11714
![]() Регистрация: 30.08.2011 Последняя активность: 22.10.2011 05:19
788 Lumens Powerful Long Shot Side Switch Tactical Flashlight
-- CREE XM-L T6-- SUNWAYMAN T40CS is specially designed for those who need an extremely high performance flashlight- military, law enforcement, search and hunting applications. Fitted with newly designed SUNWAYMAN reflector, T40CS has powerful thrower light, long shot, perfect spot and ideal beam pattern. Maximum output reaches as high as 788 lumens with an effective range of 500+ meters. Equipped with SUNWAYMAN tactical remote pressure switch, the T40CS can be utilized for rapid response on alert. T40CS comes with three plastic tactical rings for different applications, very convenient and considerate. The brand-new long shot T40CS is an ideal lighting tool for work, exploration, search and much more. Powerful Long Shot, Effective Range of 500 Meters Fitted with newly designed SUNWAYMAN reflector, T40CS has powerful thrower light, long shot, perfect spot and ideal beam pattern. Maximum output reaches as high as 788 lumens with an effective range of 500+ meters. It’s an ideal lighting tool for those who need an extremely high performance flashlight, such as hunting, law enforcement, and search etc. applications. Multi-functional Soft-contact Side Switch, New Experience SUNWAYMAN T40CS comes with the newly designed soft-contact side switch, simply depressing the side switch for super-low standby mode (about 50μA super-low standby current), High-Mid-Low output, Hidden Strobe and SOS; When the tail cap switch is turned on, the light can memorize the most recent mode used, moreover, when the light is at standby mode, simply depress and hold the side switch for about 2seconds to activate the max output mode immediately, unaffected by the memory function, we call it “Smart Magic Switch”. Permanent Max Output Tactical Momentary-on Specially designed for tactical applications, by depressing the tail cap switch, the T40CS always comes at Max mode for both momentary-on and constant-on, unaffected by the side switch, which can meet your demand of rapid response, tactical alert etc. CREE XM-L T6, Max Output Up to 788 Lumens Fitted with CREE XM-L T6 LED, max output reaches as high as 788 lumens, high-efficiency circuit, extended runtime of up to 2 hours; this light maintains a great balance between high output and long runtime, plus practical output modes for daily use. Features ● CREE XM-L LED, with a lifetime of up to 50,000 hours; ● Tactical Tail cap press button switch, slightly depress the side switch for different output modes and standby mode: Three modes constant output, hidden strobe, SOS (below is the output and runtime of using two 2600mAh 18650 batteries) Three constant output modes: 788Lumens (2hrs)- 220Lumens (8hrs)- 20Lumens (60hrs) Strobe: 788 Lumens SOS: 788 Lumens ● Constant current circuit, constant output ● Effective range of 500 meters ● Uses two 18650 or four CR123A batteries ● Working voltage: 5.5~16.8V ● High quality reflector maintains great throw distance and spread with an ideal beam pattern ● Dimensions: 225mm (length) x 64mm (head diameter) x 25.4mm (tail diameter) ● Weight: 273g(battery excluded) ● Aerospace-grade aluminum alloy ● Military Specification Type III- hard anodized body ● Waterproof, in accordance with IPX-8 standard ● Ultra-clear tempered glass lens resists scratches and impacts ● Tactical forward click switch with momentary on ● Accessories: tactical ring, holster, O-ring, rubber cap Remarks: Product specifications are subject to change without prior notice; Please always refer to our home page for most updated specifications.
Sunwayman Team SUNWAYMAN / SUNWAYFOTO www.sunwayman.com www.sunwayfoto.com We Care.... Customer First!! |
Admin (08.10.2011)
Администратор
Сказал(а) спасибо: 4330
Спасибо за информацию!
Ждите обзор в скором времени!
А вот и обзор!
