Просмотров в теме 3386   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 05.01.2012, 23:11 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of RediLast 3100mAh (Black)
Official specifications:
  • 3100mAh Capacity
  • Protected against: overcharge, overdischarge, short circuit
  • Cell Made in Japan
  • 4.20v±0.05 charge voltage
  • 2.50v cut off voltage
  • 3.6v Nominal voltage
  • Charging type: CC/CV
  • Max charge current: 1C (3.1A)
  • Recommended charge current .3C
  • Max discharge current: 6.2A
  • Cell Size: ~18.5mm x 68.8mm
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
Conclusion
This battery uses a good cell, this secures many things:
  • The batteries does match in capacity, i.e. they can be used in series.
  • The battery is very safe.
  • The battery has the specified capacity (But only when tested at the specified conditions).
The battery has a very high current limit, this does not mean it can sustain more current than other 3100 mAh batteries, but just that the safety circuit will react later.
All in all a very good battery.
Notes and links
MOHAPX (06.01.2012)
Время генерации страницы 0.10694 секунды с 15 запросами
