3710
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Keeppower 18500 1500mAh (Black)
![]() Official specifications:
![]() This battery is a 18500 battery, i.e. about 15 mm shorter than a 18650. The smaller size means considerable less capacity and less maximum current. This battery is only 1500mAh and does hold the capacity, even at a 5A load (Probably because the cell used is 1600mAh). The internal resistance is higher than a 18650, but that is expected from a smaller battery. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() For a battery with 3A rating the trip current is a bit high. The actual resistance in the operating range is slightly lower than my measurement shows. My measurement is calculated at the high load current and there the red trace drops extra fast. ![]() Conclusion There is not much to say about this battery, with a Sanyo cell inside, I will call it a very good battery. Notes and links Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them. The batteries was supplied by Keeppower for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ [Исправлено: HKJ, 01.04.2012 в 20:06] |
