Просмотров в теме 3270   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 04.07.2021, 15:05 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Keeppower 21700 5000mAh P5150TC (White-Blue) 2020
Official specifications:
  • Voltage: 3.60V
  • Typical capacity: 5000mAh
  • Minimum Capacity: 4900mAh
  • Discharge cut-off voltage: 2.50V
  • Charge voltage: 4.20V +/- 0.05V
  • Standard charge current: 1300mA
  • Maximum constant discharge current: 8A
  • USB type-C charge socket.
This is a 21700 cell with build-in USB-C charger, the cell is a protected high capacity cell.
The two cells match just about perfect and can easily deliver the rated 8A.
The USB charging uses a switching regulator to keep the heat down, I measured about 10°C temperature increase at the front of the cell during charge.
The USB-C input do not follow any protocols, except signalling it needs power.
Conclusion
It is a good battery and the USB charging means it can share charger with a mobile phone, this is very practical when traveling or when having only a few LiIon batteries. Only caveat is that the battery is considerable longer than a standard 21700 cell.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
drsleep (06.07.2021), grasl (05.07.2021), m72 (04.07.2021), Сумской (13.07.2021)
Время генерации страницы 0.07525 секунды с 15 запросами
