Просмотров в теме 6747   Ответов в теме 8   Подписчиков на тему 3   Добавили в закладки 0
Старый 09.11.2011, 20:59 Автор темы   1
Администратор
Аватар для Admin
Сказал(а) спасибо: 4331
Поблагодарили: 10697 раз(а) в 2546 сообщениях
По умолчанию Surefire Fury Ultra-High/Dual-Output LED Flashlight 500 Lumens
Expected mid-late December!
Surefire Fury LED Flashlight
SureFire’s Fury is a more powerful, slightly larger version of our best-selling dual-output 6PX Pro. It features the same 15-lumen low-output beam that’s perfect for tasks where too much light might compromise your dark-adapted vision, or situations in which extended runtime is a higher priority than maximum output. But the Fury’s high-output setting is an incredible 500 lumens, two-and-a-half times that of the Pro model. A larger reflector focuses all of this light forward to create a tight beam with plenty of reach that’s perfect for searching, signaling, or lighting up a target far off in the distance. The Fury features a tough but lightweight hard-anodized aerospace aluminum body and an orientation-independent tailcap switch that controls output: press (for momentary-on) or click (for constant-on) once for low output; return to off then press or click again (within two seconds) for high.
Features and Specifications:
  • Virtually indestructible LED emitter regulated to maximize output and runtime
  • Two output levels: High for maximum light, Low for extended runtime
  • Precision micro-textured reflector creates a smooth, optimized beam
  • High-strength aerospace aluminum body, hard anodized for extreme durability
  • Weatherproof O-ring and gasket sealing
  • Output (Runtime):
    • High: 500 lumens (1.5 hours)
    • Low: 15 lumens (46 hours)
  • Bezel Diameter: 1.375" (3.5 cm)
  • Length: 5.4" (13.7 cm)
  • Weight (with batteries): 5.7 oz (161 g)
  • Switching: Dual-output tailcap click switch- press or click for low, return to off then press or click again for high.
  • Material: Made of Aerospace aluminum, Mil-Spec hard-anodized; polycarbonate window
  • Color: Black
  • Batteries: 2 x Lithium CR123A (included)
http://www.batteryjunction....
Старый 09.11.2011, 21:05 Автор темы   2
Admin
Администратор
Аватар для Admin
По умолчанию Re: Surefire Fury Ultra-High/Dual-Output LED Flashlight 500 Lumens
Еще немного информации о будущей новинке http://www.trademarkia.com/...
Старый 09.11.2011, 21:32   3
RN4HKK
Любитель Surefire
Аватар для RN4HKK
Сказал(а) спасибо: 34
Только вчера читал CPF на счет этого фонарика... Штука интересная, но бюджетность так и прет. Стекло говорят "пластиковое". Основная фишка шуров - TIR оптика, а тут же просто рефлектор, и вероятнее всего, XM-L.
Старый 09.11.2011, 21:45   4
awl
Аватар для awl
Сказал(а) спасибо: 208
Интересно, как теплоотвод организован. Неужто в рефлектор, как в P60 модулях?
Старый 09.11.2011, 22:54   5
RN4HKK
Любитель Surefire
Аватар для RN4HKK
Посмотреть сообщение Сообщение от awl :
Нет конечно. Они ушли от стандарта P60 в светодиодных фонарях. Теперь голова это единое целое.
Старый 10.11.2011, 00:34   6
Светлячок
Авторизованный Хемуль
Аватар для Светлячок
Сказал(а) спасибо: 985
Классно. Интересна цена.
Upd. нашел. 155$ там, значит здесь порядка 6 тыс. Интересный вариант.
Старый 10.11.2011, 00:58   7
knyaz
Аватар для knyaz
Сказал(а) спасибо: 47
Блин, они обещали в этом году фонари на аккумах выпустить..командер,авиатор,убр...
А это-бюджетная какашка)
knyaz вне форума   Ответить с цитированием Вверх
Старый 10.11.2011, 02:30   8
xrennov
Флешоголик в завязке.
Аватар для xrennov
Сказал(а) спасибо: 16
Скучный он, да и минимум в 60 люм надо было, а не 15.
Мне плевать - какое оно есть, я знаю каким оно должно быть!!!
P.S. Подайте страждущему флешаголику топовый фонарик на тестирование.
Старый 20.08.2012, 11:09   9
Bayarin
Последняя активность: 12.11.2012 09:54
Я приобрёл такой.. Не хватает ещё одного режима.. 15 люмен только в комнате посветить.. а так ещё бы люмен 40 - 60 было бы самое то.. Ну и а 500 претензии нет..
Bayarin вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.09542 секунды с 16 запросами
