3846
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
EnerPower+ 18650 3100mAh (Blue)
![]() Official specifications:
![]() This battery has a different plus pole than most other high capacity LiIon batteries, it uses the small diameter button. The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity. ![]() Shipping was in a plastic box within a sealed plastic bag. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Conclusion This battery uses a good cell, this secures many things:
The use of a small button top makes this battery interesting for some application, but the price for this top is that the battery is one of the longer 3100 mAh batteries. All in all a very good battery. Note: ENERDan has improved the welding process, this might reduce the internal resistance. Notes and links The batteries was supplied by ENERDan for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
