66588
210
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Part 2
Start topic here ------------------------------------------------------------- Original Innokin Sceptre 1400mAh Pod System Mod Vape Starter Kit $18.99 The Original Innokin Sceptre pod system vape starter kit is a 1400mAh built in battery device suited for new vapers looking for a small yet compact device. With two coils to choose from, a 1.2ohm for MTL Vaping and a 0.5ohm RDL Coil for high wattages, the Sceptre can easily identify between the two and automatically adjust your settings for the ultimate vaping experience. With an auto draw and button operation the Sceptre also features Boost Mode which can create more heat and vapor. ![]() Never Normal Whistle V2 510 Drip Tip + Button + Small Button Clone for dotMod dotAIO Pod $14.99 The Never Normal Whistle V2 Style 510 Drip Tip + Button + Small Button Set is made from PMMA and is suitable for dotMod dotAIO Pod System. ![]() Original Asvape Hita 30W Kit / Hita Ink Kit Replacement Mesh Coil Head $9.99 The Original Asvape Hita Replacement Mesh Coil Head is especially designed for Asvape Hita Hita 30W Kit / Hita Ink Kit / Pod Cartridge. It features 1.2ohm coil resistance. 5 PCS / PACK ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement 510 Drip Tip $9.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement 510 Drip Tip is made of PEI, suitable for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Air Intake Pins - 1.4mm $5.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement air intake pins is made of 316 Stainless Steel and KFM in 1.4mm diameter, bringing you to reach ideal draw experience. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. 2 PCS / PACK ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Air Intake Pins - 1.6mm $5.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement air intake pins is made of 316 Stainless Steel and KFM in 1.6mm diameter, bringing you to reach ideal draw experience. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. 2 PCS / PACK ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - Black 4.0mL $7.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 4.0ml e-juice capacity, made of PC. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - Black 2.0mL $7.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 2.0ml e-juice capacity, made of PC. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - PEI, 4.0ml $10.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 4.0ml e-juice capacity, made of PEI. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - PEI, 2.0ml $10.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 2.0ml e-juice capacity, made of PEI. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer
[Исправлено: AVSel, 06.01.2021 в 17:40] |
Original BP Mods Bushido V3 RDA 22mm Dripping Atomizer w/ BF Pin $39.99
BP Mods Bushido V3 RDA is constructed from durable stainless steel in 22mm diameter. It features deep juice wells, hinged flip top cap, and single coil configuration for delicious flavored vapor. Dripping by flipping top cap is super easy to operate. In addition, it adopts innovative shape airflow system and the structure of the atomizing room, bringing you great flavor and excellent vaping experience. ![]() SXK ReLoad S RDA Clone Rebuildable Dripping Vape Atomizer w/ BF Pin $20.9 SXK ReLoad S Clone RDA features a build-friendly postless quad terminal Clone build deck design, made of 316 stainless steel in 24mm diameter. It comes with dual adjustable top-down air flow to hit both sides and bottom simultaneously for maximize flavors and minimize leaking. With 3 pieces of top cap design, Airflow is easy for adjustment. ![]() Original Steam Crave Aromamizer Titan V1.5 VV Box Mod + Titan V2 RDTA Combo Kit Original Price $169.9, Now Only $130.99. The Original Steam Crave Aromamizer Titan Combo Kit includes Steam Crave Titan PWM V1.5 300W VV Vape Box Mod and Steam Crave Aromamizer Titan V2 RDTA ![]() Original Steam Crave Aromamizer Titan V2 RDTA Atomizer Replacement Postless Deck $19.99 Steam Crave Aromamizer Titan V2 RDTA Atomizer Replacement Postless Deck is innovative to build paralle and serial coils. It is especially designed for Steam Crave Aromamizer Titan V2 RDTA Rebuildable Dripping Tank Vape Atomizer. 1 PC / Pack ![]() Original Steam Crave Aromamizer Titan V2 RDTA Atomizer Replacement Tank Tube - Transparent, 32ml, Glass (2 PCS) $4.99 The Steam Crave Aromamizer Titan V2 RDTA Replacement Tank Tubes holds 32ml capacity, made of Glass. It is especially designed for Steam Crave Aromamizer Titan V2 RDTA Rebuildable Dripping Tank Vape Atomizer. 2 PCS / Pack (32ml) ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - Transparent, Glass, 4.0ml $2.89 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 4.0ml e-juice capacity, made of Glass. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - Transparent, Glass, 2.0ml $2.89 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 2.0ml e-juice capacity, made of Glass. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - Translucent Black, Glass, 4.0ml $2.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 4.0ml e-juice capacity, made of Glass. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. ![]() Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - Translucent Black, Glass, 2.0ml $2.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 2.0ml e-juice capacity, made of Glass. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer.
Original Vandy Vape Berserker Mini V2 MTL RTA Original Price $39.99, Now Only $28.99.
Original Vandy Vape Berserker Mini V2 MTL RTA is the upgrade mini version of Berserker V2 MTL RTA.Vandy Vape Berserker Mini V2 MTL RTA has a reduced adaption diameter, a newly increased replacement metal tube and a comprehensive airflow plug-in, and a simple coil installation method to enjoy the real MTL experience. With a diameter of 22mm, it is very compact, so it looks great on various current battery mods. Berserker Mini V2 MTL RTA has three tank tubes with two different capacities. The pre-installed glass tube and spare PEI tube have a capacity of 2.0ml. In addition, Berserker Mini V2 MTL RTA also adds a metal tube based on the original Berserker V2 MTL RTA replacement tubes, and the capacity is increased to 2.5ml. The Berserker Mini V2 RTA can be top filled through the threaded top cap's dual fill ports. You could rotate the top fill ring to open and close the filling hole to prevent any accidental opening or leaking. ![]() Original MECHLYFE x Fallout Vape XRP RTA Advanced Kit Original Price $43.99, Now Only $39.9. MECHLYFE x Fallout Vape XRP RTA comes with 24mm diameter and 3.5ml capacity. MECHLYFE x Fallout Vape XRP RTA features single coil and five inner adjustable airflow holes on the single coil deck (1.0mm, 1.2mm, 1.4mm, 1.6mm, 1.8mm). MECHLYFE XRP RTA is with adjustable MTL & DTL airflow ring, 510 MTL drip tip and 510 DTL drip tip for MTL & DTL vaping. ![]() Original Mechlyfe x Fallout Vape x Mrjustright1 Paramour SBS Mod Original Price $79, Now Only $75. The Original Mechlyfe x Fallout Vape x Mrjustright1 Paramour SBS Mod (side-by-side mod), made of 304 Stainless steel & aluminum, is powered by 1 x 18650 / 20700 / 21700 battery (not included) with max 80W output. Mechlyfe Paramour SBS Mod is equipped with OLED screen and provides VW / TC (Ni, Ti and SS) / Bypass modes to meet different needs. Paramour SBS Mod can match with up to 25mm atomizers. The mod is with USB Type-C port for fast charge. ![]() Original Mechlyfe x Fallout Vape x Mrjustright1 Paramour SBS Mod + XRP RTA Advanced Kit $119 The Mechlyfe x Fallout Vape x Mrjustright1 Paramour SBS Mod + XRP RTA Advanced Kit ![]() Replacement Front + Back Door Panel Plates w/ Black Button for dotMod dotAIO $40.99 The Replacement Front and Back Door Panel Plates is made from Acrylic and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included). It comes with a black button for easy operation. ![]() Original MECHLYFE x Fallout Vape XRP RTA Basic Kit MTL Edition Original Price $32.99, Now Only $29.9. Original MECHLYFE x Fallout Vape XRP RTA Basic Kit. MECHLYFE x Fallout Vape XRP RTA comes with 24mm diameter and 3.5ml capacity. MECHLYFE x Fallout Vape XRP RTA features single coil and five inner adjustable airflow holes on the single coil deck (1.0mm, 1.2mm, 1.4mm, 1.6mm, 1.8mm). MECHLYFE XRP RTA is with adjustable MTL & DTL airflow ring, 510 MTL drip tip and 510 DTL drip tip for MTL & DTL vaping. ![]() Original Mechlyfe x Fallout Vape x Mrjustright1 Paramour SBS Mod + XRP RTA Basic Kit $99 The Mechlyfe x Fallout Vape x Mrjustright1 Paramour SBS Mod + XRP RTA Basic Kit ![]() Original MECHLYFE x Fallout Vape XRP RTA Replacement PNP Bridge $9.99 Original MECHLYFE x Fallout Vape XRP RTA Replacement PNP Bridge is perfect for Voopoo PNP coil (coils not included). With this PNP Bridge adapter, you can use Voopoo PNP coils in MECHLYFE x Fallout Vape XRP RTA. ![]() Original MECHLYFE x Fallout Vape XRP RTA Replacement Dual Coil Deck $9.99 Original MECHLYFE x Fallout Vape XRP RTA Replacement Dual Coil Deck is especially designed for Mechlyfe x Fallout Vape XRP RTA for dual coil building ![]() Original MECHLYFE x Fallout Vape XRP RTA Replacement 510 DL / MTL Drip Tip $5.99 Original MECHLYFE Replacement 510 Drip Tips includes a 510 MTL Drip Tip and a 510 DL Drip Tip, suitable for MECHLYFE x Fallout Vape XRP RTA.2 PCS / Pack ![]() Original Vapefly Optima 80W Pod Mod Kit Replacement RDTA Pod Cartridge $14.99 The Vapefly Optima RDTA Pod Cartridge holds 4.0ml e-juice capacity, designed especially for the Vapefly Optima 80W Pod Mod Kit. ![]() Original Vapefly Optima 80W Pod Mod Kit Replacement RMC Pod Cartridge $3.99 The Vapefly Optima RMC Pod Cartridge holds 3.5ml e-juice capacity, designed especially for the Vapefly Optima 80W Pod Mod Kit. ![]() Original Vapefly Optima RDTA Pod Cartridge Replacement SS Ropes Guide Wick $2.99 Original Vapefly Optima RDTA Replacement Ropes Guide Wick is especially designed for Vapefly Optima RDTA Pod Cartridg. 4 PCS / Pack ![]() Original Vapefly Optima 80W Pod Mod Kit Replacement Mesh Coil Head $9.99 Vapefly Optima Replacement Mesh Coil Head is with 0.6ohm resistance, especially designed for Vapefly Optima 80W Pod Mod Kit and Vapefly Optima Normal Pod Cartridge. 5 PCS / Pack. With fresh and pure taste, The brand new FreeCore coil with optimized mesh structure ensures pure and fresh taste for each puff. ![]() Original Vapefly Optima 80W Pod Mod Kit Replacement RMC Coil Head $2.99 Vapefly Optima Pod Replacement RMC Coil is especially designed for Vapefly Optima 80W RMC Pod Cartridge. 1 PC / Pack ![]() Original Vapefly Optima RDTA Pod Cartridge Replacement M2 Mesh Wire $2.99 The Original Vapefly Optima RDTA M3 Mesh Wire is made of Ni80 with 0.3ohm resistance. It is especially designed for Vapefly Optima RDTA Pod Cartridge. ![]() Original Vapefly Optima 80W Pod Mod Kit Replacement RMC Prebuilt Wire + Cotton $3.99 The Optima RMC Wire and Cotton kit consists of 10 PCS RMC Wire and 10 PCS Cotton. The Optima RMC Wire and Cotton kit is designed especially for the Vapefly Optima RMC Pod Cartridge. ![]() Original Vapefly Optima 80W Pod Mod Kit Replacement RMC Coil + Coil Jig $3.99 Original Vapefly Optima RMC Coil + Coil Jig kit includes a RMC Coil and a Coil Jig. It is especially designed for Vapefly Optima 80W RMC Pod Cartridge. ![]() Original Vandy Vape Berserker Mini V2 MTL RTA Replacement Tank Tube $1.99 Vandy Vape Berserker Mini V2 MTL RTA Rebuildable Tank Atomizer Replacement Tank Tube holds 2.0ml e-juice capacity, made of Glass. It is designed for Vandy Vape Berserker Mini V2 MTL RTA Rebuildable Tank Atomizer. 1 PC / Pack ![]() Original Steam Crave Aromamizer Titan V2 RDTA Replacement Tank Tube $4.99 The Steam Crave Aromamizer Titan V2 RDTA Replacement Tank Tubes holds 20.0ml capacity, made of Glass. It is especially designed for Steam Crave Aromamizer Titan V2 RDTA Rebuildable Dripping Tank Vape Atomizer. 2 PCS / Pack (20ml)
Original Eleaf iSolo Air 40W VW Pod Mod + GTL Mini 2.0ml Pod $37.99
Original Eleaf iSolo Air Pod Mod Kit includes a Eleaf iSolo Air 40W VW Pod Mod and a 2.0ML GTL Mini Pod Cartridge.Eleaf iSolo Air 40W VW Pod Mod is powered by a built-in 1500mAh battery with max 40W power range (1~40W) in VW mode, allowing you to fully control vapor production for a more individual experience. The inside chipset keeps the device running smoothly, consistently and precisely, while providing a plethora of safety features. Near the top of the Eleaf iSolo Air mod is an innovative airflow system, an adjustable double-slit airflow valve that allows you to control the air inlet of each vape. To change the airflow, simply push the small knob to the side to find the ideal setting for the ideal throat hit. On the control panel of the mod, you find the firing button, a vibrant display screen, up and down adjustment buttons, and a conveniently located USB Type-C charging port. ![]() Original SMOKTech SMOK IPX 80 80W Pod Mod Kit w/ 5.5ml RPM 2 Pod $29.99 SMOKTech SMOK IPX 80 IPX80 Pod Mod Kit consists of a SMOK IPX 80W VW Pod Mod and a 5.5ml RPM 2 Pod Cartridge.SMOK IPX 80W VW Pod Mod is powered by a built-in 3000mAh battery, providing a long-lasting vape experience with the power range of 1~80W in VW mode. SMOK IPX 80 Pod Mod kit is certified by IPX67, waterproof, dustproof and shockproof, making it truly one of the most durable kits on the market and ideal for those who travel with their vaping systems regularly. ![]() Original SMOKTech SMOK IPX80 80W Pod Mod Kit Replacement RPM Empty Pod Cartridge $6.99 Original SMOKTech SMOK IPX80 RPM Empty Pod Cartridge holds 5.5ml e-juice capacity with side filling system. It is designed especially for the Smok IPX80 80W Pod Mod Kit. The RPM Pod Cartridge is compatible with RPM Series coils (not included). 3 PCS / Pack ![]() Original SMOKTech SMOK IPX80 80W Pod Mod Kit Replacement RPM 2 Empty Pod Cartridge $6.99 Original SMOKTech SMOK IPX80 RPM 2 Pod Cartridge holds 5.5ml e-juice capacity with clear side filling system. It is designed especially for the Smok IPX80 80W Pod Mod Kit. The RPM 2 Pod Cartridge is compatible with RPM 2 Series coils (not included). 3 PCS / Pack ![]() Original 22mm Eleaf GTL Mini Pod Tank for iSolo Air Mod $10.99 Original Eleaf GTL Mini Pod Tank Atomizer holds 2.0ml e-juice capacity in 22mm diameter. It comes with 510 threading connection, fitting all the 510-threaded mod, especially perfect for Eleaf iSolo Air Mod. Eleaf GTL MINI Pod Tank applies dual sides airflow control, each side with one big and five tiny holes, ensuring free adjustments between maximum and extreme restricted air inflow. Compatible with GTL coils, like GTL 1.2ohm coil and GTL 0.8ohm coil (Included), it provides an excellent MTL vaping experience. In addition, with the magnetic connection, changing coils and filling e-juice is easier to operate.
Original Joyetech Evio C 800mAh Pod System Kit $19.74
Original Joyetech Evio C Pod System Vape Kit consists of a Joyetech Evio C 800mAh Pod Mod and a 2.0ml Pod Cartridge.Joyetech Evio C Pod Mod is powered by an 800mAh built-in battery with Type-C 2A charging for quickly fully charged in less than 30 minutes. It features dual vaping ways: Inhaling directly or pressing the button to vape. Equipped with one fire button with an LED indicator on the front, you can easily turn on and off the mod and check the battery level. ![]() Original Joyetech Evio C Pod System Kit Replacement Pod Catridge $4.99 Original Joyetech Evio C Pod Cartridge is a set of proprietary pods crafted for the Joyetech Evio C Pod System, feature a 2.0mL capacity, fast and simple filling process can be realized through side filling port. ![]() Original Joyetech Evio C Pod System / Pod Cartridge Replacement Mesh Coil Head $7.99 Original Joyetech Evio C Pod Replacement Mesh Coil Head is with 0.8ohm resistance, perfectly compatible with Joyetech Evio C Pod System Kit / Pod Cartridge. With innovative AST-Steel inside which is particularly resistant to corrosion and commonly used in medical field, it will heat faster than normal stainless steel and bring pure flavor. 5 PCS / Pack
Original ZQ Trio RTA Rebuildable Tank Vape Atomizer MTL / DL, 22.38mm $29.99
Original ZQ Trio RTA Rebuildable Tank Vape Atomizer holds 2.0ml e-juice capacity with top filling system in 22.38mm diameter. It features three independently adjustable airflow control rings, which enables you to customize your personal MTL or DTL vaping experience. In addition, with 13 airflow holes, it provides 143 airflow combinations to choose, bringing you an excellent vaping experience. It comes with single coil, a wide and excellent deck design making rebuilding a painless process. In 22mm diameter, Original ZQ Trio RTA is compatible with both larger and smaller Mods without any overhanging. ![]() Original SXK ETU Pre-built Coil Wire for RDA RTA Original Price $5.9, Now Only $5.5. Original SXK ETU Pre-built Tricked Coil, mult-choice available.
Original SXmini SX Nano Pod System Mod Kit / Atomizer Replacement SX ADA V2 Coil $7.99
Original SXmini SX Nano Pod Replacement SX ADA V2 Coil is with 0.6ohm, perfectly compatible with SXmini SX Nano Pod System Mod Kit / Atomizer. 5 PCS / Pack ![]() Original SXmini SX Nano Pod System Mod Kit Replacement SX ADA V2 Tank Atomizer $14.99 Original SXmini SX Nano SX ADA V2 Tank Atomizer has a 2.0ml reservoir capacity, compatible with the new SX ADA V2 coils available in 0.6 ohm resistance (Not included), this coil serie using a pre-built ceramic disc and coil assembly to reduce waste whilst maintaining the best flavor possible. It is perfectly suitable with SXmini SX Nano Pod System Vape Mod Kit. 2 PCS / Pack ![]() Original SXmini SX Nano Pod System 900mAh Vape Mod + 2.0ml SX ADA V2 Tank Atomizer Kit $58.99 Original SXmini SX Nano Pod System Vape Mod Kit consists of a SXmini SX Nano Pod System 900mAh Vape Mod and a 2.0ml SX ADA V2 Tank Atomizer. Original SXmini SX Nano Pod System Vape Mod is an all-in-one auto bottom-feeding vape Mod with automated temperature control. Powered by a 900mAh built-in battery, SXmini SX Nano Pod System Vape Mod supports the auto bottom-feeding (Auto-squonking) system and is easily controlled by the YiHi SX681J chipset with the YIHI ESS (Electronic Spray Squonk) Driver Technology. Similar to the SXmini SX AUto, the SX Nano has a slimmed-down feature set, ideal for every-day use. Original SXmini SX Nano SX ADA V2 Tank Atomizer has a 2.0ml reservoir capacity, compatible with the new SX ADA V2 coils available in 0.6 ohm resistance (0.6ohm coil included), this coil serie using a pre-built ceramic disc and coil assembly to reduce waste whilst maintaining the best flavor possible. ![]() Original Hellvape Vertex MTL RTA Rebuildable Tank Vape Atomizer 2.0ml / 3.5ml Original Price $36.22, Now Only $24.99. Original Hellvape Vertex MTL RTA Rebuildable Tank Atomizer holds 2.0ml / 3.5ml (Included in package) capacity with easy top filling system in 22mm diameter. Constructed of stainless steel, Hellvape Vertex RTA comes with single coil configuration, two posts side by side for easy single coil building. With adjustable 6 air holes (0.8mm, 1.0mm, 1.2mm, 1.4mm, 1.6mm, 5.8mm x 1.7mm), it offers most precise air inlet for MTL flavor. It adopts adjustable bottom airflow for large air inlet by the knurled grip.
Original Lost Vape Thelema DNA250C 200W VW TC Box Mod Original Price $199, Now Only $119.99.
Original Lost Vape Thelema DNA250C Box Mod is powered by 2 x 18650 batteries (not included), enough to provide a maximum power of 200W (1~200W). With the advanced Evolv DNA250C Chipset, it has access to VW, TC, and Bypass Modes, delivering satisfying performance to the user via tailored vapor output. Constructed from quality zinc-alloy, the THELEMA DNA250C Mod can utilize interchangeable battery chassis pieces to allow for customization of the visually striking exterior. With accurate temperature control system, the Thelema DNA250C Mod is able to prevent the coil becoming too hot and provide a much stable performance. ![]() ShenRay Vapor Giant VG V6S V6 S 2020 Clone RTA Rebuildable Tank Atomizer 5.5ml / 7.0ml $28.99 ShenRay Vapor Giant VG V6S 2020 Clone RTA is made of stainless steel in 23mm diameter. The VG V6 S Clone RTA comes with glass tank tube holds and 5.5ml capacity (pre-installed) and PEI tank tube holds 7.0ml capacity (in the package). The V6 S Clone RTA is with 360 degree removable tank tube. The VG V6 S Clone RTA is with top filling system and the liquid control. There are 9 holes in the deck and up to 6 of these 9 holes can be closed with infinitely adjustable Bottom Airflow. ![]() SXK DotMission Clone RBA Bridge for DotMod DotAIO AIO Pod 1.2 / 2.1 / 3.5mm Original Price $28.9, Now Only $26.9. SXK DotMission Clone RBA Bridge is especially designed for DotMod DotAIO AIO Pod. It supports side filling system and comes with Variable airflow controls (1.2mm, 2.1mm, 3.5mm). ![]() Original ULTRONER Alieno 70W TC VW Variable Wattage Vape Box Mod SEVO 70 Chipset Original Price $59.9, Now Only $45.99. The Original ULTRONER Alieno 70W TC VW Vape Box Mod is made from ABS and Stainless Steel. The Alieno box mod Powered by SEVO-70 chipset to supports max. 70W output. The Ergonomic design makes it more convenient to use and supports replacement battery tube (not included). The redesigned top cap adapts to 24mm atomizer. ![]() Original VOOPOO Argus GT 160W TC VW Variable Wattage Box Mod + PnP Pod Tank Vape Kit $43.99 The Original VOOPOO Argus GT vape Kit is composed of VOOPOO Argus GT Box Mod and PnP Pod Tank. The VOOPOO Argus GT finds inspiration for dynamism and lightness from racing bikes. Using the same zinc alloy and leather process as the racing bike, it's more aesthetically pleasing and 30% lighter than the usual Mod. Argus GT is powered by two external 18650 batteries (not included), in combination with the Type-C fast charging interface, offering you a longer vaping experience in a portable size. Argus GT has a high power output of up to 160W (5~160W). Besides, Argus GT built-in powerful GENE.TT chip that gives it a thick haze in an instant, has the powerful performance of fast ignition and high burst and also provides intelligent functions such as SMART and TC mode. TC mode supports the temperature adjustment of Nickel, Titanium, and Stainless Steel heating wire materials. Just press "+" and "-" at the same time to enter the page adjustment. VOOPOO Argus GT Kit comes with VOOPOO PNP Pod Tank. The tank can hold up to 4.5ml of your favorite electronic juice, and refill the juice from the bottom of the Pod by twisting 510 base. With the addition of a 510 base, PnP Pod Tank fits almost all your VOOPOO devices. PnP Pod Tank not only matches with a rich flavor of PnP coil but also has a PCTG material that is more drop-proof than glass in the outdoor. Argus GT is equipped with two dedicated coils. PnP-VM5 0.2ohm and PnP-VM6 0.15ohm, the strongest combination of the PnP series. Argus GT is compatible with all PnP coils including RBA, just pull and push, you can enjoy different vaping experience, fast and affordable. In addition, PNP Pod Tank has an innovative infinite airflow system. Turn 510 base for airflow adjustment ![]() SXK DotMISSION Clone RBA Bridge Replacement Tank Tube Original Price $4.9, Now Only $4.5. Replacement Tank Tube is especially designed for SXK DotMISSION Clone RBA Bridge. 1 PC / Pack ![]() SXK DotMISSION Clone RBA Bridge Replacement Domed Chamber Airway Original Price $9.9, Now Only $8.9. Replacement Domed Chamber Airway is especially designed for SXK DotMISSION Clone RBA Bridge. 1 PC / Pack ![]() Original Hellvape Vertex MTL RTA Replacement Tank Tube 2.0ml $1.99 Original Hellvape Vertex Replacement Glass Tank Tube holds 2.0ml, especially designed for Hellvape Vertex MTL RTA Rebuildable Tank Vape Atomizer. 1 PC / Pack ![]() Original Hellvape Vertex MTL RTA Replacement Tank Tube 3.5ml $2.59 Original Hellvape Vertex Replacement Glass Tank Tube holds 3.5ml, especially designed for Hellvape Vertex MTL RTA Rebuildable Tank Vape Atomizer. 1 PC / Pack
Original Wotofo Manik Mini 30W VW Pod System 1000mAh Kit Original Price $36, Now Only $20.99.
Original Wotofo Manik Mini Pod System Starter Kit consists of a Wotofo Manik Mini 30W VW Pod System Mod and a 3.0ml Manik Mini Pod Cartridge. Wotofo Manik Mini 30W VW Pod System Mod is powered by a 1000mAh built-in battery with the maximum power of 30W (1~30W). With 0.69 inch OLED Screen, it is easy for you to check the battery level and the statistic you need. It charges faster, lasts longer, and has a higher power density for more battery life in a lighter package. You can adjust the wattage with just one button to select between 1~30W. 0.001 seconds firing speed, various safety shutoffs and other common protection functionalities are all supported by NexCHIP safely Guarded by NexCHIP technology. Wotofo Manik Mini Pod Cartridge holds 3.0ml capacity with side filling system, made of PCTG. It comes with M12 nexMESH Coil (Pre-installed) and M11 Parallel Coil (Included), bringing you an excellent vaping experience. ![]() Original Voopoo Drag 3 177W VW Mod + TPP Tank Kit $47.99 Original Voopoo Drag 3 177W Mod Kit includes a Voopoo Drag 3 177W VW Mod and a TPP 5.5ml Tank Atomizer. Voopoo Drag 3 177W VW Mod is powered by 2 x 18650 batteries (not included) with the maximum power of 177W (5~177W). It features the newly upgraded GENE.FAN 2.0 chip, which provides stronger explosive power, more stable output and richer intelligent functions than the previous generation. DRAG 3 Mod supports the easy-to-use SMART mode for beginners and the power-free RBA mode desired by professional players. When adjusted to 80W in RBA Mode, Drag 3 Mod will automatically turn on SUPER Mode, the maximum power up to 177W. With precise temperature control mode, it is playable to the maximum, allowing you to enjoy and play whatever you want. It is able to work in Super / Smart / TC / RBA mode, brings an excellent vaping experience. TPP Tank Atomizer holds 5.5ml e-juice capacity with bottom filling system. With powerful magnet connection, it is easy for you to fill oil. ![]() Original Voopoo Drag 3 177W VW Box Mod $37.99 Voopoo Drag 3 Mod is powered by 2 x 18650 batteries (not included) with the maximum power of 177W (5~177W). It features the newly upgraded GENE.FAN 2.0 chip, which provides stronger explosive power, more stable output and richer intelligent functions than the previous generation. DRAG 3 Mod supports the easy-to-use SMART mode for beginners and the power-free RBA mode desired by professional players. When adjusted to 80W in RBA Mode, Drag 3 Mod will automatically turn on SUPER Mode, the maximum power up to 177W. With precise temperature control mode, it is playable to the maximum, allowing you to enjoy and play whatever you want. It is able to work in Super / Smart / TC / RBA mode, brings an excellent vaping experience. ![]() Original Advken Mad Hatter RTA Rebuildable Tank Vape Atomizer $22.68 Original Advken Mad Hatter RTA Rebuildable Tank Atomizer holds 2.0ml e-juice capacity with easy top filling system in 24mm diameter. Advken Mad Hatter RTA stands out with its flavor performance and compact size. Mad Hatter RTA is a 24mm diameter single-coil RTA, made of high-quality stainless steel and heat-resistant glass. The top cap and bottom airflow ring are equipped with a novel knurled design. The top is a large 810 POM drip tip that's highly heat resistant and the airflow is very smooth delivery to the lungs. Mad Hatter RTA is outfitted with a single coil postless build deck, making coil installations and adjustments easily and quickly. One side of the deck has a column wall with 10 airflow holes, and the airflow through the coil from the side. while outputting delicious vapor from the single-coil fueled by a slotted bottom airflow control ring, ventilating the single-coil structure in large angle coverage. Rotate the bottom air ring to adjust to a satisfactory throat hit. ![]() KF Lite Plus 2021 Clone RTA Rebuildable Tank Vape Atomizer $14.99 KF Lite Plus 2021 Clone RTA Rebuildable Tank Atomizer consists of a tank, top cap and a MTL drip tip. It holds a 4ml e-juice capacity with a bottom filling system. ![]() Original Voopoo TPP Tank Atomizer $12.99 Original Voopoo TPP Tank Atomizer holds 5.5ml e-juice capacity, designed with reference to "Aerodynamic Simulation" and a new "Two-way Convection" airway structure to maximize the overall atomization efficiency. It comes with TPP-DM1 0.15ohm coil and TPP-DM2 0.2ohm coil, providing an excellent vaping experience. ![]() Original Voopoo TPP Replacement TPP-DM1 Coil for Drag 3 Kit / TPP Tank Atomizer 0.15ohm $12.99 Original Voopoo TPP Replacement TPP-DM1 Coil is with 0.15ohm resistance (suggested wattage: 60~80W), perfectly compatible with Drag 3 Kit / TPP Tank Atomizer. It features higher atomizer efficiency, faster heat-up, more delicate flavor, delivering you an amazing vaping experience. 5 PCS / Pack ![]() Original Voopoo TPP Replacement TPP-DM2 Coil for Drag 3 Kit / TPP Tank Atomizer 0.2ohm $12.99 Original Voopoo TPP Replacement TPP-DM2 Coil is with 0.2ohm resistance (suggested wattage: 40~60W), perfectly compatible with Drag 3 Kit / TPP Tank Atomizer. It features higher atomizer efficiency, faster heat-up, more delicate flavor, delivering you an amazing vaping experience. 5 PCS / Pack ![]() Original Wotofo Manik Mini Pod System Kit Replacement Mini Pod Cartridge w/ M12 nexMESH Coil 0.6ohm $7.99 Original Wotofo Manik Mini Pod Cartridge with M12 nexMESH Coil 0.6ohm (Included) holds 3.0ml capacity, designed especially for the Wotofo Manik Mini Pod System Kit. 3 PCS / Pack ![]() Original Wotofo Manik Mini Pod System Kit Replacement Mini Pod Cartridge w/ M11 Parallel Coil 0.6ohm $7.99 Original Wotofo Manik Mini Pod Cartridge with M11 Parallel Coil 0.6ohm (Included) holds 3.0ml capacity, designed especially for the Wotofo Manik Mini Pod System Kit. 3 PCS / Pack ![]() Original Innokin Kroma Z 510 Adapter Connector for Kroma Z Pod System Kit $4.99 Innokin Kroma Z 510 Adapter Connector is suitable for Innokin Kroma Z Pod System Kit, compatible with Zenith / Zenith Pro / Zlide Tank and other 510 atomizers. It can switch your Innokin Kroma Z Pod Sysrtem into a normal 510 thread box mod to use different atomizers as you like. Beside, with it, / Zenith / Zenith Pro / Zlide Tank can be used on any mod with 510 threading connection. 1 PC / Pack ![]() Original YIHI T Class 200W TC VW Vape Box Mod YiHi SX580J Chipset Original Price $189.99, Now Only $50.99. The Original YiHi SXmini T Class SX580J 200W Vape Box Mod is constructed for a stunning 78 components cohesively built together to form a formidable structure. The luxurious design implements an intuitive joystick adjustment control with the addition of a joystick spinner for more dynamic operational control. The internal SX580J Chipset provides tremendous output range of 5 to 200W alongside a suite of functionality such as full temperature control support, Bluetooth support, and efficient processor for accurate and customizable experience. The inclusion of SXi-Q Intelligent Taste Curve Technology features an algorithmic calculation that allows users to set, fine tune, and save 5-memory output curves. The YiHi SX580J is also capable of Bluetooth connectivity and adjustment, allowing users to set and adjust the SXmini T Class from compatible phones. Three colors for your choice: Black Shadow, Captain Golden, Captain. ![]() Original Voopoo Drag X Plus 100W VW Variable Wattage Pod Mod GENE.FAN 2.0 Chip $32.99 Original Voopoo Drag X Plus 100W VW Pod Mod is powered by 1 x 21700 / 18650 battery (not included), enough to provide a maximum power of 100W (5~100W), with Type-C 5V / 2A fast charging port for a long lasting vaping experience. Supported by the upgraded advanced GENE.FAN 2.0 Chipset, it brings a maximum output of 100W, 0.001s extreme ignition and has access to multiple output modes. The newly upgraded GENE.FAN 2.0 chip has stronger explosive power, more stable output, and more intelligent functions than the previous generation. With the maximum output power of 100W, the Drag X Plus Mod enables you to create a larger flavor cloud and meet your different needs within a large range of adjustable power. With SMART Mode, it can identify the installed coil and match it with the best power. RBA Mode allows you to break through the power limit and feel powerful. The vibrant 0.96" full-color TFT screen clearly displays vaping data and comes with two different styles of theme switching. Five different colors for your choice: Classic, Marsala, Prussian Blue, Sandy Brown, Smoky Grey. ![]() Original Voopoo Drag X Plus 100W VW Pod Mod + TPP Tank Kit GENE.FAN 2.0 Chip $41.99 Original Voopoo Drag X Plus Pod Mod Kit consists of a Voopoo Drag X Plus 100W VW Pod Mod and a 5.5ml TPP Tank Atomizer. Voopoo Drag X Plus 100W VW Pod Mod is powered by 1 x 21700 / 18650 battery (not included), enough to provide a maximum power of 100W (5~100W), with Type-C 5V / 2A fast charging port for a long lasting vaping experience. Supported by the upgraded advanced GENE.FAN 2.0 Chipset, it brings a maximum output of 100W, 0.001s extreme ignition and has access to multiple output modes. The newly upgraded GENE.FAN 2.0 chip has stronger explosive power, more stable output, and more intelligent functions than the previous generation. With the maximum output power of 100W, the Drag X Plus Mod enables you to create a larger flavor cloud and meet your different needs within a large range of adjustable power. With SMART Mode, it can identify the installed coil and match it with the best power. RBA Mode allows you to break through the power limit and feel powerful. The vibrant 0.96" full-color TFT screen clearly displays vaping data and comes with two different styles of theme switching. TPP Tank Atomizer holds 5.5ml e-juice capacity with bottom filling system, made of PCTG. With 510 threading connection, it allows you to use on any mod with 510 threading connection. It is compatible with all the TPP coils, like TPP-DM1 0.15ohm and 1 x TPP-DM2 0.2ohm (include), bringing you an excellent vaping experience. Adjustable airflow can be altered by sliding the sleek side lever, giving users even more versatility over their vaping style. With powerful magnet connection, it is easier for you to fill oil. Five different colors for your choice: Classic, Marsala, Prussian Blue, Sandy Brown, Smoky Grey. ![]() Original ZQ Xtal 520mAh Pod System Vape Starter Kit $18.99 Original ZQ Xtal pod system is an innovative product, featuring its outstanding taste. Its unique Smart Airflow system lets you enjoy a velvety, smooth-as-silk satisfaction that can beat any kind of cigarettes. It combined Aspire's professional coil testing technology and the extraordinary integration of coil resistance, vapor, temperature, which brings you an Original taste of your favorite e-liquid. Five different colors for your choice: Blue Pink, Teal, Red, Gun Metal, Black. ![]() Original Nitecore UI2 USB Charger for 18350, 18490, 18500, 18650, 20700, 21700, 22500, 22650, 25500, 26500, 26650 $11.99 Original Nitecore UI2 USB Charger provides single slot Max charging current of 1000mA, available for low current charging below 2.9V for protecting the batteries and maximizing the battery cycle durability. It is compatible for 3.6V / 3.7V rechargeable Li-ion batteries, like the large-sized 20700 / 21700 batteries. It comes with intelligent charging mode selection: CC and CV. With the Micro-USB Port for Outdoor Charging, it is compatible with various mobile power source, solar panel and USB adaptors to ensure endless power supply. Equipped with explicit and simple Power Indicators, you can easily check real-time display of battery level and charging status. The Nitecore UI2 USB Charger is compatible with: Li-ion/IMR: 10340, 10350, 10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14430, 14500, 14650, 16500, 16340 (RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500, 18650, 20700, 21700, 22500, 22650, 25500, 26500, 26650. ![]() Original Innokin EQs Replacement Pod Cartridge $4.99 The Innokin EQs Replacement Pod Cartridge has 2ml of juice capacity and 0.48ohm coil and is suitable for Innokin EQs Pod System Starter Kit. 1 PC / Pack
Original Vandy Vape Gaur-21 200W Dual 21700 Vape Box Mod Original Price $69.99, Now Only $51.99.
Vandy Vape Gaur-21 Mod is powered by dual 21700 or 18650 batteries (batteries not included) because two 18650 battery adapters are provided. Charging through the USB Type-C port, the current is 1.8A. Gaur-21 Mod can accommodate 30mm atomizers at the top 510 connector without overhanging. The Vandy Vape Gaur-21 Box Mod is integrated with a smart Vandy chipset with various output modes, such as POWER, Voltage, Temperature Control, with a power output range of 5W to 200W. In addition, the chipset unlocks an extensive temperature control suite, offering plenty of adjustment for advanced users, accommodating nickel, titanium, and stainless steel wire compatibility. Vandy Vape Gaur-21 Mod supports firmware upgrade. Configure innovative positioning function, no need to worry about device loss. Under blue tooth connection, the device can be easily detected by using the retrieval function on Vandyvape App. Eight colors in total for your choice. ![]() Original Famovape Magma AIO 40W 900mAh Pod System Starter Kit $29.99 Original Famovape Magma AIO 40W Pod System Starter Kit included a Famovape Magma AIO 40W Pod System Mod and a 2.0ml Pod Cartridge. Famovape Magma AIO 40W Pod System Mod is powered by a 900mAh built-in battery, enough to provide a maximum power of 40W (5~40W). Equipped with 0.69 inch OLED screen, vaping data can be checked clearly. Famovape Magma AIO Pod Cartridge holds 2.0ml e-juice capacity with side filling system. With external air conditioning, it is easy for you to use. It supports two coils: 0.4ohm / 1.2ohm, bringing you an excellent MTL or DTL vaping experience. Six colors in total for your choice. ![]() Original ZQ Xtal Vape Pod System Replacement Pod Cartridge 1.0ohm $9.99 This Pod cartridge was especially design for ZQ Xtal Pod with 1.8ml e-juice capacity. It combined Aspire's professional coil testing technology and the extraordinary integration of coil resistance, vapor, temperature. It comes with 1.0ohm coil, brings an excellent vaping experience. Another pod cartridge with 1.2ohm coil for your choice. 4 PCS / Pack ![]() Original Famovape Magma AIO Kit Replacement Pod Cartridge $4.99 Original Famovape Magma AIO Pod Cartridge holds 2.0ml e-juice capacity with side filling system. It is especially designed for Famovape Magma AIO Kit. With external air conditioning, it is easy for you to use. It brings you an excellent MTL or DTL vaping experience, depend on the coil you use (coil not included). 2 PCS / Pack ![]() Original Famovape Magma AIO Pod Kit / Pod Cartridge Replacement Coil $9.99 Original Magma AIO Replacement Coil is is suitable for Famovape Magma AIO Pod Kit / Pod Cartridge. There are two kinds of resistance for your choice: 1.2ohm / 0.4ohm. 5 PCS / Pack ![]() Original Suorin Air Pro 18W 930mAh Pod System Starter Kit $25.99 Original Suorin Air Pro 18W Pod System Starter Kit includes a Suorin Air Pro 18W 930mAh Pod System Mod and a 4.9ml Pod Cartridge. Suorin Air Pro 18W 930mAh Pod System Mod is powered by a 930mAh built-in battery with 18W output power available in USB charging and pogo charging (Coming soon). Except for the auto-draw mode, Suorin Air Pro Mod is designed with a more sensitive button-draw mode, bringing you a stable experience. Suorin Air Pro Pod Cartridge holds 4.9ml e-juice capacity with bottom filling system, made of PCTG. It adopts LAVAL nozeel airway design which takes away more heat by speeding up the airflow. It features bottom filling system and built-in coil which brings you original and pure taste. 11 colors in total for your choice. ![]() Original Suorin Air Pro 930mAh Pod System Kit Replacement Pod Cartridge 1.0ohm $4.99 Original Suorin Air Pro Pod Cartridge is especially designed for Original Suorin Air Pro 18W 930mAh Pod System Kit, made of PCTG. It holds 4.9ml e-juice capacity with bottom filling system and built-in coil which brings you original and pure taste. It adopts LAVAL nozeel airway design which takes away more heat by speeding up the airflow. 1 PC / Pack ![]() Original Auguse CG108P CG Pro 510 Drip Tip w/ 5 x Plugs for RTA / RDA /RDTA Vape Atomizer $4.99 Original Auguse CG108P CG Pro 510 Drip Tip Kit consists of a Stainless Steel Base, 3 PEI Mouthpieces with different height and 5 PEEK Plugs with different size: 1.0mm, 1.5mm, 2.0mm, 2.5mm and 3.5mm. It is suitable for RTA / RDA / RDTA Vape Atomizer. This 510 drip tip serie: Mouthpiece in Yellow, White and Black, Base in Gunmetal, Silver and Black, Totally Nine combination for your choice.
Original Eleaf iStick Pico 2 75W VW Box Mod + GZeno S Tank Standard Version Kit $50.52
Original Eleaf iStick Pico 2 75W Standard Version Mod Kit consists of a Eleaf iStick Pico 2 75W Box Mod and a 4.0ml GZeno S Sub Ohm Tank Atomizer. Eleaf iStick Pico 2 75W Mod is powered by 1 x 18650 battery (not included) with USB Type C cable at a 2A charging rate, enough to provide a maximum power of 75W (1~75W) and a long lasting vaping experience. Equipped with the OLED screen, the mod supports two different user modes: Power mode and Smart mode. Power mode gives you full variable wattage adjustment while in Smart Mode, the Mod sets the mod output according to the coil resistance. The 510 connector on the side makes it compatible with tanks with a maximum diameter of 27mm without overhang. Eleaf GZeno S Sub Ohm Tank Atomizer Standard Version holds 4.0ml e-juice capacity with convenient top filling system and easy coil replacement in 24.5mm diameter. It features adjustable bottom airflow ring and leak-proof design to adjust the airflow you want and find the ideal throat hit. GZeno S Tank is compatible with GZ Coils like GZ 0.8ohm Coil (for MTL) and GZ 0.4ohm Coil (for Half-DL) are included. Three colors for your choice: Silver, Matte Gunmetal, Rose Gold. ![]() Original Eleaf iStick Pico 2 75W VW Variable Wattage Box Mod $32.81 Original Eleaf iStick Pico 2 75W Mod is powered by 1 x 18650 battery (not included) with USB Type C cable at a 2A charging rate, enough to provide a maximum power of 75W (1~75W) and a long lasting vaping experience. Equipped with the OLED screen, the mod supports two different user modes: Power mode and Smart mode. Power mode gives you full variable wattage adjustment while in Smart Mode, the Mod sets the mod output according to the coil resistance. The 510 connector on the side makes it compatible with tanks with a maximum diameter of 27mm without overhang. Operate in a classic way by using the ergonomic fire button and the adjustment buttons at the bottom. Three colors for your choice: Silver, Matte Gunmetal, Rose Gold. ![]() Original Eleaf Gzeno S Sub Ohm Tank Atomizer Standard Version 4.0ml $25.99 Original Eleaf GZeno S Sub Ohm Tank Atomizer Standard Version holds 4.0ml e-juice capacity with convenient top filling system and easy coil replacement in 24.5mm diameter. It features adjustable bottom airflow ring and leak-proof design to adjust the airflow you want and find the ideal throat hit. GZeno S Tank is compatible with GZ Coils like GZ 0.8ohm Coil (for MTL) and GZ 0.4ohm Coil (for Half-DL) are included. Two colors for your choice: Silver, Matte Gunmetal. ![]() Original Kumiho K1 V2 3 in 1 Magnetic 3A Braided Fast Charge Sync Cable for for iPhone 12/ Samsung / Huawei / Xiao MI $6.99 Original Kumiho K1 V2 3 in 1 Magnetic 3A Braided Fast Charge Sync Cable features upgraded 3 in 1 Magnetic Charge Sync Cable, compatible with all most Charging equipments: iPhone / Type-C / Android devices. In 1.0 meter length, it is easy to connect with one hand while driving or doing other things. It is widely compatible and solve the problem of breakage of charging cable, like iPhone 12 Mini / 12 / 12Pro / 12 Pro Max / 7 / 7Plus / 6S / 6S Plus / 6 Plus / 6 / SE (2020) / 11 / 11Pro / 11Pro Max / Xs Max / XR / XS / X / 8 / 8 Plus / AirPods / Ipad / Samsung / LG / HTC / Huawei / Moto / Xiao MI and More. Two color: Blue, Black.
Original YIHI SXmini SL Class 100W SX485J TC VW Box Mod Original Price $174.99, Now Only $59.99.
Original YiHi SXmini SL Class SX485J 100W vape Box Mod is from YiHi's unrivaled line-up, powered by 18650 / 20700 / 21700 battery (not included) platform with a premium frame chassis and high-end grip design. Accessed via a threaded battery cover at the bottom of the device, the SL Class SX485J can support single 18650, 20700, or 21700 battery for wide range of vape battery options. The internal YiHi SX485J Chipset provides tremendous output range of 5 to 100W alongside a suite of functionality such as full temperature control support and efficient processor for accurate and customizable experience. The inclusion of SXi-Q Intelligent Taste Curve Technology features an algorithmic calculation that allows users to set, fine tune, and save 5-memory output curves. ![]() Original YIHI T Class 200W TC VW Vape Box Mod Original Price $189.99, Now Only $50.99. Original YiHi SXmini T Class SX580J 200W Vape Box Mod is powered by 2 x 18650 batteries (not included). The design implements an intuitive joystick adjustment control with the addition of a joystick spinner for more dynamic operational control. The internal SX580J Chipset provides tremendous output range of 5 to 200W alongside a suite of functionality such as full temperature control support, Bluetooth support, and efficient processor for accurate and customizable experience. The inclusion of SXi-Q Intelligent Taste Curve Technology features an algorithmic calculation that allows users to set, fine tune, and save 5-memory output curves. The YiHi SX580J is also capable of Bluetooth connectivity and adjustment, allowing users to set and adjust the SXmini T Class from compatible phones. Four colors for your choice: Black Panther, Captain, Captain Gold, Black Shadow. ![]() Original Geekvape Wenax K1 600mAh Pod System Starter Kit $14.99 Original Geekvape Wenax K1 600mAh Pod System Starter Kit includes a Geekvape Wenax K1 600mAh Pod System Mod and a 2.0ml Geekvape Wenax K1 Pod Cartridge. Geekvape Wenax K1 Pod System Mod is powered by a 600mAh built-in battery with USB-C Charging Port 5V, with output power range: 9~16W. Constructed from Aluminum, Geekvape Wenax K1 Mod supports 3 level Adjustable Power Output, delivering an excellent vaping experience. Geekvape Wenax K1 Pod Cartridge holds 2.0ml e-juice capacity. In this kit, there are two pod cartridges, one with 0.8ohm coil (suggested wattage: 12~16W), another with 1.2ohm (10~12W). Nine colors for your choice. ![]() Original Nitecore i8 Intellicharger Multi-slot Intelligent Battery Charger AU Plug $43.99 The Nitecore i8 Intelligent Charger is the latest charger from the reliable Nitecore range, ideal for charging a huge variety of batteries whether used for vaping, torches or other electronic devices. Featuring 8 bays that are controlled independently, the i8 automatically detects power levels of the batteries and selects the appropriate voltage and charging mode. In addition, the charger offers reverse polarity protection and short circuit protection, ensuring you are made aware of the error with a flashing red indicator above the appropriate bay. The Nitecore i8 is made from PC materials and has a unique grill design on the top of charger for faster heat dissipation, providing a safe, reliable and simple charging experience. This charger is AU Plug. UK / EU / USA Plug are also available. ![]() Original Geekvape Wenax K1 Pod System Kit Replacement Pod Cartridge $9.99 Original Geekvape Wenax K1 Pod Cartridge with 1.2ohm coil (suggested wattage is 10~12W ) holds 2.0ml e-juice capacity. It is especially designed for Geekvape Wenax K1 Pod System Kit. Pod Cartridge with 0.8ohm coil (12~16W) is also available. 4 PCS / Pack ![]() Original Voopoo TPP Empty Pod Cartridge for TPP Tank Atomizer / Drag 3 Kit / Drag X Plus Kit $6.99 Original Voopoo TPP Empty Pod Cartridge with 5.5ml capacity is designed especially for the Voopoo Drag 3 Kit, Drag X Plus Kit and Voopoo TPP Tank. Three colors for your choice: Silver, Gun metal, Black. 2 PCS / Pack
Original Fucig Exvape Expromizer V5 MTL RTA Rebuildable Tank Vape Atomizer Original Price $39.95, Now Only $28.99.
Original Fucig Exvape Expromizer V5 MTL RTA is constructed from Stainless Steel (Body), Glass (Tank Tube) and POM (Drip Tip). It holds 2.0ml e-juice capacity with side top filling system and top-to-bottom airflow in 23mm diameter. Its airflow control can be adjusted in two different ways: on one side of the airflow control are 6 openings that you can open and close in steps, on the other side is a large opening, which you can adjust it as you need. The leakage will be completely prevented with the top-to-bottom airflow method. Liquid control will offer a wide range to control the liquid-flow, which makes Expromizer V5 RTA suitable for any types of liquid. Featuring single coil winding deck, it is easy to wind and handle. Five colors for your choice: Gun metal, Black, Sand blasting, Polished, Brushed ![]() Original Innokin Endura T20S 1500mAh Battery Mod $13.99 Original Innokin Endura T20S Battery is with a 1500mAh built-in Li-Po battery, capable to fire up to 18W. With tri-color LED indicator, you can check the battery level clearly and easily. The high-quality 510 connector makes it to be widely compatible with most atomizers. It also has USB pass-through and safety protections. In addition, it is pretty perfect as a replacement battery for Innokin Endura T20S Pod system Starter Kit. Two colors for your choice: Silver, Black ![]() Original Fucig EXvape eXpromizer V5 MTL RTA Replacement Extension Kit $6.89 Original Fucig EXvape eXpromizer V5 Extension Kit is especially designed for Fucig EXvape eXpromizer V5 MTL RTA to expand to 4.0ml capacity. Five colors for your choice: Gun metal, Black, Sand blasting, Polished, Brushed ![]() Replacement Glass Tank Tube for Geekvape Aero Mesh Sub Ohm Tank Atomizer 5.0ml $1.59 This replacement tank tube is especially designed for Geekvape Aero Mesh Sub Ohm Tank Atomizer. It holds 5.0ml capacity, made of Glass. 1 PC / Pack ![]() Replacement Glass Tank Tube for Nautilus 2S Sub Ohm Tank Clearomizer 2.6ml $1.59 This replacement tank tube is especially designed for Nautilus 2S Sub Ohm Tank Clearomizer. It holds 2.6ml capacity, made of Glass. 1 PC / Pack ![]() Replacement Glass Tank Tube for Hellvape Dead Rabbit V2 RTA Atomizer 2.0ml $1.59 This replacement tank tube is especially designed for Hellvape Dead Rabbit V2 RTA Atomizer. It holds 2.0ml capacity, made of Glass. 1 PC / Pack ![]() Replacement Glass Tank Tube for Vandy Vape Kylin M RTA Atomizer 3.0ml $1.59 This replacement tank tube is especially designed for Vandy Vape Kylin M RTA Atomizer. It holds 3.0ml capacity, made of Glass. 1 PC / Pack
Original VOOPOO Argus GT 160W TC Variable Wattage Box Mod + PnP Pod Tank Vape Kit Original Price $43.99, Now Only $41.99.
Original VOOPOO Argus GT vape Kit is composed of VOOPOO Argus GT Box Mod and PnP Pod Tank. VOOPOO Argus GT Box Mod, using the same zinc alloy and leather process as the racing bike is more aesthetically pleasing and 30% lighter than the usual Mod. Argus GT is powered by two external 18650 batteries (not included), in combination with the Type-C fast charging interface, offering you a longer vaping experience. Argus GT has a high power output of up to 160W (5~160W). Besides, Argus GT built-in powerful GENE.TT chip that gives it a thick haze in an instant, has the powerful performance of fast ignition and high burst and also provides intelligent functions such as SMART and TC mode. TC mode supports the temperature adjustment of Nickel, Titanium, and Stainless Steel heating wire materials. Just press "+" and "-" at the same time to enter the page adjustment. VOOPOO PNP Pod Tank hold up to 4.5ml e-juice capacity and refill the juice from the bottom of the Pod by twisting 510 base. With the addition of a 510 base, PnP Pod Tank fits almost all your VOOPOO devices. Made of PCTG, PnP Pod Tank matches with a rich flavor of PnP coil. Argus GT is equipped with two dedicated coils: PnP-VM5 0.2ohm and PnP-VM6 0.15ohm. Argus GT is compatible with all PnP coils including RBA, just pull and push, you can enjoy different vaping experience, fast and affordable. In addition, PNP Pod Tank has an innovative infinite airflow system. Turn 510 base for airflow adjustment. Nine colors in total for your choice. In addition, VOOPOO Argus GT Box Mod and PnP Pod Tank can be purchased separately. ![]() Original Fucig EXvape Expromizer V5 Cotton Rope Suitable for Coil Internal Diameter 2.0~3.0mm $6.95 Original Fucig EXvape Expromizer V5 Cotton Rope is 5 Meters in length, made of premium organic cotton. It is designed for coil internal diameter 2.0~3.0mm. ![]() Original Fucig EXvape Expromizer V5 MTL RTA Replacement Cotton Laces $6.95 Original Fucig EXvape Expromizer V5 Cotton Laces is especially designed for Fucig EXvape eXpromizer V5 MTL RTA. 20 PCS / Pack
Original VapX Meteor 510 2000mAh 80W VW Variable Wattage Vape Box Mod $39.99
Original VapX Meteor 510 Box Mod is equipped with a 2000mAh built-in battery, enough to provide a maximum power of 80W (5~80W). Constructed from Zinc Alloy and fenced with silicone straps, Meteor 510 Box Mod is formed indestructibly and ruggedly, featuring a superior IP68 waterproof, dustproof, and shockproof chassis strength to combat water, shocks, and dust in daily use situation. With a 0.96 inch color screen display and an extensive fire button, users can conveniently control the Meteor 510 box mod and easily check the overall details. It supports super charging and compatible with two charging methods: The first is to use the Type-C port on the side of the Mod to quickly charge at a charging rate of 5V / 2A; the second is to connect to the Mod's exclusive charging base for maximum fast charging, which can be fully charged in about 10 minutes. (The Charging Base is sold separately.) With 510 threading connection, it is also compatible with most of your favorable atomizers. Three colors for your choice: Volcano Red, Stardust Gray, Charcoal Black. ![]() Original ZQ Trio MTL RTA Replacement Tank Tube + Drip tip 2.0ml $4.99 Original ZQ Trio MTL RTA Replacement Tank Tube with Drip tip holds 2.0ml e-juice capacity, especially designed for ZQ Trio MTL RTA Rebuildable Tank Vape Atomizer.
Original Damn Vape DOOM X Mesh RTA Rebuildable Tank Vape Atomizer 5.5ml / 8.0ml Original Price $35.99, Now Only $22.99.
Original Damn Vape DOOM X Mesh RTA Rebuildable Tank Vape Atomizer holds 5.5ml / 8.0ml e-juice capacity with top filling system in 26mm diameter. DOOM X Mesh RTA features compact vaping chamber, 3D liquid flow, juice flow control and side bottom honeycomb airflow system to deliver you the denser flavor and bigger clouds. Constructed from Stainless Steel, Damn Vape DOOM X Mesh RTA adopts the spring-loaded clamp-style build deck, which is simply easy for you to wick and build mesh coil or normal coil. Three colors for your choice: Gunmetal, Black, SS. ![]() Original Damn Vape Mongrel RDA Rebuildable Dripping Vape Atomizer with BF Pin + Spare Top Cap Original Price $21.99, Now Only $20.99. Original Damn Vape Mongrel RDA is a single coil rebuildable dripping vape atomizer / squonker made in collaboration between Damn Vape & Deuces Jack (Vaping Insider). Mongrel RDA has a diameter of 25.4mm (stainless steel top cap) or 26mm (glass top cap). A stainless steel top cap and a glass top cap are included in package for personal customization. Mongrel RDA adopts a dual post deck designed for single coil build with two terminals per post. Air enters the coil from the bottom through the center hole. In addition, the Damn Vape Mongrel RDA possesses 9.5mm deep juice wells. Mongrel RDA has a standard 510 pin and a BF 510 pin, use for squonking mod. Due to the use of airflow solutions, the liquid is supplied through two side openings. The dripping juice capacity reaches 1.5ml. Four colors for your choice: Gunmetal, Silver, Black, Matte Black. ![]() Original Damn Vape DOOM X Mesh RTA Replacement Tank Tube $1.79 Original Damn Vape DOOM X Mesh RTA Replacement Tank Tube is especially best for Damn Vape DOOM X Mesh RTA Rebuildable Tank Vape Atomizer. Three capacities for your choice: 2.0ml PCTG, 5.5ml PCTG, 8.0ml Glass. ![]() Original Damn Vape Doom X Mesh RTA Replacement KA1 DV-01 Mesh Coils $4.99 Original Damn Vape Doom X RTA Replacement is made of KA1, designed for Damn Vape Doom X Mesh RTA Rebuildable Tank Vape Atomizer. Four types for your choice: DV-01 Mesh Coils with 0.12~0.18ohm resistance, DV-03 0.11~0.16ohm, DV-04 0.17~0.23ohm, DV-05 0.12~0.18ohm (suggest wattage: 45~60W). 10 PCS / Pack
17
Original Uwell Whirl S 1450mAh 18W Pod System Vape Pen Starter Kit $38.89
Original Uwell Whirl S Pod System Pen Starter Kit includes a Uwell Whirl S 1450mAh 18W Battery Mod and a 2.0ml Whirl S Pod Cartridge. Uwell Whirl S Battery Mod is powered by a 1450mAh built-in battery, enough to provide a maximum output power of 18W in Bypass mode with 5V / 2A USB-C charging. Equipped with color LED display and constructed from Stainless Steel, Whirl S Mod can be activated by automatic pull / fire button, easy for you to operate. Whirl S Pod Cartridge holds 2.0ml e-juice capacity with top filling system. With a magnetic connection, the pod cartridge can be easily disassembled and cleaned with running water to make cleaning more convenient and avoid the Mod damaged by water. It features adjustable airflow located on the bottom, bringing you RDL or MTL vaping experience. Four colors for your choice: Coffee, Iridescent, Blue, Dark Grey. ![]() Original Steam Crave Aromamizer Supreme V3 RDTA Rebuildable Dripping Tank Vape Atomizer Advanced Kit 6.0 / 7.0ml $56.99 Original Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer, a high-quality multifunctional Rebuildable Dripper Tank Atomizer, is made of stainless steel and Pyrex glass in 25mm diameter. The Aromamizer Supreme V3 RDTA can be used as an RTA or RDA or be equipped with another chimney, with a 6.0ml or 7.0ml tank glass or an optional deck. Compared to its predecessor, the Supreme V3 has an improved a honeycomb airflow design, which offers even more options in the DL area and, together with the single-coil deck, gets everything out of the winding. A single-coil deck is pre-installed and fresh air is fed to it from below and from the side, ensuring an excellent taste and ample vapor. With postless deck and mesh deck, Aromamizer Supreme V3 RDTA is compatible with the decks of the Aromamizer Supreme V2 RDTA. Five colors in total. Basic version is also available. ![]() Original Uwell Whirl S Pod System Starter Kit Replacement Pod Cartridge $8.5 Original Uwell Whirl S Pod Cartridge holds 2.0ml capacity with top filling system. It features adjustable airflow located on the bottom, delivering you RDL or MTL vaping experience. Whirl S Tank accepts UN2 Meshed-H Coil (Not included) with the push-pull style design. With a magnetic connection, the pod cartridge can be easily disassembled and cleaned with running water to make cleaning more convenient and avoid the Mod damaged by water. With an innovative coil lock design, the coil (not included) is firmly fixed in the cartridge by a spring-loaded bolt and can be removed again only after the lock is released. ![]() Original Uwell Whirl S Pod System Starter Kit / Pod Cartridge Replacement UN2 Meshed-H Coil 0.8ohm $13.36 Original Uwell Whirl S UN2 Meshed-H Coil is with 0.8ohm resistance, made of FeCrAl. It is especially designed for Uwell Whirl S Pod System Starter Kit and Uwell Whirl S Pod Cartridge. With the Pro-FOCS flavor testing technology, it gives you a satisfying flavor. 4 PCS / Pack ![]() Original Steam Crave Aromamizer Ragnar RDTA Replacement 810 Wide Bore Drip Tip 22mm $3.99 Original Steam Crave Aromamizer Ragnar Replacement 810 wide bore drip tip is in 22mm Diameter. It is made of resin and stainless steel, designed for Steam Crave Aromamizer Ragnar RDTA. In addition, it is also suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Apocalypse GEN 2 RDA, Vandy Vape Kylin V2 RTA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Hellvape Drop Dead RDA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. Five colors for your choice. ![]() Original Innokin Isub BVC Coil for Innokin Isub / Isub A / Isub G / Isub S / Isub V Tank Atomizer 0.5ohm $7.99 Original Innokin Isub BVC Coil with 0.5ohm resistance is suitable for Innokin Isub / Isub A / Isub G / Isub S / Isub V Tank Atomizer. 5 PCS / Pack ![]() Original Wotofo NexMESH SUS316L Mesh Sheet Coil for Profile 1.5 RDA / Profile RDTA 0.15ohm $4.99 Original Wotofo NexMESH SUS316L Mesh Sheet Coil is with 0.15ohm resistance, suitable for Profile 1.5 RDA / Profile RDTA. Other types are also available: nexMESH Prebuilt 0.16ohm Wire Mesh Sheet, nexMESH Turbo 0.13ohm Prebuilt Wire, nexMESH Chill 0.15ohm Prebuilt Wire.10 PCS / Pack
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Vapefly Kriemhild II Sub Ohm Tank Vape Atomizer 4.0ml / 5.0ml $39.9
Original Vapefly Kriemhild II Sub Ohm Tank, the upgraded version of the original Kriemhild Sub Ohm Tank, applies the newest Duplex TM patented mesh technology, ensuring the coil fires up instantly, heats evenly, and creates soft and delicate taste to bring you an excellent vaping experience. Kriemhild II Sub Ohm Tank Vape Atomizer holds 4.0ml / 5.0ml with top filling system in 25mm diameter with Pull-Plug coil replacement design for easily installing coil (FreeCore K-1 0.2ohm / K-2 0.3ohm included). Two versions for your choice: Standard Edition-P Version and Standard Edition-W Version. Edition-P is shaped with less metal construction and more visible Glass tank tube for checking the juice, while Edition-W version looks similar to the original Kriemhild Atomizer with less visible Glass tank tube. Three colors: Gunmetal, Black, Silver. Picture below shows Edition-W version. ![]() Original Vapefly Kriemhild II Atomizer / Kriemhild Kit Replacement FreeCore K-2 Mesh Coil $11.99 Original Vapefly Kriemhild II FreeCore K-2 Mesh Coil is perfectly fit for Kriemhild II Sub Ohm Tank Vape Atomizer / Kriemhild Kit with 0.3ohm resistance (suggested wattage: 40~55W), delivering you an amazing vaping experience. FreeCore K-1 Duplex Mesh Coil 0.2ohm (45~60W) is also available. 5 PCS / Pack ![]() Original Vapefly Kriemhild II Atomizer / Kriemhild Kit Replacement FreeCore K-1 Duplex Mesh Coil 0.2ohm $12.37 Original Vapefly Kriemhild II FreeCore K-1 Duplex Mesh Coil with the newest mesh technology, Duplex patented mesh technology fires up instantly, heats evenly, and creates soft and delicate taste. The coil is with 0.2ohm resistance (suggested wattage: 45~60W), perfectly fit for Kriemhild II Sub Ohm Tank Vape Atomizer / Kriemhild Kit. 5 PCS / Pack ![]() Original Vapefly Kriemhild II Sub Ohm Tank Replacement Glass Tank Tube $2.99 Original Vapefly Kriemhild II Replacement Glass Tube is especially designed for Vapefly Kriemhild 2 Sub Ohm Tank Vape Atomizer. Two capacities for your choice: 4.0ml, 5.0ml.
Original Wotofo SMRT 2000mAh 80W VW Pod System Starter Kit Original Price $39.95, Now Only $24.99.
Original Wotofo SMRT 2000mAh 80W Pod System Starter Kit consists of a Wotofo SMRT 2000mAh Pod System Battery Mod and a 4.5ml Wotofo SMRT Pod Cartridge. Wotofo SMRT Pod System Battery Mod is powered by a 2000mAh built-in battery, enough to fire up to 80W (5~80W). Equipped with 0.96 inch TFT display and constructed from Aluminum Alloy, Wotofo SMRT Battery Mod is durable and lightweight and easy to check the vaping statistics you need. It adopts the nexCHIP quickly ignite within 0.001 seconds and also provides intelligent identification of coil. Wotofo SMRT Pod Cartridge holds 4.5ml capacity with side filling system, made of PCTG. It adopts an adjustable air intake at the bottom. SMRT Pod Cartridge is compatible with D11 / D13 / D14 / D15 / Voopoo PnP-series and Vaporesso GTX series Coils. (Only SMRT PnP Rebuildable Coil and D15 Clapton M Coil included in the package) ![]() Original HorizonTech Asteroid 900mAh Pod System Starter Kit Original Price $39.99, Now Only $23.99. Original HorizonTech Asteroid 900mAh Pod System Starter Kit includes a HorizonTech Asteroid 900mAh Pod System Battery Mod and a 2.0ml HorizonTech Asteroid Pod Cartridge. HorizonTech Asteroid Pod System Battery Mod is powered by a 900mAh built-in battery, enough to provide a maximum power of 15W, with Type-C 5.0V charging for a long lasting vaping experience. Equipped with LED battery light indicator, HorizonTech Asteroid Mod, as a lightweight and portable pod system Mod, is perfectly suitable for you to carry it outside. HorizonTech Asteroid Pod Cartridge holds 2.0ml e-juice capacity with top filling system. With push-pull coil replacement design, it is easy for you to install coils. It comes with 0.8ohm mesh coil, brings you an excellent MTL vaping experience. In addition, it provides you two different airflow style options by Rotating Pod Cartridge 180 Degree, meeting your different meets. ![]() Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement PnP Rebuildable Coil Pack Original Price $14.95, Now Only $9.99. Original Wotofo SMRT PnP Rebuildable Coil Pack is interchangeable with Voopoo Pnp and Vaporesso GTX Coils (not included), including 1 x SMRT PnP Rebuildable Coil, 2 x nexMESH Chill, 2 x nexMESH Turbo, 2 x nexMESH Extreme, 6 x Cotton Strip. Wotofo SMRT PnP Mesh and Cotton Strip firstly need to be installed in Voopoo Pnp and Vaporesso GTX Coil shell (Not included) to be a complete and usable coil and then can be perfectly applied in Wotofo SMRT Pod System Starter Kit and Wotofo SMRT Pod Cartridge. ![]() Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement PnP Rebuildable Coil Kit Original Price $9.95, Now Only $5.99. Original Wotofo SMRT Coil Kit is interchangeable with Voopoo Pnp and Vaporesso GTX Coils (not included), including 1 x SMRT PnP Rebuildable Coil, 2 x nexMESH Chill, 2 x nexMESH Turbo, 2 x nexMESH Extreme, 6 x Cotton Strip. Wotofo SMRT PnP Mesh and Cotton Strip firstly need to be installed in Voopoo Pnp and Vaporesso GTX Coil shell to be a complete and usable coil and then can be perfectly applied in Wotofo SMRT Pod System Starter Kit and Wotofo SMRT Pod Cartridge. ![]() Original Wotofo SMRT Pod System Starter Kit / Pod Cartridge Replacement PnP nexM Chill Mesh + Cotton Strip Original Price $9.95, Now Only $5.99. Original Wotofo SMRT PnP nexM Chill Mesh + Cotton is interchangeable with Voopoo Pnp and Vaporesso GTX Coils (not included), including 10 x nexM Chill and 10 x Cotton Strip. Wotofo SMRT PnP Mesh and Cotton Strip firstly need to be installed in Voopoo Pnp and Vaporesso GTX Coil shell to be a complete and usable coil and then can be perfectly applied in Wotofo SMRT Pod System Starter Kit and Wotofo SMRT Pod Cartridge. Other types for your choice: PnP nexMESH Turbo Mesh, PnP nexMESH Extreme Mesh. ![]() Original Wotofo SMRT Pod System Kit Replacement PnP Pod Cartridge 4.5ml Original Price $9.95, Now Only $2.59. Original Wotofo SMRT Pod Cartridge is made of PCTG, holding 4.5ml e-juice capacity with side filling system, especially designed for Wotofo SMRT Pod System Starter Kit. It has an adjustable air intake at the bottom. It is compatible with D11 / D13 / D14 / D15 / Voopoo PnP-series and Vaporesso GTX series Coils (coils not included). ![]() Original HorizonTech Asteroid Pod System Kit Replacement Pod Cartridge 2.0ml Original Price $3.99, Now Only $2.59. Original HorizonTech Asteroid Pod Cartridge holds 2.0ml capacity with top filling system, designed especially for the HorizonTech Asteroid Pod System Starter Kit. With push-pull coil replacement design, it is easy for you to install coils (not included). ![]() Original HorizonTech Asteroid Pod System Kit / Pod Cartridge Replacement Mesh Coil 0.8ohm Original Price $14.99, Now Only $7.99. Original HorizonTech Asteroid Replacement Mesh Coil with 0.8ohm resistance brings you a MTL vaping experience. It is compatible with HorizonTech Asteroid Pod System Starter Kit and HorizonTech Asteroid Pod Cartridge. 3 PCS / Pack ![]() Original Damn Vape Mongrel RDA Replacement Full Open Airflow Insert $3.59 Original Damn Vape Mongrel Full Open Airflow Insert is especially designed for Mongrel RDA Rebuildable Dripping Vape Atomizer. Other types for your choice: Slotted / Honeycomb Airflow Insert.
20
Replacement Glass Tank Tube for Eleaf iJust 3 Starter Kit 6.5ml $1.89
This replacement glass tank tube holds 6.5ml e-juice capacity, especially designed for Eleaf iJust 3 Starter Kit. 1 PC / Pack ![]() Replacement Glass Tank Tube for Vaporesso NRG PE Sub Ohm Tank 3.5ml $1.89 This replacement glass tank tube holds 3.5ml e-juice capacity, especially designed for Vaporesso NRG PE Sub Ohm Tank Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for Voopoo Uforce T2 Sub Ohm Tank 5.0ml $1.89 This replacement glass tank tube holds 5.0ml e-juice capacity, especially designed for Voopoo Uforce T2 Sub Ohm Tank Vape Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for HorizonTech Falcon King Sub Ohm Tank 6.0ml $1.89 This replacement glass tank tube holds 6.0ml e-juice capacity, especially designed for HorizonTech Falcon King Sub Ohm Tank Vape Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for SMOKTech SMOK TFV8 Baby V2 Sub Ohm Tank 2.0ml $1.89 This replacement glass tank tube holds 2.0ml e-juice capacity, especially designed for SMOKTech SMOK TFV8 Baby V2 Sub Ohm Tank Vape Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for SMOKTech SMOK TFV8 Baby Beast Sub Ohm Tank 3.0ml $1.89 This replacement glass tank tube holds 3.0ml e-juice capacity, especially designed for SMOKTech SMOK TFV8 Baby Beast Sub Ohm Tank Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for SMOKTech SMOK TFV8 Big Baby Beast Sub Ohm Tank 7.0ml $1.89 This replacement glass tank tube holds 7.0ml e-juice capacity, especially designed for SMOKTech SMOK TFV8 Big Baby Beast Sub Ohm Tank Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for SMOKTech SMOK TFV12 Baby Prince Sub Ohm Tank 2.0ml $1.89 This replacement glass tank tube holds 2.0ml e-juice capacity, especially designed for SMOKTech SMOK TFV12 Baby Prince Sub Ohm Tank Vape Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for SMOKTech SMOK TFV12 Cloud Beast King Sub Ohm Tank 8.5ml $1.89 This replacement glass tank tube holds 8.5ml e-juice capacity, especially designed for SMOKTech SMOK TFV12 Cloud Beast King Sub Ohm Tank Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for SMOKTech SMOK TFV16 Lite Sub Ohm Tank 5.0ml $1.89 This replacement glass tank tube holds 5.0ml e-juice capacity, especially designed for SMOKTech SMOK TFV16 Lite Sub Ohm Tank Atomizer. 1 PC / Pack ![]() Replacement Glass Tank Tube for SMOKTech SMOK TFV16 Sub Ohm Tank $1.89 This replacement glass tank tube holds 5.0ml e-juice capacity, especially designed for SMOKTech SMOK TFV16 Sub Ohm Tank Atomizer. Two Capacities for your choice: 5.0ml / 9.0ml. 1 PC / Pack ![]() Original Augvape Intake Mesh Sub Ohm Tank Replacement Straight Tank Tube 3.5ml $1.99 Original Augvape Intake Replacement Straight Tank Tube holds 3.5ml capacity, made of Glass. It is especially designed for Augvape Intake Sub Ohm Tank Vape Atomizer. 1 PC / Pack ![]() Original XTAR X4 Charger for 3.6V / 3.7V Li-ion / IMR / INR / 18350 / 18500 / 18650/18700/20700/21700 Batteries, etc. w/ AU Plug $39.99 The XTAR X4 Quick Charger has great compatibility, which can work with different batteries. It also features four battery slots with LCD display that you can see the charging situation clearly. The X4 regulates the voltage and current delivered to the batteries in three automatic stages, ensuring batteries receive optimum charging with minimal wear and tear. The XTAR X4 Charger is compatible with different kinds and sizes of most batteries like 3.6V / 3.7V Li-ion/ IMR / INR / ICR: 14500 / 14650 / 16340 / 17335 / 17500 / 17670 / 18350 / 18490 / 18500 / 18650 / 18700 / 20700 / 21700 / 22650 / 25500 / 26650, and 1.2V Ni-MH / Ni-CD: AAAA / AAA / AA / A / SC / C. Note: The XTAR X4 Charger cannot charge protected 20700 / 21700 batteries. Two Plugs for your choice: AU Plug, US Plug ![]() Original Steam Crave Aromamizer Plus V2 RDTA Replacement Mesh Strip Coil $3.99 Original Steam Crave Mesh Strip Coil with 0.15ohm resistance is made of Ni60. It is designed for Steam Crave Aromamizer Plus V2 RDTA Rebuildable Dripping Tank Vape Atomizer. Four types for your choice: 0.15ohm Mesh Strip Coil (Ni60), 0.15ohm Dual Mesh Strip Coil (Kanthal A1), 0.15ohm Mesh Strip Coil (Kanthal A1), 0.14ohm Mesh Strip Coil (SS316L). 10 PCS / Pack
