Просмотров в теме 4273   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 24.04.2012, 13:59 Автор темы   1
Аватар для candle lamp
Последняя активность: 09.06.2017 16:17
Сказал(а) спасибо: 4
Поблагодарили: 403 раз(а) в 87 сообщениях
Wink2 Simplified Spark SL6-740NW (XM-L T5)
Spark has released SL6S which is simplified version of SL6.
SL6S keeps all the main features of SL6, but removed the tailcap switch and inner tube.
I received a SL6S-740NW and it comes with a holster, two extra o-rings, a diffuser and a user manual.
The shape of SL6S-740NW is quite same as SL6-740NW except the tailcap.
Left is SL6 and Right SL6S.
The inner tube and tailcap switch are removed. The very early SL6 version has an issue with a fat
protected 18650 cells and tailcap switch doesn't work.
There is no such issue on my SL6S.
SL6S(right) has no outer spring due to removal of the inner tube & tailcap switch.
SL6(left) has a switch, but SL6S has no one. It can tailstand perfectly.
SL6(Left) looks nicer than SL6S to me. It seems SL6S has a tailcap switch though.
SL6 has only one small hole for lanyard and SL6S has four.
The clip of SL6S(right) looks better than SL6, and has clean surface.
I have tested with several batteries on super mode.
- Surefire 2xCR123A
- Unprotected flat-top LG 18650(2600, 2800, 3000mAh)
- Unprotected flat-top Panasonic 18650(3100mAh)
- Protected button-top Jil Lite 18650(2600mAh)
- Protected buttton-top NLTEC 18650(2600mAh)
All batteries work fine on super mode except Jil Lite 18650 cell.
It can't access to the super mode due to the very high discharge ratio. I think its PCM works.
From left to right, Nailbender P60 drop-in module 4500K NW, 4000K NW, SL6S-740NW, YEZL Z1X CW.
All is powered by one 18650 cell.
The main specs. for each light :
- Nailbender P60 4500K NW : Max. current 2.8A, OP reflector
- Nailbender P60 4000K NW : Max. current 3.0A, OP reflector
- Spark SL6S-740NW : Max. current 3.0A, OP reflector
- YEZL Z1X CW : Max. current 2.5A, SMO reflector
The following beamshots condition :
- Distance : about 7m
- Brightness : Max.
- ISO100, F2.8, 1/4sec
- Battery : LG 18650(2600mAh)
- ISO100, F2.8, 1/8sec
YEZL Z1X CW
Spark SL6S-740NW
YEZL Z1X CW
Spark SL6S-740NW
candle lamp вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.08602 секунды с 15 запросами
