Просмотров в теме 2393   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 10.06.2020, 17:54 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Ampsplus 16650 2500mAh (Black) 2020
Official specifications:
  • Ampsplus 16650 2500mAh Battery Protected
  • Battery Size: 16.60mm x 67.50mm
  • Nominal Voltage: 3.70V
  • Nominal Capacity: 2500mAh
  • Min. Rated Capacity: 2400mAh
  • Charging Method: CC/CV 4.20V~4.35V
  • Discharge Voltage: 3V (Average Cut Off)
  • Standard Charging Current CC: 1250mA
  • Fast Charging Current: 2500mA
  • Standard Charging Time: 4hrs
  • Continuous Discharge Current: 6A
  • Energy Density: 9.25Wh
  • Battery Rate: 2C
  • Weight: 41 gr. max
  • Version: Button
  • Protection / PCB: Yes , Protected
This is a protected 16650 LiIon battery
The two cells match nicely, but the capacity is nowhere near the rated 2500mAh, the cells are also very hard pressed at 5A load.
The missing capacity is due to it being a 4.35V cell used at 4.2V and most likely the protection will prevent it being charge to 4.35V..
Conclusion
This cell is a fairly good 16650 protected cell, but do not expect the rated capacity.
Notes and links
The batteries was supplied by Ampsplus for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
fnksb (10.06.2020), m72 (15.06.2020), ФанКол (10.06.2020)
Время генерации страницы 0.08686 секунды с 15 запросами
