Просмотров в теме 9176   Ответов в теме 8   Подписчиков на тему 4   Добавили в закладки 0
Старый 23.12.2011, 16:34 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of AW 18650 3100mAh (Black)
Official specifications:
  • Nominal Voltage : 3.6V
  • Capacity : 3100mAH ( rated at 0.2C discharge 4.2V - 2.5V @ 25° )
  • Operating Temp. : Charge 0 to 45° / Discharge -20 to 60 °
  • Recommended Charge Rate : max. 2170mA ( 0.7C ) - ambient temp. 25 °
  • Max. Discharge Rate : 6.2A ( ambient temp. 25 ° )
  • Dimensions :18.50 X 68.16mm ( +/- 0.3mm )
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
AW ships the batteries in a small box.
These batteries are real flattop batteries, i.e. the plus pole might not connect when pressed against a flat surface. This will usual prevent the batteries from being used in series (because the minus pole is a flat surface on most batteries), but because the minus pole on these batteries has 3 bumps, they work fine in series applications.
These batteries are slightly lower in capacity, compare to some other batteries with the same cell, this might due to a different production batch or the cells being slightly older.
Conclusion
This battery uses a good cell, this secures many things:
  • The batteries does match in capacity, i.e. they can be used in series.
  • The battery is very safe.
  • The battery has the specified capacity (But only when tested at the specified conditions).
The battery is one of the shorter 18650 batteries, but it is a flat top battery. The first can be an advantage, the last can be a disadvantage, depending on equipment.
All in all a very good battery.
Notes and links
5rybolov5 (23.12.2011), Admin (23.12.2011), Li-Ion (23.12.2011), MOHAPX (23.12.2011), serj_32 (23.12.2011)
Старый 23.12.2011, 17:14   2
serj_32
По умолчанию Re: Test/Review of AW 18650 3100mAh (Black)
И все же нету там 3100, но все равно отлично. Жаль цена кусается
Старый 23.12.2011, 17:27   3
dsche
Аватар для dsche
Последняя активность: Вчера 20:20
Сказал(а) спасибо: 1066
Поблагодарили: 4280 раз(а) в 2230 сообщениях
Вот ответ:
Посмотреть сообщение Сообщение от HKJ :
ויאמר אלהים יהי אור ויהי אור׃
Старый 23.12.2011, 17:36 Автор темы   4
HKJ
Аватар для HKJ
That is only part of the answer, the other part is the charging cutoff current, where I uses 100mA, but the data sheet says 60mA.
The full data sheet is here: http://industrial.panasonic...
I will test some cheaper batteries based on the NCR18650A later on.
Старый 23.12.2011, 18:07   5
dsche
Аватар для dsche
Is it 'International Outdoor' one?
Старый 23.12.2011, 18:24 Автор темы   6
HKJ
Аватар для HKJ
That is one of them, there is also another candidate, but I do not have the price yet.
I believe that it will be 6 different batteries with the NCR18650A cell I am going to test.
Старый 12.05.2012, 16:04   7
Be single wolf
Последняя активность: 24.07.2014 01:30
Сказал(а) спасибо: 17
Поблагодарили: 18 раз(а) в 13 сообщениях
Отправить сообщение для Be single wolf с помощью ICQ Отправить сообщение для Be single wolf с помощью Skype™
Блин, ну нахера в AW сделали утопленный плюсовой контакт? Зарядка Икстар не контачит, ТМ11 не контачит, у Зебры Н600 крышка со скрежетом закручивается из-за пупырышков на минусе. Надо было Редиласты брать.
Be single wolf вне форума   Ответить с цитированием Вверх
Старый 12.05.2012, 16:55   8
LUMENTORG.RU
Аватар для LUMENTORG.RU
Последняя активность: 07.07.2014 11:25
Сказал(а) спасибо: 4
Поблагодарили: 38 раз(а) в 18 сообщениях
Посмотреть сообщение Сообщение от Be single wolf :
С остальным согласен
LUMENTORG.RU вне форума   Ответить с цитированием Вверх
Старый 12.05.2012, 17:11   9
Be single wolf
Посмотреть сообщение Сообщение от LUMENTORG.RU :
Вложение 48079
Да она как-то через раз. То контачит, то нет.
Время генерации страницы 0.11920 секунды с 16 запросами
