5040
🔥🔥🔥 The Acebeam L35 is a super bright tactical flashlight that blasts a max output of 5000 lumens and a max beam distance of 480 meters (CREE XHP70). Also, L35 is offering a new ELD option with LatticePower P70 for more long beam distance. Powered by a single high capacity 21700 battery, the L35 has impressive outputs and beam distance. It has a body diameter of 1" so it is compatible with most weapon mounts. The side switch is for a everyday activation and the tail switch can be used for tactical purposes or remote pressure switch attachment. The L35 was designed for tactical, hunting, duty, law-enforcement, search and outdoor use.
✅ Maximum output 5,000 lumens with a throw of up to 480 meters ✅ Can be mounted on different kind of guns with proper equipment. ✅ 6 brightness levels option plus special Strobe ✅ Powered by 1 x 21700 (Recommend ACEBEAM 21700 USB-C rechargeable battery) ✅ 1-meter impact resistance, IP68 waterproofing Click and Get More Info: 👉 https://www.acebeam.com/l35 sales@acebeam.com
www.acebeam.com [Исправлено: Acebeam Light, 11.11.2020 в 06:27] |
[Исправлено: Acebeam Light, 20.11.2020 в 09:32] |
[QUOTE=Acebeam Light;1305093]ACEBEAM L35 Is A Worthwhile Purchase in the end of 2020.
![]() sales@acebeam.com[/QUOT |
The ACEBEAM L35 2.0 is a near-perfect outdoor flashlight. The beam is perfect; throw enough to punch through and flood enough to see what the hazards are at your feet. And the battery remained >75% with two hours of constant use and repeated access to turbo mode.
Warm Tip: The low inventory of the Blue version is available. Learn more: https://www.acebeam.com/l35... acebeam.aliexpress.com ![]() ![]() ![]() cs@acebeam.com |
Сказал(а) спасибо: 3350
Поблагодарили: 1947 раз(а) в 1254 сообщениях
Замечательно!
Байки старого генерала |
Регистрация: 17.09.2021 Последняя активность: 18.12.2025 22:58
Сказал(а) спасибо: 311
