Вернуться   Форум FONAREVKA.RU Торговая площадка Производители/Дистрибьюторы/Дилеры фонарей и аксессуаров SKILHUNT
Просмотров в теме 9285   Ответов в теме 10   Подписчиков на тему 4   Добавили в закладки 0
Старый 10.10.2011, 13:26 Автор темы   1
Аватар для skilhunt
Последняя активность: 10.06.2025 04:25
Поблагодарили: 159 раз(а) в 53 сообщениях
По умолчанию The Prevue of SKILHUNT DT-20 Night Owl
Hello everyone,
Good News!
Skilhunt is proud to announce the latest release : DT-20 Night Owl
The first color argentate comes first, now! ( Other colors should be release this weekend.)
DT-20 Night Owl The first color: Argentate
Specification:
2× CREE XLamp XM-L U2 LED
LENS:Toughened ultra-clear glass lens with double anti-reflective coating and diamond coating.
Power: 4x CR123A, 2x 18650, 4x RCR123A, 4x 16340
Max Output: 1100 Lumens
Switches
Double side switches(On-off button and Mode transfer button)
On-off button:Click to turning on flashlight, 2 LEDs light up,then press this button can access to light up LED one by one. Hold press 2 seconds to turning off the flashlight.
Mode transfer button:Transfer mode when flashlight turn on.Single LED/ Double LEDs Circulate as High-Med-Low-Beacon(Beacon output as same as Mid mode) -Repeat-。double-click access to Strobe mode
Press Mode transfer button, click the On-off button to access Double LEDs, both in high mode.
Reflectors:
2xDurable aluminum vacuum plating orange peel reflector
Mode and Brightness: Offers Double LEDs, or Single LED (lit one by one) output
Double LEDs Mode: High-Med-Low-Beacon-Repeat- double-click mode transfer button to access Strobe mode
Single LED Mode: High-Med-Low-Beacon-Repeat- double-click mode transfer button to access Strobe mode
Dimension:
Head(max)73 x 37mm; Length: 151.5mm
Accessories: Holster , 550 paracode lanyard, Two spare switch cap rubber boot, Four rubber ring, Operator's manual
Features
1. 2 x CREE Xlamp XM-L U2 LED, Super bright。
2. Innovation patented design。
3. Special double LEDs with dual-circuit design providing a reliable safeguard.
4. Parallel circuit design offers single led use. Can be powered by single 18650 battery in extreme__ circumstances.
5. Double holes and wide multi level design offer excellent heat dispersion
6. Double side switch offer user-friendly interface to turn on/off and adjust output.
7. 304 stainless steel bezel rings effectively protect the light from drops and impacts.
8. Toughened ultra-clear glass lens with anti-reflective coating and diamond coating.
9. Ergonomic design, Comfortable hold, and solid aluminum construction.
10. Wide input range provides more choices of batteries.
11.Reverse polarity protection, to protect from improper battery installation.
12.Over-discharge protection circuit, protects the batteries effectively.
Warning:
1.Please read the manual before use the flashlight.
2.Insert batteries with the positive(+) end pointing to the head. Reverse batteries will damage the circuit, even cause a explosion!
3.Do not mix batteries of different types/brands. Do not mix batteries of different charge levels. Do not mix batteries of different capacity.
www.skilhunt.com
info@skilhunt.com
skilhunt вне форума   Ответить с цитированием Вверх
Старый 10.10.2011, 13:31   2
SML
Аватар для SML
Сказал(а) спасибо: 21
По умолчанию Re: The Prevue of SKILHUNT DT-20 Night Owl
Prototip?
Мои фонари
Старый 10.10.2011, 16:26   3
Zontik
Сказал(а) спасибо: 385
2 секунды на выключение? Как-то это... спорно.
Старый 13.10.2011, 20:13   4
jose
Последняя активность: 23.04.2019 13:09
Сказал(а) спасибо: 6
Поблагодарили: 37 раз(а) в 21 сообщениях
Eще фотка...
born to hunt, forced to work...
jose вне форума   Ответить с цитированием Вверх
Старый 28.03.2012, 11:49   5
jose
Вишел новой DT20 - черной цвет , покритие тип III
havoc (28.03.2012)
Старый 28.03.2012, 12:05   6
Сказал(а) спасибо: 5056
Красавец.
Старый 22.04.2012, 18:13   7
oleg235
Сказал(а) спасибо: 25
Посмотреть сообщение Сообщение от skilhunt :
А что мешает сделать защиту от переполюсовки?
Старый 23.04.2012, 11:14   8
jose
pointing to the
При нормальное изпользование фонаря, защита не нужная. Есть Еще и SKILHUNT не рекомендует дисасемблинг фонаря...Short cirquit 18650 батареек, как я понял - дело опасное...
[Исправлено: jose, 23.04.2012 в 11:47] Причина: ошибка
Старый 25.04.2012, 14:17   9
oleg235
Посмотреть сообщение Сообщение от jose :
Ну так что им мешает сделать?
Старый 13.06.2012, 20:45   10
jose, есть вопрос по DT20. В описании не нашел про память режимов. Получается что фонарь всегда включается с максимальной яркостью с обоих голов?
Старый 14.06.2012, 09:40   11
jose
У DT 20 нет памят режимов. Да, всегда включается на максимуме с обе рефлектора.
havoc (14.06.2012)
Время генерации страницы 0.09826 секунды с 16 запросами
