4256
Регистрация: 25.06.2010 Последняя активность: 24.06.2015 07:00
Поблагодарили: 24 раз(а) в 11 сообщениях
CatEye TL-LD600
Born : 2002 Weight : 59g Power source : 2AAA Burn time : 15 Hours Made in Japan ![]() CatEye TL-LD610 Born : 2007 Weight : 49g Power source : 2AAA Burn time : 30 Hours Made in China ![]() Smart RL-317R Born : 2006 Weight : 53g Power source : 2AAA Burn time : 30 Hours Made in Taiwan ![]() Who will be the winner ? ![]() Pattern test - shot behind white paper. Smart / 600 / 610 ![]() *. TL-LD1000 wasn't most powerfull CatEye blinkie ever. It is still day here so you will have to wait for a night shoots... ![]() Ok, first comparision shots... Distance 0,6 m, white paper A4, 1/60 sec. Smart / 600 / 610 ![]() So now first conclusions : - they have very similar light output in constant mode - there is no visible improvement in output between LD600 and LD610* - LD600 have the best focused beam from these three** * maybe they simply lowered the current to get longer burnt time 15 instead 15 hours and light output is the same. ** theoretically the smart should have the best focus (as a 1 led lamp) but after testing 4-5 of these they all have irregular beam pattern - probably there is some problem with optics positioning during production. Some night photos... distance 50m, time 1sec. HL-EL600 ![]() HL-EL610 ![]() RL-317R ![]() These are 640x480 cuts from 10MP photos - no resizing or any additional edition. And her are some head to head mov's :RL-317R vs HL-EL610 RL-317R vs HL-EL600 Final Conclusion Each of these lamps have highly directional light output - during ground test’s after moving about 5m side from direct line with lamp smart have the worst visibility. I wasn’t able to decide which one is the best - despite of weker result in long distance photo test for EL600 it was the most aye-catching lamp in the test (higher frequency in flashing mode). I think that they are very comparable and you can make a decision based on price and availability of these lamps in your location. ** UPDATE ** I’ve spend half an hour in darkroom with these three and luxmeter : EL-610 => 141,5 Lux EL-600 => 135,1 Lux RL-317R => 134,8 lux Distance : 100 cm, these are maximal measured values at this distance. |
