5425
Регистрация: 25.06.2010 Последняя активность: 23.08.2013 16:00
Поблагодарили: 104 раз(а) в 43 сообщениях
Hey guys, I recently upgraded my camera and have been away for a short while working on this massive indoors shots session. The new camera has a wider angle lens thus capturing more of the beam profile. It also has the ability to tweak the custom-white balacing (Blue, Magenta, Green, Amber) thus allowing me to attempt to reproduce as faithful an interpretation of what my eyes see as possible. While this can be done PP (post-processing), I don't always remember exactly what each beam's temperature was so being able to do this on the fly was a huge boon to the process. However, with that said, I'm still learning the in's/out's of the camera and may have over-compensated on the M axis a little for some pics so something to note if a particular shot has too much M hue. Another thing to keep in mind is that the door is an off-white, creamy color and not pure white.
As for the modes, where possible, I've captured all modes except those where it was so low as to not provide a meaningful exposure. For obvious reasons, I only did Max and Min for variable lights (but again only where the Min showed anything in the shot). There may be shots that look pitch black but upon enlarging it, you can make out the beam even if just barely (at least on my monitor) so I've also embedded links to full size 1280 x 960 pics in case you want to do detailed comparos of the hotspot (this alone took a few hours and I'm pretty sure I caught all of them but do let me know if any links are broken). I will continue to add to this thread as I get more shots. Cheers, Tim ===== ![]() Lights in yellow are new as of 1/2/12. Lights sorted in alphabetical order by mfg. All shots were taken on a Panny FZ150 @ ISO-100, custom WB, f/2.8 and fixed shutter speeds of 1/8, 1/40 & 1/80. Distance to door is 5m (16.4ft) away. 4Sevens QMini 123 Ti High ![]() Med ![]() Low ![]() Dereelight DBS V2 w/Manafont XM-L 3S Drop-In SM High Med ![]() Low ![]() eGear X-Flare Pro Focus Control 400 Headlamp (review - unfinished) High (flood) High (spot) ![]() Med (flood) ![]() Med (spot) ![]() Low (flood) ![]() Low (spot) ![]() Fenix L0D-CE High ![]() Med ![]() Low ![]() Fenix LD10 Premium Q5 Turbo ![]() High ![]() Med ![]() Low ![]() Fenix TK21 (review) Turbo ![]() High ![]() Med ![]() Low FoxFury Rook CheckMate (review) High Low ![]() ICON Link High ![]() Low ![]() IKEA Ljusa (given how quickly this light dims, I wound the light between each pic) ![]() JETBeam RRT-0 XR-E R2 L5 ![]() L4 ![]() L3 ![]() L2 JETBeam TCR-2 Max ![]() Klarus XT20 (review) High Med ![]() Low Lumapower D-65V w/TurboForce Kit and XR-E R2 L4 ![]() L3 ![]() L2 ![]() L1 ![]() Nitecore SR3 L8 ![]() L7 ![]() L6 L5 ![]() L4 ![]() L3 ![]() L2 ![]() L1 ![]() Niteye EYE-30 (preview) Turbo ![]() Olight M20 w/Manafont XM-L 3S Drop-In High ![]() Med Low ![]() Olight M20 Ti High ![]() Med Low ![]() Olight M21 High ![]() Med ![]() Low ![]() Pelican 1910 (review) ![]() Pelican 1920 (review) ![]() Petzl PIXA3 (HL was aimed so that the spot would be centered w/middle of door to be consistent w/other lights, further details of the unique flood/spot implementation of this HL can be found here) Flood Flood/Spot ![]() Spot Sunwayman T20C (review) High ![]() Med ![]() Low Sunwayman T40CS (review) High ![]() Med Low ![]() Sunwayman V10A UF 14500 ![]() ENLP ![]() Sunwayman V10R Ti Max Sunwayman V60C (review) Max ![]() Min
Lights in yellow are new as of 1/2/12. Lights sorted in alphabetical order by mfg. All shots were taken on a Panny FZ150 @ ISO-100, custom WB, f/2.8 and fixed shutter speeds of 1/8, 1/40 & 1/80. Distance to door is 5m (16.4ft) away. SureFire E1E w/kuku427 Warm XP-G 3S Tower High ![]() Med ![]() Low ![]() SureFire E2DL (200lms) High Low ![]() SureFire G2Z w/Neofab D1000 ![]() SureFire KL4 head w/VitalGear FB1 body Note: The KL4 head is identical to the one on the L4 and was designed for 2 CR123's @ 6V. These pics were taken on a single RCR123 3V (closer to 4V really) so check out the pics for the L4 to get an idea of what the beam of this head would look like w/2 cells). SureFire L1 AW 16340 High AW 16340 Low ![]() LiFePO4 High LiFePO4 Low ![]() SureFire L4 ![]() SureFire M3LT (review) High ![]() Low ![]() SureFire U2 (LuxV) L6 ![]() L5 ![]() L4 ![]() L3 - this level is defective on my light thus no pics L2 ![]() L1 ![]() SureFire U2 (P4) L6 ![]() L5 ![]() L4 ![]() L3 ![]() L2 ![]() L1 ![]() SureFire Z2 w/Malkoff M60 ![]() ThruNite TN10 (review) 1x18650 ![]() 2x18650 ![]() ThruNite TN11 (review) 1x18650 ![]() 2x18650 ![]() XENO G10v2 (review) High ![]() Med ![]() Low ![]() Zebralight SC30 (review) L6 ![]() L5 ![]() L4 ![]() L3 L2 ![]() L1 (didn't register) |
dmn42 (06.01.2012)
