Просмотров в теме 2042   Ответов в теме 3   Подписчиков на тему 1   Добавили в закладки 0
Старый 14.06.2022, 14:45 Автор темы   1
Аватар для Acebeam Light
Последняя активность: Вчера 18:01
Сказал(а) спасибо: 12
Отправить сообщение для Acebeam Light с помощью MSN Отправить сообщение для Acebeam Light с помощью Yahoo Отправить сообщение для Acebeam Light с помощью Skype™
По умолчанию ACEBEAM New Release Nichia 519A E70MINI and SST-20 H50 2.0
Hello Everyone,
It is an honor to announce our newest members of the E70MINI and H50 2.0.
With the latest popular high-CRI Nichia 519A Neutral white (5000K) LED,including one rechargeable 18650 battery, you get 2000 lumens with a uniform and smooth big spot from a pocket EDC flashlight E70 MINI.
Introducing the H50 2.0 High Performance Outdoor USB-C Rechargeable Headlamp, this is a fantastic budget friendly headlamp with a robust feature-set.
What are you most excited about? Let us know below!
Learn more - https://www.acebeam.com/new...
sales@acebeam.com
www.acebeam.com
[Исправлено: Acebeam Light, 14.06.2022 в 14:56]
Acebeam Light вне форума   Ответить с цитированием Вверх
Старый 15.06.2022, 13:46 Автор темы   2
Acebeam Light
По умолчанию Re: ACEBEAM New Release Nichia 519A E70MINI and SST-20 H50 2.0
ACEBEAM New E70MINI Ultra-compact&powerful 3 x Nichia 519A EDC light for outdoors, working, commuting,etc. Diminutive and finely crafted combined with high performance make the E70 MINI ideal EDC Flashlight too!
✅ Utilizes 3 x the latest popular high CRI Nichia 519A LED for a maximum output up to 2000 lumens
✅ The high CRI>90 Nichia 519A LED produces a uniform and smooth spot with no artifacts, capability revealing every detail on objects
✅ Neutral white (5000K) uniform spot reducing chances of misdiagnose
✅ Powered by 1 x 18650 rechargeable battery with max long runtime 56 hours
✅ 5 Brightness levels and 2 special modes (Strobe and Ultra-Low) for various scenarios
✅ With a stainless steel clip can be attached to pockets
✅ Stylish double layers tube design for better grip and heat insulation
✅ Lockout mode and "double click to turn on" design prevents accidental activation
✅ Rating in accordance with IP68 (2 meters submersible)
Learn more:https://www.acebeam.com/e70...
sales@acebeam.com
[Исправлено: Acebeam Light, 15.06.2022 в 13:47]
Старый 15.06.2022, 14:11 Автор темы   3
Acebeam Light
ACEBEAM headlamp is the first choice by China Expedition.
Compact and lightweight New H50 2.0 headlamp equipped with floodlight,spotlight, or dual beam with a max output of 2,000lumens.141 meters long range coverage and 170° wide range flood light specially designed for industrial maintenance,caving rescuing,climbing and mountaineering.
✅ Utilizes 3 x Luminus SST-20 LED(High CRI>90,Neutral White 5000K)
✅ Equipped with the customized TIR optic lens, can reflect uniform and soft light
✅ 180° tilt angle for different illumination needs
✅ Including one 18650 high capacity Li-ion battery and compatible with 2 x CR123/16340 batteries
✅ Built-in the concealed USB-C charging port is effectively protected against the complex outdoor environment
✅ USB-C Rechargeable Approx. 2hours 30 min to fully charge
✅ One button interface controls 5 brightness levels, 3 light sources and 1 SOS special mode
✅ Highly efficient constant current circuit provides a stable output of up to 30 days
✅ The power indicator beneath the switch can indicate the remaining battery power
✅ Rating in accordance with IP68 (2 meters submersible),All-weather applicable
Learn more: https://www.acebeam.com/wid...
sales@acebeam.com
Старый 15.06.2022, 14:12 Автор темы   4
Acebeam Light
ACEBEAM New E70MINI Ultra-compact&powerful 3 x Nichia 519A EDC light for outdoors, working, commuting,etc. Don't worry stay out too late, the Acebeam lights will light your way home.
High performance makes extraordinary that is the new H50 2.0 Outdoor Rechargeable Headlamp that combines Spot-and Floodlight. 170° wide range vision specially designed for outdoor applications.
sales@acebeam.com
Время генерации страницы 0.10415 секунды с 15 запросами
