12116
![]() Регистрация: 24.08.2011 Последняя активность: 24.08.2011 20:17
More Info.
The evolutionary G25C2 and G25C2 kit Features: - CREE XM-L U2 LED in premium tint (limited supply only, free upgrade from T6) - 2.7V-12.6V, takes 2xCR123A or 1x18650, (3-4 cells body extenders are also available) - Crazy 770 LED lumen output, ANSI FL-1 640 lumen, from a turbo reflector - Output (mode1): 770/320/59/2 lumen (ANSI FL-1 lumen: 640/267/49/2) - Runtime (mode1): 1.1/3.5/20/200 hours - Output (mode2): 770/90/strobe/disoriented strobe lumen (ANSI FL-1 lumen: 640/74) - Runtime (mode2): 1.18/10 hours - Rotary head design for instant access to four levels - Low drop-out voltage and highly efficient current regulated C2100 EX circuit offers flat regulation when using all batteries, even with a single 18650 li-ion - Programmable settings for 1) mode1 or mode2 output, 2) tailcap strobe access, 3) energy-saving feature - Multiple spring loaded mechanism inside the flashlight body to prevent battery rattling when using CR123A batteries - (kit only) 3 cells extender body tube for 3 CR123A/RCR123A, and 4 cells extender body tube for 4 CR123A or 2 18650 - (kit only) Add-on filter assembly made from solid aluminum, with flip-over filter door and lock. Comes with diffuser and YRGB output. The included holster fits G25C2 with bezel or filter assembly attached. Standard version includes: - EagleTac G25C2 flashlight - Black titanium coated stainless steel bezel (removable) - Spare O-rings - GITD switch boot - Black titanium coated Stainless steel pocket clip - User manual - Tail-stand rubber boot - Soft cigar holding grip - Cigar grip cover ring - Lanyard ring attachment ring - Heavy Duty Nylon Holster w/ self-retention device and flip - Mil-Spec Paracord Lanyard w/ quick attachment clip - Two ET CR123A batteries included YRGB Lens Kit version includes: - Durable aluminum flip-over filter assembly - Diffused, yellow, red, blue, and green optical grade anti-reflective coated add-on lens. - 3 cells extension body tube for three CR123A/RCR123A - 4 cells extension body tube for four CR123A or two 18650 li-ion Optional Accessories: - 3 cells extension body tube for three CR123A/RCR123A - 4 cells extension body tube for four CR123A or two 18650 li-ion |
Параноик
Регистрация: 19.06.2012 Последняя активность: 21.05.2019 22:19
Сказал(а) спасибо: 117
Поблагодарили: 33 раз(а) в 27 сообщениях
EagleTac
Do you produce it with a smooth reflector? There are important range and the concentration of light for a tactical flashlight, especially when shooting with it.
Налобное: Petzl MYO XP, Fenix HP10, Spark ST5-150CW Подствольно-походное: Armytek Predator v.2 R4 5/24, Xeno F42 v.2, Fenix LD41, Fenix LD40 Наключник: Quark Mini ML Нестандарт: хозбыт ФПС-4/6C(акб Дельта сдох), ЭРА КА16М(+з/у 4.2В), свечи 100штх3 |
