Просмотров в теме 4356   Ответов в теме 1   Подписчиков на тему 1   Добавили в закладки 0
Старый 12.02.2012, 23:11 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of EagleTac 18650 3100mAh (Black)
Official specifications:
  • 3100mAh IC PROTECTED Rechargeable Cell (takes the place of 2-R123 cells in some applications) (4.2V hot off charger)
  • Uses newest Panasonic 3100mAh LiNiCoAlO2 cells, made in Japan
  • This is the shortest ultra high capacity 18650 ever made WITH protrude top button!
  • Measures only 68mm in height (+/-0.1mm) and 18.5mm in width
  • IC protected for a) over-charge, b) over-discharge, c) short circuit, d) current overflow of 5A+
  • True protrude top design, fits all flashlights
  • High discharge rate 4A-5A
  • Nominal voltage: 3.7V, charge up to 4.2V, use CC/CV charger to charge
  • Reinforced steel plate bottom, highly efficient protective PCB design
  • Packaged in individual box and anti-static bag
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
The two batteries does not have the same current limit, on trips at 6 ampere the other at 6.5 ampere.
The current limit is placed low enough to prevent overloading the cell, this is very good for people that want maximum battery lifetime without any risk of accidents, but not for people that want to play with high current direct drive configurations.
Conclusion
This battery uses a good cell, this secures many things:
  • The batteries does match in capacity, i.e. they can be used in series.
  • The battery is very safe.
  • The battery has the specified capacity (But only when tested at the specified conditions).
All in all a very good battery.
Notes and links
Старый 13.02.2012, 04:39   2
Scratch
Опаньки
Аватар для Scratch
Последняя активность: 05.10.2025 22:38
Сказал(а) спасибо: 110
Поблагодарили: 271 раз(а) в 108 сообщениях
По умолчанию Re: Test/Review of EagleTac 18650 3100mAh (Black)
good bye AW )
Scratch вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.18458 секунды с 15 запросами
