Просмотров в теме 3199   Ответов в теме 1   Подписчиков на тему 0   Добавили в закладки 0
Старый 26.03.2012, 19:17 Автор темы   1
Аватар для turboBB
Последняя активность: 23.08.2013 16:00
Поблагодарили: 104 раз(а) в 43 сообщениях
По умолчанию Sunwayman M11R Mr. Elfin (XM-L U2 | 1 x R/CR123) Review
I might be compact (and some may dare call me cute) but to you, it's still Mr. Elfin SIR!!
MFG SPECS
MSRP: $78USD
● CREE XM_L U2 LED, with a lifetime of up to 50,000 hours;
● Output and Runtime of three constant output modes (uses one CR123A)
- 180 Lumens (1.5hrs) - 60 Lumens (10hrs) - 4 Lumens (70hrs)
- Turbo Mode: 230 Lumens (uses one 16340 battery, do not run the light continuously at turbo mode for more than 10 minutes)
- Two Hidden Modes: Strobe, SOS
● Digital Sensor Magnetic Control system, slightly twist the rotator ring to select from different modes
● Constant current circuit, constant output
● Effective range of 130 meters
● Uses one single CR123A (RCR123A/16340) battery
● Working voltage: 0.9~4.2V
● High quality OP reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 75mm (length) x 23.2mm (head diameter)
● Weight: 45.5g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tail stand capable- can be used as a candle
● Accessories: Clip, Holster, O-ring, lanyard
SIZE
L to R: AW IMR | Zebralight SC30 | Sunwayman M11R Mr. Elfin | SureFire E1E | Sunwayman V10R Ti
MEASURED PERFORMANCE - 288lms | ~1600lux (1m)
@74F (23.3C) on 1xAW16340
Was taken shortly after 30 seconds but was 288 @ 31 seconds
L: Quick calibration w/G10v2 in M | M: Mr. Elfin SIR!! shortly after turn-on | R: Lux @ 1m
QUICK WALL SHOT (not color corrected)
L: M11R | V10R Ti (XP-G)
WE ARE FAMILY, I'VE GOT MY BROTHERS, SISTERS & ME!
Mr. Elfin's head/body is completely interchangeable with his V brethrens.
turboBB вне форума   Ответить с цитированием Вверх
Admin (26.03.2012), Alex4479666 (26.03.2012), MOHAPX (26.03.2012), WallE (26.03.2012)
Старый 26.03.2012, 19:17 Автор темы   2
turboBB
Аватар для turboBB
По умолчанию Re: Sunwayman M11R Mr. Elfin (XM-L U2 | 1 x R/CR123) Review
Literally just got this in and sorry, not full blown review yet. However, I'll add to it as time allows but likely won't get to it soon since I have a few other reviews queued up.
However, I think I've captured the more important details that inquiring minds would like to know but in the meanwhile, any questions just ask away.
My initial conclusion after a few minutes: You must address this one as Mr. Elfin SIR!!
Cheers,
Tim
Время генерации страницы 0.08870 секунды с 15 запросами
