39955
62
![]() Регистрация: 28.07.2011 Последняя активность: 10.12.2014 12:07
Записей в дневнике: 1 Сказал(а) спасибо: 1
Поблагодарили: 17 раз(а) в 7 сообщениях
XENOled is glad to own the space in fonarevka.ru where we can interact with Torch Mania
XENO is not a mysterious brand that without sufficient infomation on interenet once people have interest in, but XENO is a quality brand that worthy for people to know, useful for people to use. Till now, XENO have expanded foreign market for about 2 years, it compared so young, but it is powerful in quality, in design, in CNC machine processing, in fasting reseach which help us win the cooperation with dealers/distributors from Japan, South Korea, USA, Germany, France, CZ, Ukrain, Tailand, etc. we are expecting more and more dealers/distributors to join us, expecting more and more people can enjoy these good torches. To help people jugde&compare the flashlight performance, XENO adopt uniformed rating standard ANSI/NEMA FL-1 on new models XENO G42 V2, XENO F42 V2, XENO G10 V2. light output, runtime, beam distance, peak beam intensity, impact resistance and water resistance are strictly tested under the guide of ANSI/NEMA FL-1 Standard. XENO also carry out other tests such as constructure-hardness test, vibration test, Salty Spray test,etc.. To the point, let's begin to brief introduction on XENO G42 V2, when people view it by naked eyes on picture, it looks a big torch, but actually, it only be powered by 1pcs 18650 Li-ion battery or CR123A*2,generally, G42 with length 6.3'' will be classified as a pocket torch; however, it can give out bright beam, output 605lms (OTF)/2200mA, G42 really a small sun. Some consumers doubt why not to set higher current 2500mA or 2700mA based on the performance ability of currently 2200mA G42. the reason that when we design models, "Reliablity, durability" will be the most important elements we consider, the safe, reliable max current will be considered. people need a reliable partner, not a risk-potential,trouble tool in their life, that's why we can promise 3 year warranty on models branded XENO. Come back to the high-effeciency output 605lms(OTF), some key elements help more, the first, it's material, Material of all parts is selective&elaborate-designed such as AR-coated lens, full brass parts of electric-access with silver, gold assistant, Gold-Electroplate spring, precision aluminum reflector, etc. the second, it's high effecinecy Engine DDU3, designed by XENO is Linear led driver, matched with XENO R42X2 reflector, with reasonble-designed constructure, torch can get good heat-dispersing, well-protect the driver to cause a high-effeciency output. the third, it's the construction, the inner structure between head and body lockup by machining method(XENO unique in the world), not O-rings, the magic is the torches still warter-proof, and the clip can be dismantled through some method. XENO have the advantage in indurstral design, CNC machine processing, combined with Aesthetics, the appearance of body, small parts(reflector, springs, tailcap switch), accessories(lens-secure rings RG42, strike bezel, lanyard system LS10E,etc), not only makes torches durable, but exquisite&elegant. XENO G42 professinally designed for searching, rescuing, hunting, daily-working, etc. let's view the following pictures or u can view pictures of full range of XENO torches on my flickr http://www.flickr.com/photo... welcome your questions. When G42 come to u, it will be with unique serial-number. each XENO torches with unique serial-number, come with Spare parts: O-rings*2, switch part*1 Accessories: XENO STT10:stainless Strike Bezel in tailcap: secure-ring, windows break, self-defence. XENO RG42 Stainless Secure-Ring for Window(Lens). XENO LS10E Enhanced Lanyard System, with XENO XRD-the best Lanyard Ring on the blue Earth. XENO L01 Nylon Cord Wrist Lanyard ![]() ![]() ![]() Magic lanyard system ![]() AR-coated lens ![]() Lens-secure ring XENO RG42 ![]() Detachable belt clip ![]() XENO DDU3 driver ![]() Stailless steel taicap bezel ![]() ![]() Beam shot ![]() ![]() ![]() ![]() XENO G10 V2 review ![]() ![]() ![]() ![]() ![]() ![]() XENO ST03/RG03 bezel/lens-secure ring , for XENO G10 V2, XENO F8 V6, XENO E06, XENO F7 V6 ![]() XENO TW02 traffic wand for XENO G10 V2, XENO F8 V6, XENO E06, XENO F7 V6 ![]() XENO CUBE E11 V7 surface with Ti-electroplating finish, color: black ![]() XENO CUBE E11 V7 surface with polish finish ![]() XENO E03 ![]()
[Исправлено: XENOled, 01.09.2011 в 12:05] Причина: add picture |
Рады приветствовать на фонаревке!
Очень интересный фонарик! А можно фото рефлектора фонаря?
мне в обще все до фонаря
Регистрация: 04.03.2011 Последняя активность: 05.12.2014 00:29
Сказал(а) спасибо: 36
Поблагодарили: 31 раз(а) в 26 сообщениях
приветствую
рад видеть на фонаревке и сразу вопрос why cube so expencive?
там где появляется халява-заканчивается объективность |
Шурик с шуриком
about a week ago had recieved e03 on t4 and tw15 - excellent flashlight!
But it become better if it has pocket clip and such smart crowned view bezel!!!
Администратор
Сказал(а) спасибо: 4330
XENOled,
![]() XENOled присвоен на нашем форуме статус "Авторизованного производителя". |
Hi Tim4r70, thanks for your questions
LV is so expensive, right? Generally, the expensive goods uniformly features quality material, outstanding processing technic, unique design, long-time process and durability in use. CUBE is an expensive torch.. Normally, production of 200pcs CUBE will takes about 2 months, CUBE made of stainless steel solid cylinder, this material will be processed through these mainly procedures: 1. Pouch hole by CNC 2. Shape each side of CUBE body by milling machine (will cause very high defect rate, if don't sucess in milling every side, the whole body will be a scrap) 3. Polish each side (this procedure finished by hand, only 40pcs>= finished to be successfully polished by one skilled worker in continuous 8 hours) 4. laser unique serier-no. on each body (generally, a lot of one model will be with the same serier-no., but all of XENO torches with unique serier no., your CUBE is the unique in the world) 5. Design driver, reflector, tail-switch, etc., pick out the quality material,parts to fill the body. I think people all like beautiful things, that's why even LV, surefire, CUBE expensive, people still like to buy them.. |
Hi asket32420, thanks for your positive feedback, thanks for your attention on XENO torches, welcome u come to my thread
[Исправлено: XENOled, 02.09.2011 в 13:25] Причина: hi |
Hi dsche
Each CUBE come with spare parts: O-rings*2, switch part*1 Accessories: 1.XENO LS10E*1 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment) 2. XENO H3GL, Calfskin Genuine holster Packed into Tin box RRP(Recommended retail price) US$98 for XENO CUBE E11 V7 with XM-L 7B T4 WW or XM-L 3C T5 NW |
можно тогда и все цены привести
Hi Tim4r70
Answer here: Currently, XENO torches of D serier and E series classified by battery types. XENO D series with 18650*1 Li-io rechargeable battery or CR123A*2 one-way Li-Poly battery. Typical Models: G42, G10, G5, F42, F8, F7... XENO E series with any AA size battery inluding One-way battery and reachargeable battery. Typical Models: E11, E06, E15, E03... RRP(Recommended Retail Price) listed for ref., generally, the concluded price is not the same as RRP, and it is subject to final confrimation by dealers. Different types of led, different RRP, but the price gap is not big or the same. So i only list the PPR price of models with XM-L 1B T6 led except XENO G10 and G42 with XM-L 1B U2. XENO G42 V2 with XM-L 1B U2 US$113 with 1pcs switch spare part, 2pcs O-rings, 1pcs LS10 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment) XENO F42 V2 US$85 with 1pcs switch spare part, 2pcs O-rings, 1pcs LS10 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment) XENO G10 V2 with XM-L 1B U2 US$85 with 1pcs switch spare part, 2pcs O-rings, 1pcs LS10 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment) XENO G5 V6 US$80 with 1pcs switch spare part, 2pcs O-rings, 1pcs LS10 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment) XENO F8 V6 US$69 with 1pcs switch spare part, 2pcs O-rings, 1pcs LS10 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment) XENO F7 V6 US$49 with 1pcs switch spare part, 2pcs O-rings, 1pcs LS10 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment) XENO E11 V7 US$95 with 1pcs switch spare part, 2pcs O-rings, 1pcs LS10 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment), XENO H3GL*1 (calfskin Genuine holster) XENO E03 V2 US$38 come with 1pcs switch spare part, 2pcs O-rings, 1pcs hand strap XENO E15 V2 US$63 come with 1pcs switch spare part, 2pcs O-rings, 1pcs hand strap XENO E06 V6 US$71 with 1pcs switch spare part, 2pcs O-rings, 1pcs LS10 Parachute Cord(Mil-spec. lanyard system)with Punched Stainless Lanyard Ring (u can find the detailed spec. in attachment) glad to get questions, and welcome quesitions! |
Псевдоним (05.09.2011)
Hi, u are right, official website www.xenoled.com, currently, we are planning to release a new version website, i think it will come soon..
Регистрация: 08.03.2011 Последняя активность: Сегодня 15:14
Записей в дневнике: 4 Сказал(а) спасибо: 17688
Поблагодарили: 39934 раз(а) в 14775 сообщениях
Не очень понятно, почему на сайте многие фонари (например, E03) на XP-G, если они уже довольно давно на XM-L.
17
Hi fnksb, i guess the staff who manage website is in love with XP-G torches. just joking.. actually, some of our engneers like XP-G, and XM-L optional for each XENO torches..
I will pass your question to this man.. thank u ![]() |
Регистрация: 20.01.2011 Последняя активность: 01.03.2025 21:16
Сказал(а) спасибо: 28
Поблагодарили: 16 раз(а) в 12 сообщениях
Хорошо бы цены разместить на непосредственно на сайте,а еще лучше интернет магазин полноценный создать,с условиями доставки,сервиса и т.д
http://tacticalhid.info/ является вашим дилером?
У носорога плохое зрение,но при его весе это уже проблема окружающих |
Hi, welcome, yes, u are right.
Регистрация: 29.12.2010 Последняя активность: 14.01.2025 21:56
Сказал(а) спасибо: 343
XENOled, hi and welcome to Fonarevka
![]() I have one question: what`s the difference between Xeno E03 V2 and V3? |
