7035
Регистрация: 05.02.2012 Последняя активность: 05.02.2012 18:30
Hello everyone,
I have received two new models from ArmyTek, the Viking S and Viking X. This particular review will be on the Viking S XP-G R5. ArmyTek has not yet at time of writing given the specifications or availability on the Viking S. So, on with the review, ![]() ArmyTek used DHL with tracking to send the Vikings, I assume that is how they will handle orders as well, either by sending an email or a PM to you. Which, BTW, they usually respond very quickly, less than a day at most. So obviously, for us people, the wait is not a happy time. Checking the tracking number everyday and seeing it coming closer yet still so far was excruciating. Well, almost. DHL delivered it to my family while I was at school, in just 3 days from China . Wow.Needless to say, I shredded the DHL bag and took these boxes out (the ArmyTek Predator box is there to show a comparison between packaging, and yes, the packaging is the same for both Vikings):![]() A strange thing, look at the day and time stamp on the boxes, the Viking X has his stamped the 30 of December of 2011, and the Viking S has his January 10, 2012, the same day ArmyTek shipped the lights out. Maybe for others, they can know when their light was made or shipped, or maybe both. ![]() ![]() So here we open the box, the light in its holster and comfy Styrofoam holders. ![]() ![]() Accessories are just as ArmyTek described them, except the rubber button is actually a rubber ring. Holster is nice and feels durable, rings and o-rings inside a bag, and the lanyard in another. So here we have the light itself: ![]() Its rather simplistic looks somehow is pleasing to my eyes. These are some pictures from the business end: ![]() The Viking S has a quite deep smooth reflector obviously meant for throw and very thick walls! This makes the Viking obviously feel heavier in the hand compared to lights such as the Predator. Here it is alongside its partner, the Viking X: ![]() The Viking S has a deeper reflector and hence, a longer head, so as this picture shows, the Viking X has a higher spill angle: ![]() These are pictures showing the construction design of the light, which BTW, both Vikings have the same body, ring, and tailcaps (note: none of the Vikings can tailstand alone.) ![]() These next few pictures are going to be comparing the Viking S to the ArmyTek Predator: ![]() For those of you wondering about interchangeable parts between the ArmyTek models, well, here it is: ![]() Here are pictures of the Viking S for comparing size against other flashlights: ![]() Whitewall Beamshots IMG]http://www.candlepowerforums.com/vb/images/smilies/evilgrin07.gif[/IMG]![]() (All beamshots have equal amount of initial and reduced exposure, white balance is same as well, and the Viking S is always on the left) ArmyTek Viking S Vs. ArmyTek Predator Smooth ArmyTek Viking S Vs. ArmyTek Viking X ArmyTek Viking S Vs. ArmyTek Predator Orange Peel ArmyTek Viking S Vs. Fenix TK20 ArmyTek Viking S Vs. Cree Budget Light (2X18650-5X Q5 emitters - 1.5 Amps Current) ArmyTek Viking S Vs. Klarus XT20 (Not really a fair comparison, Klarus uses 2X18650) ArmyTek Viking S Vs. Fenix TK41 (Not fair either, but its for comparison purposes) ![]() Spill Comparison-This is to allow us to compare the relative spill angles from other lights: ArmyTek Viking S is always on the left: Vs. Viking X (Viking S is on the right in this image: ![]() Vs. ArmyTek Predator SMO Vs. ArmyTek Predator OP Vs. Fenix TK20 Vs. Cree budget light (5X Q5 emitters, 2X18650) Vs. Klarus XT20 Vs. Fenix TK41 (the hosting site seems to have a bit of an issue with this image, sorry guys) Next is a waterproof test, now, I know lights don’t like water, but these guys were quite eager to get in J ![]() The Viking S cannonballs inside the water, perhaps the name ArmyTek Pioneer S may suit him just fine haha. Soon, the other ArmyTek’s join in on the fun: Not before long, the others jumped in so fast I didn’t know what just happened… So, after their little pool party in my sink, I wanted to show you guys the ceiling bounce of these lights. Note: All shots have equal exposure except a few that I will mention. First picture is the regular bathroom lights: 4X60 watt incans. Next is only the ArmyTek Viking X lighting up the bathroom. This next one is the ArmyTek Viking S, Then, both of them (had to hold them in my hand, they cannot tailstand alone) This is all four ArmyTek’s turned on. Reduced exposure: All of them turned on: Reduced exposure: Final kitchen shots with reduced exposure-Viking S on max mode: Low mode: Middle Mode and reduced exposures: High mode and reduced exposures: Now to Wrap it all up: So, overall, the Viking S is a very good light in my book But I think that the Viking has a bit of a wider hotspot than the Predator’s (which is still a very focused beam), and a wider corona . So the Viking is a bit more suited to covering a slightly wider area than the Predator, while still maintaining a strong throw.UI ArmyTek has not implemented a control ring in this model, contrary to what several were hoping for back on CPFMP. But, the UI they put in the Viking is one that is very “tactical”. Head tightened (Line 1) will always come on max mode (1.5 amps), no other mode is on line 1. For when you absoulutely need max quickly, a quick tighten of the head will give you just that. Line 2, which is Head loosened, will give you the other output levels. Low, middle and high seemed to be well spaced out, and Max was just brighter by 100 lumens or so I believe. Construction ArmyTek really gave a much needed improvement over the Predator’s body, a cigar grip ring. This gives it a much easier hold when holding it “cigar style”. It also prevents your hand from slipping, which BTW, although there is no knurling, the unique ArmyTek finish is grippier than other finishes, so no worries. The flat bezel was also a big change for me from the Predator’s aggressive strike bezel. But seeing it is so thick as well as the whole flashlight, I think I let it grow on me. It gives it a “tank” feel, as if it is a solid, well-built, and reliable light to carry with you. Most aesthetic details from the Predator are gone, the tailcap is completely smooth, and the only head details are grooves going around the whole head. The LED is well centered and seems to have a centering piece. 18650 do not rattle in the light The light cannot tailstand unfortunately, though I have seen some pictures where the cigar ring is somehow used to allow it to tailstand .Beam The beam from the XP-G R5 is well balanced, and is definitely throw-oriented. If anyone has any requests, questions, or anything, feel free to post it or if preferable, PM me. Cheers, Firelord777 CPF link |
eaero (18.02.2012)
