16983
29
Регистрация: 10.07.2011 Последняя активность: 20.02.2020 14:54
Сказал(а) спасибо: 7
Всех приветствую!)
В продаже следующие экземпляры, все новое, территориально в Казани, перешлю по РФ 1ым классом, цена без учета пересыла. Jetbeam BA10 - 1950 руб. - 1500 руб. ПРОДАН The Jetbeam BA10 utilizes one AA battery featuring a Cree R5 LED with an output of 160 lumen. Modes: 2 Modes: High (160 Lumen), Low (12 Lumen) Run Time: High - 75 minutes, Low - 30 Hours Battery Type: One AA Battery Size: 23mm x 107mm Weight: 60g (without battery) Finish: HAIII Hard Anodized Mil-Spec Finish Glass: Hardened Glass Lens with Anti Reflective Coating Reflector: Machined Aluminum Reflector Waterproof: IPX-8 Standards (2 Meters) Accessories: Pocket Clip Jetbeam BC10 - 1950 руб. - 1500 руб. ПРОДАН The Jetbeam BC10 is a single cell (CR123) flashlight featuring a Cree R5 LED with an output of 270 lumen. Modes: 2 Modes: High (270 Lumen), Low (30 Lumen) Run Time: High - 75 minutes, Low - 18 Hours Battery Type: One CR123 3V Glass: Hardened Glass Lens with Anti Reflective Coating Reflector: Machined Aluminum Reflector Size: 23mm x 90mm Weight: 47g (without battery) Finish: HAIII Hard Anodized Mil-Spec Finish Waterproof: IPX-8 Standards (2 Meters) Accessories: Pocket Clip Jetbeam BA20 - ПРОДАН The Jetbeam BA20 utilizes two AA batteries featuring a Cree R5 LED with an output of 270 lumen. Modes: 2 Modes: High (270 Lumen), Low (30 Lumen) Run Time: High - 105 minutes, Low - 35 Hours Battery Type: Two AA Batteries Size: 23mm x 155mm Weight: 71g (without battery) Finish: HAIII Hard Anodized Mil-Spec Finish Glass: Hardened Glass Lens with Anti Reflective Coating Reflector: Machined Aluminum Reflector Waterproof: IPX-8 Standards (2 Meters) Accessories: Pocket Clip Jetbeam BC20 S2 edition - 1950 руб. Features . Premium Cree S2 LED . Powered by two CR123 batteries . Aero grade aluminium alloy construction . High performance reflector-based optic system . Fully regulated advanced power management . Reverse polarity protection circuit . 2 modes of output . AR coated scratch-resistant mineral glass lens . Type III hard-anodized finish for corrosion and scratch resistance . IPX-8 Waterproof (submersible up to 2 meters) . Impact resistant to 1.5 meters Specifications and Performance . LED: CREE S2 . Maximum output: 320 lumens . Maximum runtime: 36 hours . Battery: 2* CR123 . Reflector: Precision aluminum reflector . Dimensions: Diameter 23mm, length 123mm . Weight: 86g (without battery) Jetbeam BC40 - 2850 руб. ПРОДАН The Jetbeam BC-40 features the latest Cree X-LED, which puts out an amazing 830 lumens on high and 130 lumens on low mode. Run time up to 11 hours on low setting. Features . Premium Cree XM-L LED . Powered by 4*CR123 or 2*18650 batteries . Aero grade aluminium alloy construction . High performance reflector-based optic system . Fully regulated advanced power management . Reverse polarity protection circuit . 2 modes of output . AR coated scratch-resistant mineral glass lens . Type III hard-anodized finish for corrosion and scratch resistance . IPX-8 Waterproof (submersible up to 2 meters) . Impact resistant to 1.5 meters Specications and Performance . LED: CREE XM-L . Maximum output: 830 lumens . Maximum runtime: 11 hours . Battery: 4*CR123 or 2*18650 . Reflector: Precision aluminum reflector . Dimensions: Head Diameter 48mm, Tube Diameter 25.4mm, Total Length 223mm . Weight: 227g (without battery) Jetbeam RRT-2 - 4150 руб. Reflector - SMO CREE XPG R5 300 Lumen LED High Mode Using 2*CR123A batteries: 300 Lumens, 2 Hours Using 2*RCR123 Li-ion batteries: 300 Lumens, 1 Hour Using 1*18650 Li-ion battery: 300 Lumens, 3 Hours Mid Mode Using 2*CR123A batteries: 125 Lumens, 6 Hours Using 2*RCR123 Li-ion batteries: 125 Lumens, 3 Hours Using 1*18650 Li-ion battery: 125 Lumens, 8 Hours Low Mode Using 2*CR123 batteries: 38 Lumens, 20 Hours Using 2*RCR123 Li-ion batteries: 38 Lumens, 10 Hours Using 1*18650 Li-ion battery: 38 Lumens, 25 Hours Storbe Mode Using 2*CR123A batteries: 300 Lumens, 4 Hours Using 2*RCR123 Li-ion batteries: 300 Lumens, 2 Hour Using 1*18650 Li-ion battery: 300 Lumens, 6 Hours The batteries used for testing: CR123: Panasonic CR123A capacity 1350mAH RCR123 Li-ion: 3.7V 650mAH 18650 Li-ion: 3.7V 2600mAH Jetbeam JetIII Pro ST(BVC) - 3150 руб. Reflector - OP Model: JET-III PRO ST - Featuring I.B.S. User Interface LED: Cree XP-G (R5 bin) Max Output: 280 Lumen (Torch Lumen) Reflector: Aluminum OP Reflector Lens: Mineral Glass Metal Switch Retaining Ring Lock-out Function Material: T6061 T6 aircraft aluminum alloy Finish: HA III Military grade hard anodized Battery: Broad Voltage Circuit, which can use 2xCR123, 2xR123, or 1x18650 li-ion. (Batteries not included) Input voltage: 2.7 - 15V Switch: Reverse Clickie Modes: 3 programmable modes Waterproof: Accord to IPX-8 standard Dimension: Bezel diameter 25mm, Tail diameter 25mm, Overall length 120mm Weight: 65g(without battery) Output & Runtime: 18650 Rechargeable Lithium Battery Max Output: 280 Lumen, lasting for 1.5 hours High Output (Default Mode A): 200 Lumen, lasting for 2 hours and 15 min Low Output (Default Mode B): 20 Lumen, lasting for 21 hours Min Output: 2 Lumen, lasting for 150 hours Reverse polarity protected [Исправлено: Excalibur, 02.02.2012 в 21:36] |
Homo Lumarius
Регистрация: 28.04.2011 Последняя активность: 14.03.2016 22:04
Сказал(а) спасибо: 27
Такое ощущение, что фонари выгодней продавать, чем покупать
И rrt-0 нету ...
Фонарщик вконец офонарел Klarus Mi X6 rule!
Пусть по всем фонарям пересыл по России с меня будет ![]() Если у кого то появятся сомнения в личности продавца, дам ссылку на отзывы обо мне с Ганзы
Ухты, казань, прикольно.
Не один я офонаревший в этом городе
Шурик с шуриком
подскажите ba10 на акках работает АА?
а на 14500? |
Скажем так, производитель указывает использование только АА батарей.
И так же, если учитывать, что в фонаре скорее всего установлен повышающий драйвер, то использование АКБ 14500 скорее всего может убить электронику. Ну или фонарь будет работать в директдрайве
Добавил новинки и отредактировал цены:
Jet-III M (XM-L) - 3950 руб. новинка 450+ люмен OP reflector Jet I Pro w/IBS V3 - 2950 руб. SMO reflector Jetbeam RRT-2 - 4150 руб. Jetbeam JetIII Pro ST(BVC) - 3150 руб. Jetbeam BC40 - 2850 руб. Jetbeam BA10 - 1950 руб. Jetbeam BC10 - 1950 руб. Jetbeam BA20 - 1950 руб. Jetbeam BC20 S2 edition - 2250 руб. [Исправлено: Excalibur, 20.07.2011 в 17:00] |
Отличные цены, особенно учитывая бесплатную доставку.
В продаже)
Отписал в личку.
BC40 в резерве, остальное в продаже.
Регистрация: 05.02.2011 Последняя активность: 09.03.2014 21:44
Скажите работает ли BC10 на 16340 ?
rigin gsa
Регистрация: 17.01.2011 Последняя активность: 20.09.2014 10:38
я бы взял Jetbeam BC40 или Jetbeam JetIII Pro ST(BVC)
только подскажите какой лучше для бытового использования... |
17
Фонари в продаже
Отредактировал цены на серии BA\BC
BA10, BC10 - 1500 руб. BC20 - 1950 руб. Если есть интерес к другим моделям, цену также можно обсудить в личке
20
Приветствую.
Отписал в ПМ, но тут тоже продублирую. Фонарь очень нужен до субботы. |
