Просмотров в теме 5134   Ответов в теме 4   Подписчиков на тему 3   Добавили в закладки 0
Старый 28.01.2012, 19:44 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Review of Xtar Wk21 with measurements and outdoor beamshots
Xtar Wk21
Xtar has made flashlights, batteries and chargers for some time. In this review I am looking at a small high power light, that uses a LiIon battery to drive a XM-L led.
The light is turned on/off and brightness changed by loosing and tighten the head. The light is made of aluminum with anodized finish.
The light comes in a a small box with a foam insert.
Included in the package is the light, a LiIon battery, a chain with claw and split ring, a manual and a warranty card.
The light uses a smooth reflector with a XM-L led. With this small reflector and a XM-L led the beam will be mostly flood.
The head has some groves for grip, but is not equipped with any cooling fins.
The light has up to five modes, that can be selected with loosing/tightening the head. It will remember the last selected mode.
A look at the head from the backside shows that there is a metal plate on the plus connection, but also show 4 small solder pads. Bridging any of these pads will disable one mode from the user interface, the only mode that cannot be disabled is high. How to do this is well explained in the manual. On the last picture I have disabled SOS mode and there is also some solder on strobe, but it is not bridged.
The battery tube has triangular threads with anodized.
Inside the battery tube is the usual spring.
On the tube is a removable clip.
The tailcap has a magnet below the round plate. The magnet is strong enough to attach the light to a fridge. The plate can be unscrewed and the magnet removed, for people that do not want a magnet.
Here is all the part the light can be disassembled in without tools.
The light is small and bright and has a lot of flexibility both for modes and for physical configuration with/without magnet and clip, but it is not designed for long runtime. I like this light, it is a nice EDC.
Technical specification and measurements
The light is rated for use with one 16340 LiIon battery.
Measured size and weight:
Length: 71 mm
Diameter: 22.4 mm to 25.6 mm
Weight: 70 gram with Xtar 16340
The light uses a Cree XM-L T6 led.
In the above table I have collected all modes. The current is measured at 3.7 volt. All the estimated runtimes are with a 600mAh LiIon battery. The estimated lumen is scale from the specified maximum of 500 lumens.
The first voltage sweep is done in high mode. The light uses a linear current regulator, i.e. the current draw does not change with voltage.
Also note that the current draw has fallen to around 0 at 2.6 volt, this does give some protection for LiIon batteries.
Reducing the brightness to medium with 40% pwm reduces the power consumption to about 40% of high.
At low there is not much regulation, it is just low brightness.
The light does not last long at high, it is better at medium, but this is definitly not the light to use for long runtime and lot of light at the same time (Larger batteries are needed for that).
The strobe is 10 Hz and has a 50% duty cycle. It runs at full brightness.
SOS is not really a SOS, it only sends SO, the last S is missing.
The light uses pwm at 500 Hz to control brightness, here is medium.
Pwm at low.
Comparison to other Flashlights
Xtar Wk21, Xtar Wk25B, Xtar Wk26:
Sunwayman V10R Ti, Fenix LD15, Fenix E15:
For the full comparison to other lights with graphs and beamshots see here
Notes
The light was supplied by Xtar for review.
havoc (28.03.2013), nurlanchm (29.10.2012)
Старый 28.01.2012, 19:47   2
svetofreak
Последняя активность: 23.03.2015 19:21
По умолчанию Re: Review of Xtar Wk21 with measurements and outdoor beamshots
почем сей девайс
svetofreak вне форума   Ответить с цитированием Вверх
Старый 28.01.2012, 19:51 Автор темы   3
HKJ
Аватар для HKJ
Посмотреть сообщение Сообщение от svetofreak :
почем сей девайс
I found it for $33 at hkequipment.
Старый 29.10.2012, 00:10   4
Zlоdey
Последняя активность: 25.02.2022 22:45
Сказал(а) спасибо: 40
Получил на днях XTAR WK21 T6, дать хороший обзор не могу, так как для этого нужно прикупить еще фотоаппарат и хоть немного разбираться в терминологии.
Скажу что не очень понравилось: достаточно тяжелый, как для такого маленького фонаря, имеет очень жесткую пружину, это сразу ощущаешь еще до того как успел наживить голову на тушку и сделать пару витков . На мой пока еще неокрепший ум в флэшоголизме рефлектор здесь не очень удачный. Это проявляется в том что, от центральной точки засветки и до края самого луча, я насчитал 5ть перехоров яркости. Простыми словами луч как бы не сплошной. Пробовал регулировать глубину посадки кристалла в рефлекторе, вроде бы самих переходов стало поменьше, но сам диаметр центрального луча после этого увеличился примерно в два раза.
Zlоdey вне форума   Ответить с цитированием Вверх
Старый 10.11.2012, 12:27   5
Zlоdey
Кто скажет, где можно купить рефлектор? Дал своему знакомому поюзать фонарик, а он спалил рефлектор. При разборке, замацал пальцами рефлектор и решил его протереть ваткой с медицинским спиртом, вот и спалил
Время генерации страницы 0.12647 секунды с 15 запросами
