Просмотров в теме 4276   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 02.08.2021, 12:42 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of E-Stream ES18650-29MP 2900mAh (Green) 2021
Official specifications:
  • Capacity Nominal: 2900mAh
  • Capacity Minimum: 2750mAh
  • Nominal Voltage: 3.7V
  • Discharge cut-off voltage: 2.75
  • Maximum charge voltage: 4.2V
  • Intern impedance: <=28mOhm
  • Standard charge current: 1.425A
  • Standard charge cut-off current: 142.5mA
  • Maximum continuous charge current: 2.9A
  • Maximum pulse charge (<2s): 5.7A
  • Standard discharge current: 2.85A
  • Maximum continuous discharge current: 10A (With 60°C cut-off)
  • Maximum pulse (<1s) discharge current: 15A (With 60°C cut-off)
  • Cycle life: 1000 cycles to 80%
A 2900mAh LiIon battery with moderate current rating.
The two cells is fairly well matched and the cells can deliver the rated 10A
Conclusion
The batteries looks fine, they do not set any records in either capacity or current, but are more average.
Notes and links
The batteries was supplied by E-Stream for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
grasl (03.08.2021)
Время генерации страницы 0.07599 секунды с 15 запросами
