7589
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Hohm Tech School4
A four slot LiIon only charger from Hohm Tech that is USB powered. The charger was in a cardboard with specifications on it. The box included the charger, a USB cable and a instruction sheet. The USB cable is very thick. The charger has a USB type-C input. It only uses 5V and the supplied cable is with a USB-A plug in the other end. There are no buttons, only a led for each slot. The leds is red while charging and green when the battery is full. ![]() There is two current settings on the charger and they are selected by the battery length. There is a nice marking showing at what point the current changes. The charger has specifications on the back. ![]() The connection are the common slider style that can handle from 32mm to 76mm, this means all batteries will fit. The current for 10440 is a bit on the high side. The charger is not rated for 32xxx batteries, but LiIon types may work in it. Measurements charger
Charging LiIon ![]() Slot #1 uses two ampere with long batteries, the charge current is a nice CC/CV curve and a termination current around 130mA ![]() ![]() With slot #2 & #3 the current is 1A and the termination current around the same. ![]() And slot #4 is also 2A ![]() ![]() ![]() Doing these other batteries in a 1A slot worked nicely ![]() ![]() A 2A slot also works, but it harder on the batteries ![]() The small batteries is charged in a 0.5A slot. ![]() Here I use a 2A slot for charging a high current battery. ![]() Using a 0.5ohm resistor in series with the power supply to simulate a long cable or weak supply, the charger handles it nicely. ![]() The charger will charge four batteries fairly fast, but it do not play nice with the USB charge. In this case I am drawing nearly 4A from my supply, as can be seen above the charger will reduce current if the USB charger has trouble keeping the voltage up (The specifications says it can use 4A from USB). ![]() M1: 36.6°C, M2: 41.0°C, M3: 39.8°C, M4: 34.5°C, HS1: 47.9°C ![]() HS1: 45.1°C ![]() The charger needs about 10 seconds to reach full current. I wonder about the initial pulse, it is at the full slot current, but the second time the current goes up it will stop at the low current setting if a short battery is in the charger (Two seconds at double charge current is not really an issue for any battery). ![]() The charger will discharge a full LiIon battery with about 10mA when not powered. ![]() ![]() ![]() The charge profile. ![]() The charger will not work reliable with a unstable voltage. Conclusion The charger can handle a wide variety of LiIon battery sizes and currents with currents selected from 0.5A, 1A and 2A it is very universal. But it requires a bit much from the USB charger, it is best to use a charger with two or more USB outputs is parallel, that can deliver 4A or more (Check my USB charger tests). This also makes it a fairly fast USB powered charger. I will rate it as good. Notes The charger was supplied by a Hohm for review. Here is an explanation on how I did the above charge curves: How do I test a charger My USB charger tests
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
stradivarius (10.04.2020)
