Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 6880   Ответов в теме 2   Подписчиков на тему 2   Добавили в закладки 0
Старый 24.01.2021, 16:43 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Keeppower 18650 3200mAh P1832U (Blue-white) 2020
Official specifications:
  • Protected 18650 Li-ion Rechargeable Battery
  • Minimum Capacity: 3100mAh
  • Typical Capacity: 3200mAh
  • Normal Voltage: 3.6V
  • Standard Continuous Charging Current: 750mA (by USB), 1A (by li-ion battery charger)
  • Maximum Continuous Discharging Current: 8.0A
  • In Built Safety Circuitry
  • Protection Circuit (Against over charge, over discharge, over current and short-circuit.)
  • Charge voltage: 4.20V maximum voltage and 2.50V cut-off voltage (by li-ion battery charger), 5.0V (by USB)
  • Over 500 charge-discharge cycles
A fairly high capacity protected 18650 that can be charged from USB.
The battery box includes a dual USB charge cable.
The two cells tracks very nicely and can also deliver the rated 8A, the protection triggers at about 15A.
Conclusion
A good protected battery with decent capacity, the USB charging can be useful on the go or if you only have a few 18650 batteries.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
dr oleg (25.01.2021), grasl (24.09.2021), m72 (24.01.2021), rpdoctor (24.01.2021), vorsmann (23.09.2021), Сумской (25.01.2021)
Старый 22.09.2021, 17:39   2
Последняя активность: Сегодня 14:05
Сказал(а) спасибо: 17550
Поблагодарили: 39487 раз(а) в 14614 сообщениях
По умолчанию Re: Test/review of Keeppower 18650 3200mAh P1832U (Blue-white) 2020
HKJ, I think this table is inserted by mistake:
It is duplicated with this one:
from this review:
https://lygte-info.dk/revie...
Старый 29.09.2021, 11:04 Автор темы   3
HKJ
Аватар для HKJ
Fixed.
Note: I do not have notification from this website, this means it will take some time before I notice posts.
fnksb (29.09.2021)
Время генерации страницы 0.13772 секунды с 15 запросами
