11.2014, 19:39 | 11 |
Любитель налобников
Регистрация: 24.11.2013 Последняя активность: 15.04.2024 18:11 Адрес: Украина. Мариуполь
Сказал(а) спасибо: 167
Поблагодарили: 265 раз(а) в 165 сообщениях
Конечно стекло! Матированное изнутри стекло.
А вот с просветлением или без - не знаю.
Фонари: Armytek Wizard Pro Warm, Nitecore HC50, Nitecore NU10, Skilhunt H02, Convoy S2+, Small Sun ZY-R837. Зарядки: Skilhunt I2, MCO beam S-168, Miller ML102 v9/V7.1. Soshine E4S |
14.11.2014, 20:38 | 12 |
KyTy30B, имел ввиду оттенок, матовостью не искажает?
14.11.2014, 21:47 | 13 |
Регистрация: 22.12.2012 Последняя активность: 22.08.2016 16:54 Адрес: Москва
Сказал(а) спасибо: 102
Поблагодарили: 58 раз(а) в 49 сообщениях
Не KyTy30B, но отвечу:- матовость "смешивает" чуть более теплый оттенок хотспота и немного прохдадный (относительно хотспота) оттенок засветки. Т.е. по сути искажает исходный свет. Но общая, исходная температура не изменяется при этом. Как-то так...
[Исправлено: shery077, 14.11.2014 в 21:49] |
Штанга (15.11.2014)
15.11.2014, 14:57 | 14 | |
Регистрация: 04.01.2014 Последняя активность: 20.09.2023 18:33 Адрес: Израиль
Сказал(а) спасибо: 378
Поблагодарили: 201 раз(а) в 127 сообщениях
купил ленту от skilhunt, она не в пример мягче и приятнее в контакте, но китайцы ж без косяков никак не могут. нет чтобы сделать её на пару сантиметров длиннее, а то на моём 59-ом размере туговато сидит. придётся зебру на фениксовскую повязку пересадить. фениксом то я пореже пользуюсь |
19.05.2015, 23:31 | 15 |
Регистрация: 19.05.2015 Последняя активность: Сегодня 09:56 Адрес: Орёл
Сказал(а) спасибо: 1773
Поблагодарили: 1150 раз(а) в 538 сообщениях
Здравствуйте!
Недавно приобрёл ZebraLight H600F, до этого в качестве налобного фонаря пытался использовать Fenix PD 35 (отличная вещь) на найткоровской резинке, но через некоторое время начинала ныть голова в месте соприкосновения с фонарем,общий вес которого с аккумулятором 138 грамм. Всем сомневающимся хочу сказать, что фонарь замечательный: очень компактный, легкий, логично управляемый, программируемый. Для подсветки окружающей местности перед собой - самое то. Фонарь покупал в российском интернет-магазине ZebraLight, вместе с доставкой обошёлся ровно в 5000 рублей, что на фоне других продавцов совсем неплохо. |
10.11.2016, 10:46 | 16 |
Регистрация: 10.11.2016 Последняя активность: 22.03.2017 17:44
народ подскажите почему нет в продаже H600F Mk3 на сайте zebralight и вообще в Москве?
06.03.2017, 19:45 | 17 |
Регистрация: 03.01.2017 Последняя активность: Сегодня 09:10 Адрес: Саяногорск, Республика Хакасия
Сказал(а) спасибо: 38
Поблагодарили: 19 раз(а) в 13 сообщениях
Скажите, в чем отличие МК3 то МК2, кроме внешнего вида? Заказал МК 2, говорят, что он надежнее?
