Просмотров в теме 3791   Ответов в теме 3   Подписчиков на тему 3   Добавили в закладки 0
Старый 01.11.2020, 18:59 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell INR14500 950mAh P1409A (Black-red) 2020
Official specifications:
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge voltage: 2.50V
  • Typical capacity: 950mAh
  • Minimum capacity: 880mAh
  • Standard charge: 500mA, CCCV, 50mA cut-off
  • Quick charge: 1000mA, CCCV, 100mA cut-off
  • Maximum continuous discharge current: 2000mA
  • USB input power: 5V <0.5A
  • USB charge current: 375mA +/50mA
  • Over charge protection: 4.25V +0.05V/-0V
  • Over discharge protection: 2.50V +0.0V/-0.05V
  • Over current protection: 2.1A ~ 3A
Protected and USB chargeable AA sized LiIon cells and they are not over sized, this looks good.
There is a led behind the white plastic top to show when the cell is charging: red=charge, blue=done.
The two cells are well matched, they are not high current cells, but than still deliver above 6 watt.
The cells can be charged on a normal LiIon charger.
Here I am using the USB input to charge.
Conclusion
A good protected 14500 cell with the added bonus of a USB charge input.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
MA57 (04.11.2020), Storm (01.11.2020)
Старый 04.11.2020, 15:26   2
MA57
Аватар для MA57
Последняя активность: Вчера 08:03
Сказал(а) спасибо: 1135
По умолчанию Re: Test/review of Vapcell INR14500 950mAh P1409A (Black-red) 2020
What a good batteries.
Hello there
Старый 04.11.2020, 15:35 Автор темы   3
HKJ
Аватар для HKJ
In this case it is because the LiIon battery works as expected without any issues and because it fits 14500 size (All other protected and/or usb charged LiIon batteries I have tested is oversized)
grasl (04.11.2020), MA57 (05.11.2020)
Старый 05.11.2020, 11:06   4
MA57
Аватар для MA57
Посмотреть сообщение Сообщение от HKJ :
That's it. Built-in micro-usb charger with decent amount of capacity and without growing up the length of the battery - is a jack-pot. Also I think that top positive contact with small diameter is a good thing because some twisty flashlights (such as DQG AA) have foam at the head and can't be turned on properly without that feature at the battery.
[Исправлено: MA57, 05.11.2020 в 11:11]
Время генерации страницы 0.09232 секунды с 15 запросами
