3509
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
EnerPower+ 18650 2900mAh (Blue)
![]() Official specifications:
![]() This battery has a different plus pole than most other high capacity LiIon batteries, it uses the small diameter button. The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity. ![]() Shipping was in a plastic box within a sealed plastic bag. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The two batteries had 1A difference in trip current and also a difference in internal impedance, one battery was 0.12 ohm and the other was 0.10 ohm. ![]() My charger (Power supply) did have a slight problem with the low impedance of one of the batteries, as can be seen where it changes from CC to CV. This has no impact on the actual test. Conclusion This battery uses a good cell, this secures many things:
The use of a small button top makes this battery interesting for some application, but the price for this top is that the battery is one of the longer 2900 mAh batteries. All in all a (very) good battery (I do not like the difference between the batteries thus the brackets around (very)). Note: ENERDan has improved the welding process, this will probably secure that all batteries has the same low internal resistance. Notes and links The batteries was supplied by ENERDan for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Admin (11.01.2012)
