Просмотров в теме 12446   Ответов в теме 17   Подписчиков на тему 3   Добавили в закладки 0
Старый 12.02.2012, 23:07 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of EagleTac 16340 750mAh (Black)
Official specifications:
  • 750mAh IC PROTECTED Rechargeable Cell (4.2V hot off charger)
  • Measures only 34.4mm in height (+/-0.1mm) and 16.7mm in width
  • IC protected for a) over-charge, b) over-discharge, c) short circuit, d) current overflow of 3A+
  • True protrude top design, fits all flashlights
  • High discharge rate 3A+
  • Nominal voltage: 3.7V, charge up to 4.2V, use CC/CV charger to charge
  • Reinforced steel plate bottom, highly efficient protective PCB design
  • Packaged in individual box and anti-static bag
These 16340 batteries are short for protected batteries, i.e. they are very close to 34 mm long (Same size as CR123 batteries). This battery can only replace a CR123 battery in equipment designed for LiIon, because it has higher voltage than a CR123 battery.
The capacity is slightly below rated value, but that is very common for 16340 batteries. The batteries do not track perfectly.
The protection is at 5.6 ampere, this is a bit high in my opinion.
Conclusion
This battery has a size very close to CR123 batteries and a construction with a metal plate at the bottom, both are good details. But that the battery uses a cell from an unspecified supplier is a minus and I would also have liked the discharge curves being closer.
I will call this battery acceptable.
Notes and links
sakost (18.01.2018), vorsmann (29.09.2017)
Старый 18.12.2014, 17:36   2
Dmitriyrus
HID маньяк
Аватар для Dmitriyrus
Сказал(а) спасибо: 787
По умолчанию Re: Test/Review of EagleTac 16340 750mAh (Black)
Получил 13 штук, этих аккумов с nkon.nl.
Такое впечатление, в термоусадку упаковывают в ручную, при этом делает это однорукий китаец.
Один экземпляр оказался особенно выдающимся.
ID:	124644 Нажмите на изображение для увеличения
ID:	124645 Нажмите на изображение для увеличения
ID:	124646 Нажмите на изображение для увеличения
[Исправлено: Dmitriyrus, 18.12.2014 в 17:58]
Старый 18.12.2014, 17:51   3
Dmitriyrus
HID маньяк
Остальные были получше и нарушение геометрии было в основном со стороны минусового контакта. Как в этой фотографии. Где то меньше, где то так же.
Я, честно говоря был немого шокирован... Вроде и фирма производитель нормальная. И магазин хороший...
Так и не определился в суждении. Или это подделка, продаваемая в уважаемом магазине. Или это просто продукция такого говёного качества от уважаемого производителя.
В плане электрических характеристик, пока претензий нет.
Но опять же, неизвестно, что там внутри и сколько циклов на близких к максимальным, или хотя бы в половину от них (а заявлено 3A), выдержат эти аккумуляторы.
Через мои руки прошло больше 20 аккумов AW 16340.
Ни до одного из них, в плане геометрии и качества насадки термоусадки, я не могу докапаться даже при желании. Собственно, как и в плане электрических характеристик.
Сейчас закупил парк аккумов Efest. Ситуация такая же. Всё идеально.
Иглтаки покупать больше не буду. Как уже писал - не знаю чей это косяк, поэтому просто предпочту воздержаться от дальнейших покупок именно этого товара, где бы то ни было.
Ибо, по одёжке, как говориться, встречают. И если ТАК снаружи, то неизвестно, как вообще внутри.
Культура производства, однако.
[Исправлено: Dmitriyrus, 18.12.2014 в 18:29]
sakost (18.01.2018)
Старый 18.12.2014, 18:25   4
Dali
читатель
Аватар для Dali
Сказал(а) спасибо: 2774
Жуть!
Имею сабж оттуда же (нкон) более годичной давности покупки. Такого безобразия нет.
Старый 19.12.2014, 14:23   5
SuperFonarik.ru
Аватар для SuperFonarik.ru
Последняя активность: 04.10.2024 12:03
Сказал(а) спасибо: 243
Подтверждаем: У нас E/T 16340 всегда шли без такой косорукости, это явно или брак, или подделка. Ну и возникает масса вопросов к дилеру, который такое умудрился выпустить в розничную продажу.
Производителя спросили, родные ли аккумуляторы.
SuperFonarik.ru вне форума   Ответить с цитированием Вверх
Dmitriyrus (19.12.2014)
Старый 22.12.2014, 09:55   6
SuperFonarik.ru
Ответ от EagleTac:
It looks like the 16340 in the picture is fake.
Но еще не уверены до конца, проверяют.
Старый 22.12.2014, 10:00   7
Последняя активность: Сегодня 06:38
Сказал(а) спасибо: 17678
Поблагодарили: 39920 раз(а) в 14768 сообщениях
Покупал когда-то парочку на nkon, все было хорошо.
Но "по электрическим характеристикам" игловские аккумы довольно средненькие, главный их плюс - крохотные размеры.
Dmitriyrus, не затруднит сделать групповую фоточку всех аккумов?
SuperFonarik.ru (22.12.2014)
Старый 22.12.2014, 14:16   8
Dmitriyrus
HID маньяк
Затруднит, потому что вот.
Когда ситуация образовалась.... Долго думал, в какую же тему писать...
В итоге решил, что речь в первую очередь всё таки об аккумуляторах, поэтому запилил свой пост сюда.
А в тему отзывов о nkon.nl, кинул только ссылку на свой пост здесь.
Собственно и далее, следуя политике отделения мух от котлет разделения информации, касающейся непосредственно аккумуляторов и информации о реакции магазина на конфликтную ситуацию, решил распределять инфу по темам.
Так как на данный момент, вашими комментами, весы всё больше склоняются к тому, что это косяк магазина (продажа поддельной продукции EagleTac), то считаю логичным, что бы уважаемый Суперфонарик, после получения официального ответа от EagleTac (когда они закончат проверку), опубликовал его в теме отзывов о магазине nkon.nl
P.S. fnksb, аккумы покупались для недавно закупленных зебр H32.
Как мы знаем, зебры на 16340, к размерам аккума, а именно к его длине, относятся очень критично.
Хотя, честно говоря, в H32 я обнаружил, что места под аккум там больше, чем в H31, где оно впритык ваааще.
[Исправлено: Dmitriyrus, 22.12.2014 в 14:18]
Старый 22.12.2014, 14:21   9
SuperFonarik.ru
Dmitriyrus, мы предполагаем, что в данный момент EagleTac как раз обсуждают с NKON, что это и откуда это взялось.
В подделку мы сами не верим, т.к. пока таких откровенных подделок не попадалось, да и смысла нет их подделывать, проще выпустить аккумулятор под своим брендом.
Старый 22.12.2014, 14:28   10
Dmitriyrus
HID маньяк
ОК
[Исправлено: Dmitriyrus, 22.12.2014 в 15:12]
Старый 22.12.2014, 15:19   11
как вы понимаете, отдельная прелесть ситуации в том, что nkon формально не продаёт продукцию иглтак в Россию. Или аккумов это не касается?
Старый 22.12.2014, 15:29   12
Dmitriyrus
HID маньяк
Я не совсем понимаю, если честно.
Старый 22.12.2014, 15:35   13
SuperFonarik.ru
Это не прелесть, это пикантность
Старый 22.12.2014, 19:56   14
Если совсем коротко, то недавно уважаемый Superfonarik уговорил уважаемый Eagletac запретить уважаемому nkon продавать продукцию Иглтак в Россию
Linx (10.03.2015)
Старый 22.12.2014, 20:03   15
Dmitriyrus
HID маньяк
Фига се
А я по незнанию своему, думал, что Вы, Суперфонарик, просто от чистого сердца хотите разобраться в ситуации.
Знал бы, что такой расклад....
[Исправлено: Dmitriyrus, 22.12.2014 в 20:11]
Старый 22.12.2014, 20:05   16
SuperFonarik.ru
Ну если еще короче, то уважаемый EagleTac намекнул NKONу о недопустимости нарушения лицензионного соглашения, NKON намеку внял и в общем-то ничего с тех пор не изменилось
Старый 22.12.2014, 20:06   17
SuperFonarik.ru, ну или так
Старый 25.12.2014, 18:52   18
SuperFonarik.ru
Официальный ответ EagleTac - аккумуляторы, судя по всему, настоящие. Сейчас разбираются, как оно вообще попало в продажу.
Dmitriyrus (25.12.2014), fnksb (25.12.2014)
Время генерации страницы 0.13976 секунды с 16 запросами
