Просмотров в теме 3398   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 11.03.2012, 18:40 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of EnerPower+ 18650 2200mAh (Blue)
Official specifications:
  • Lithium-ion battery of the 3rd Enerpower generation
  • Nominal voltage: 3.7V
  • Capacity: 2200mAh
  • Minimum capacity: 2200mAh
  • Standard charging current: 500mAh for 5.5 hours to 4.2 V
  • Maximum charge current 2000mA
  • Protection circuit: 7 A
  • Deep discharge protection: at 3V
  • Button top
  • Nickel base plate for added durability
  • Diameter: 18mm Length: 69mm
  • Weight: 45g
  • CE certification
  • Production in Germany!
This battery has a low internal impedance and has nearly the same capacity at all tested loads.
Because the voltage is lower at higher loads, the energy will be lower, even when the capacity is the same.
Conclusion
This battery is a lower capacity battery, but works well at higher discharge currents.
All in all a very good battery.
Notes and links
The batteries was supplied by ENERDan for review.
Admin (11.03.2012)
Время генерации страницы 0.08283 секунды с 15 запросами
