Просмотров в теме 4288   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 14.08.2010, 07:23 Автор темы   1
Последняя активность: 26.08.2011 11:52
По умолчанию ITP H01
iTP Light H01 Cree 7909-XP-E Q5 3-Mode 80-Lumen LED Headlamp Operation
Battery installation:
- Remove the light tail.
- Insert the battery with the negative end toward the tail.
Operation:
- Insert the battery and tighten the tail
- Tighten the head clockwise to turn on the headlamp.
- When the light is on, loosening (counter-clockwise) and tightening (clockwise) the head within 1 second will change the mode between low, medium and high level.
- After choosing a specific mode, the headlamp will memorize that level and will default to the level when turned on.
- Loosen the head to turn off the headlamp.
iTP Light H01 Cree 7909-XP-E Q5 3-Mode 80-Lumen LED Headlamp Specifications
Brand: iTP Light
Mode: H01
LED Type: Cree XP-E Q5
Function: Low-Med-High
Finish: HA Type Ⅲ
Reflector: Orange Peel
Lens:Anti-shattering ultra clear lens, anti-scratching and anti-slip
Water and Dust Resistant to IP68
Switch: Head Twisty Switch
Mil-spec: MIL-STD-810F
Battery: 1 x AAA, 1 x Rechargeable NiMh AAA, or 1 x 10440 (due to the small body size, 10440 batteries are not recommended since it may cause the light becoming hot very quickly). Batteries are not included.
Three output levels: Low 1.5 lumens (50 hours) -> Medium 18 lumens (4 hours) ->-High 80 lumens (55 minutes)
Standard Accessories: 1 x Clip, 2 x O-rings, 1 x Manual
Size: L 52.5mm (2.07'') x D 16.2mm (0.64'') x W 36.2mm (1.43'') ,
Net Weight: 22.8g (Excluding Battery and belt),
Weight (including the packing): 50.8g
perfectful вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.06346 секунды с 15 запросами
