Просмотров в теме 3392   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 21.07.2020, 17:36 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Vapcell Vapcell IFR32700 6500mAh G65 (Blue) 2020
[Vapcell IFR32700 6500mAh G65 (Blue) 2020
Official specifications:
  • Model: IFR32700 G65 6500mah 30A
  • Size: 32.1*70.5mm
  • Nominal voltage: 3.20V
  • End-of-charge voltage: 3.65V
  • End-of-discharge Voltage: 2.0V
  • Typical Capacity: 6500mAh (0.2C discharge)
  • Min capacity: 6400mAh (0.2C discharge)
  • Weight: Max: 150g
  • Internal resistance: Max:8mOhm AC 1kHz
  • Standard Charge: 6000mA,CCCV 50mA cut-off
  • Quick Charge Current: 30000mA
  • Max Continuous Discharge Current: 30A
  • Max Pulse Discharge Current: 55A for 5 seconds
Fairly large (They are 5mm longer than 32650) LiFePO4 batteries that can deliver a lot of current.
The two batteries matches very well. Being LiFePO4 the discharge curve is very flat, until the battery is nearly empty. The batteries can also easily handle the 30A test current and without any drop in capacity.
The charger curve for LiFePO4 is significantly different from LiIon.
[Conclusion
Need a lot of current and stable voltage at around 3V, then these batteries are very good.
[Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Drex (21.07.2020), grasl (21.07.2020), WallE (22.07.2020)
Время генерации страницы 0.11600 секунды с 15 запросами
