Просмотров в теме 11118   Ответов в теме 12   Подписчиков на тему 4   Добавили в закладки 0
Старый 02.11.2011, 11:44 Автор темы   1
Flashlight surgeon
Аватар для Apchxi
Последняя активность: 23.11.2022 23:06
Сказал(а) спасибо: 55
Поблагодарили: 131 раз(а) в 79 сообщениях
Отправить сообщение для Apchxi с помощью ICQ Отправить сообщение для Apchxi с помощью Skype™
По умолчанию NEW Klarus XT1A, XT2A, XT1C, MiX5 The Midas Torch
Сегодня пришла информация от производителя по новым моделям.
Klarus MiX5 The Midas Torch
Exquisite, Compact and Reliable. Designed for every day carry
Features:
One of smallest and brightest AAAA flashlight in the world
Durable, compact and reliable. Designed for every day carry
Digitally regulated output - maintains constant brightness, no PWM
Max output: 76 Lumens. Max run time: 26 hours
Reverse polarity protection
Specification:
Emitter: Cree XP-E R2 LED with a lifespan of 50,000 hours
Four outputs, 25 lumens(2.2 hours) --
2 lumens(26 hours) --
76 lumens(40 minutes)--
Strobe (76 lumens, 1.2 hrs)
Battery: Single AAAA (Alkaline, Ni-MH)
Switch: Twist switch, Adjust output by rotating the flashlight head
Lens: Toughened ultra-clear glass
MaterialStainless steel
Dimensions65.6mm (Length) x 9.2mm (Body) x 10.3mm(Head)
Net weight: 11g (Excluding battery)
Waterproof to IPX-8 standard
Klarus XT1A
Tactical, Military Grade Flashlight for Everyday Use
The new XT series flashlights from Klarus are serious, precision-engineered illumination tools, which have been developed with tactical use and self-defense in mind. Part of the XT (Extreme Tactical) range, which includes the popular XT10 and XT20, this new XT1A is a true Tactical EDC. Being smaller than the XT10, it is easy to carry in a pocket or bag.
Despite being small, the XT1A is very bright – outputting a maximum 150 ANSI lumens with a single AA battery. It uses Klarus's innovative dual-button tail switch (as seen on the XT10 and XT20 models) to allow for fast mode changes (from High to Medium and Low) and provide lightning-quick access to a super bright and disorientating strobe – making the XT1A an amazing self-defense flashlight.
Specification 1.CREE XP-G R5 LED with a lifespan of up to 50,000 hours
2.Three lighting modes and 1 flashing mode:
a)Lighting modes: 150 ANSI lumens (1hrs)
b)30 lumens (6 hrs)
c)4 lumens (50hrs)
d)Variable frequency strobe: 150 lumens (2hrs)
3.Working Voltage: 0.9V-1.8V
4.Battery: 1pcs 1.5V AA Alkaline or Ni-MH (not included). 14500 lithium-ion battery will destroy the light
5.Body color: Military grey
6.Reflector: Textured orange peel reflector
7.Switch: Dual tail switch
8.Tactical main switch for turning the light on and off. Momentary activation from off.
9.Dedicated mode switch for instant access to strobe and changing modes
10.Lens: Toughened ultra-clear glass
11.MaterialAircraft grade aluminum
12.Dimensions: 116mm (Length) x24mm (Head) x22.6 (Body)
13.Net weight: 53g (Excluding battery)
14.Waterproof to IPX-8 Standard (underwater to 2 meters)
15.Included accessories: holster, lanyard, body clip and two spare o-rings
Klarus XT2A
Despite being an AA battery light, the XT2A is very bright – outputting a maximum 245 ANSI lumens with 2x AA batteries. It uses Klarus's innovative dual-button tail switch (as seen on the XT10 and XT20 models) to allow for fast mode changes (from High to Medium and Low) and provide lightning-quick access to a super bright and disorientating strobe – making the XT2A an amazing self-defense flashlight.
a)Lighting modes: 245 ANSI lumens (1.5hrs)
b)60 lumens (8 hrs)
c)4 lumens (130hrs)
d)Variable frequency strobe: 245 lumens (3hrs)
3.Working Voltage: 1.8-3.2V
4.Battery: 2pcs 1.5V AA Alkaline or Ni-MH (not included). 14500 lithium-ion batteries will destroy the light
12.Dimensions: 163mm (Length) x24mm (Head) x22.6 (Body)
13.Net weight: 75g (Excluding battery)
Klarus XT1C
Despite being small, the XT1C is very bright – outputting a maximum 245 ANSI lumens with a single CR123 battery. It uses Klarus's innovative dual-button tail switch (as seen on the XT10 and XT20 models) to allow for fast mode changes (from High to Medium and Low) and provide lightning-quick access to a super bright and disorientating strobe – making the XT1C an amazing self-defense flashlight.
Specification
a)Lighting modes: 245 ANSI lumens (1hrs)
b)60 lumens (4 hrs)
c)4 lumens (70hrs)
d)Variable frequency strobe: 245 lumens (2hrs)
4.Battery: 1XCR123
7.Switch: Dual button tail switch
12.Dimensions: 99mm (Length) x24mm (Head) x22.6 (Body)
13.Net weight: 47g (Excluding battery)
Apchxi вне форума   Ответить с цитированием Вверх
Старый 02.11.2011, 11:58   2
Последняя активность: Сегодня 04:58
Сказал(а) спасибо: 17767
Поблагодарили: 40131 раз(а) в 14862 сообщениях
По умолчанию Re: NEW Klarus XT1A, XT2A, XT1C, MiX5 The Midas Torch
Спасибо, интересно!
Старый 21.06.2012, 19:57   3
Alejandro
Последняя активность: 11.09.2014 21:31
Поблагодарили: 20 раз(а) в 8 сообщениях
XT!1X Я так понял не работает от аккумулятора, обломно
Alejandro вне форума   Ответить с цитированием Вверх
Старый 22.06.2012, 00:36 Автор темы   4
Apchxi
Flashlight surgeon
Аватар для Apchxi
Посмотреть сообщение Сообщение от Alejandro :
От 14500 нет, от обычного Ni-Mn запросто работает
Старый 22.06.2012, 00:40   5
ssr
Аватар для ssr
Сказал(а) спасибо: 80
Посмотреть сообщение Сообщение от Apchxi :
что за формат питания такой)
Старый 22.06.2012, 00:41   6
Alejandro
Apchxi,
От какого такого обычного?
Там в анотации указано
CR123 battery.
Старый 18.05.2013, 14:55   7
Intel-LeGeND
Последняя активность: 31.12.2013 09:54
Klarus XT1C, как я понимаю, работает только от батареек CR123?.. Аккумуляторы использовать нельзя?
Intel-LeGeND вне форума   Ответить с цитированием Вверх
Старый 20.05.2013, 14:22   8
altur
Аватар для altur
Последняя активность: 18.04.2022 07:36
Сказал(а) спасибо: 356
Поблагодарили: 246 раз(а) в 106 сообщениях
Посмотреть сообщение Сообщение от Intel-LeGeND :
Можно. Только 3х вольтовые.
altur вне форума   Ответить с цитированием Вверх
Старый 21.05.2013, 21:07   9
Александр Павлов, не слабо поговорили сами с собой) Все решили и всем довольны)
Старый 21.05.2013, 21:33   10
crus
Последняя активность: 05.01.2018 02:18
Сказал(а) спасибо: 280
Это магазин приколов?).
crus вне форума   Ответить с цитированием Вверх
Старый 21.05.2013, 21:37   11
crus
Посмотреть сообщение Сообщение от Александр Павлов :
в смысле? где дешевый на 1й ааа
На остальные цены глянь. ТК 35 - 1150р. катапульт 3 - 1500р и т.п. Мелкие зебры по 800. Распродажа посылок с почты?
Зы :На форуме уже было сообщение от пострадавшего на сайте-мошеннике dachnayatehnika.ru При поиске в Google по запросу "Телефон: 788-24-22, 788-21-29" открывается более 500 ссылок на различные интернет-магазины, имеющие эти контактные данные и одинаковый почтовый адрес: 43567, Россия,Москва, ул.Лазарева, 47, оф.21
http://forum.ozpp.ru/showth...
[Исправлено: crus, 21.05.2013 в 21:42]
Старый 28.05.2013, 11:30   12
KLARUS-UA
Аватар для KLARUS-UA
Последняя активность: 29.08.2016 13:34
Сказал(а) спасибо: 4
Поблагодарили: 21 раз(а) в 7 сообщениях
Друзья, предлагаем небольший видеообзор XT1C KLARUS
KLARUS-UA вне форума   Ответить с цитированием Вверх
Старый 03.06.2013, 10:49   13
KLARUS-UA
Добрый день! Я так понимаю Вы имеете ввиду видеообзор фонарика MiX5Au.
Так вот- модель MiX5Au уже снята с производственной программы, распродаются остатки. Сняли с производства в виду редкости батареек АААА и полном отсутсвии в продаже аккумуляторов АААА.
Название: Klarus MiX5Au 2.jpg
Время генерации страницы 0.15113 секунды с 16 запросами
