Просмотров в теме 4051   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 24.05.2011, 18:50 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Beamshoots from AAA Flashlights.
This article is part two of my AAA review, part one is here: A look at AAA flashlights..
Here are all the lights I have included, they are (Same sequence as picture): ARC-U, ARC AAA Ti, Killer AAA, Tiablo A1, Streamlight Microstream, LumaPower Avenger GX, Tank 007 TK-701, Leatherman S1, Leatherman S2, Fenix E01, Fenix L0D, Fenix LD01, Maglite Solitaire, Led Lenser P2, Led Lenser P3, LiteFLux LF2X, LiteFlux LF2XT, Peak Matterhorn #1, Peak Matterhorn #2, Peak Eiger, Peak Baltic.
ARC-U is a UV light, the normal version has a beam more like Fenix E01
The first two graphs show maximum brightness from the flashlights and there are large differences between the different lights. Some of the lights has different brightness, depending on the battery used and a diffuser will always reduce the brightness a bit. Note: Peak Eiger #8 has an extreme high brighness with LiIon, this is probably because it goes into direct drive and this high level will be very hard on the light and the battery.
Hre I have change to a log scale and added all brightness settings for multi level lights. LiteFlux has the best coverage, it goes both very low and very high (with LiIon batteries). For a more simple light, with a large range, the Avenger is good, but its maximum brightness is not as high as Fenix L0D/LD01, but they have a less adjustment range.
To get an idea about how far the lights can throw, I have measured the lux (at one meter), a high value equals a good throw. Note that the Led Lenser lights had the highest value when using wide focus!
Maximum brightness
LiteFLux LF2X NiMH, LiteFlux LF2X LiIon, LiteFlux LF2X LiIon + diffuser
LiteFlux LF2XT NiMH, LiteFlux LF2XT LiIon, Peak Matterhorn #1
Peak Matterhorn #2, Peak Eiger #2 NiMH, Peak Eiger #8 NiMH
Peak Eiger #8 LiIon, Peak Baltic
Lowest brightness, with increased exposure
Many of the lights has only one level and the picture used here is the same as above, just with increased exposure. For lights with multiple settings, I have chosen the picture from the lowest setting and again increased the exposure.
White wall beamshoot
These pictures are the 3 picture in the sequence from part one of the review and always of the brightest setting.
Maglite Solitaire, Led Lenser P2, Led Lenser P3, LiteFLux LF2X NiMH
LiteFLux LF2X LiIon, LiteFlux LF2XT NiMH, LiteFlux LF2XT LiIon, Peak Matterhorn #1
Peak Matterhorn #2, Peak Eiger #2 NiMH, Peak Eiger #2 LiIon, Peak Eiger #8 NiMH
ARC-U
This is an UV light and has not enough visible light to register.
ARC AAA Ti
Killer AAA
Tiablo A1
Low, medium, high:
Low
Medium
High
Tank 007 TK-701
Leatherman S1
Leatherman S2
Low, High:
Low:
High:
Fenix E01
Fenix L0D
Low, medium, high:
Low:
Medium:
High:
Fenix LD01
Low, medium high:
Low:
Medium:
High:
Maglite Solitaire
The light has adjustable focus, these two pictures show the focus change (The have increased exposure):
Tight focus:
Led Lenser P2
Wide focus
Tight focus
Led Lenser P3
Wide focus:
Tight fokus:
LiteFLux LF2X
The light can use both NiMH and LiIon batteries and has variable brightness, the light also includes a diffuser.
Low, high with NiMH:
Low, high with NiMH and diffuser:
Low, high with LiIon:
Low, high with LiIon and diffuser
Low, high with NiMH, increased exposure:
Low, high with NiMH and diffuser, increased exposure:
Low, high with LiIon, increased exposure:
Low, high with LiIon and diffuser, increased exposure:
Low with NiMH
High with NiMH
Low with NiMH and diffuser
High with NiMH and diffuser
Low with LiIon
High with LiIon
Low with LiIon and diffuser
High with LiIon and diffuser
LiteFlux LF2XT
The light can use both NiMH and LiIon batteries and has variable brightness.
Low, high with NiMH, incresed exposure:
Low with NiMH
High with NiMH
Low with LiIon
High with LiIon
Peak Matterhorn #1
Without and with diffuser:
Without and with diffuser, increased exposure:
Without diffuser:
With diffuser:
Peak Matterhorn #2
Without diffuser:
With diffuser:
Peak Eiger
#2 with NiHM and LiIon
#8 with NiHM and LiIon
#2 with NiHM
#2 with LiIon
#8 with NiHM
#8 with LiIon
Peak Baltic
Without diffuser:
With diffuser
Время генерации страницы 0.16019 секунды с 15 запросами
