1580
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Yucel Y12-6L 6V 12Ah (Lead-Acid PB)
![]() Official specifications:
![]() ![]() ![]() ![]() ![]() ![]() The capacity of lead acid is very depend on load. ![]() The battery rating says it must work for 20 hours at 0.6A discharge and 10 hours at 1.112A discharge, this looks to about match the performance of the battery. ![]() ![]() ![]() ![]() I did not try any real high current test, only a load sweep up to 15A and the voltage looks fairly stable. ![]() Charging algorithm is basically the same as LiIon, but with other voltage levels. Conclusion It was interesting to test a PB battery and see how the discharge and charge curve looks Notes and links I was asked if I could test a lead acid battery and because I had a idle test station I agreed to do it. I do not have more more lead acid batteries planned. I looks like Yucel uses more than one manufacturer for their batteries, I got batteries with different types and place of markings. The two shown here is with the same marking, but the others is not very different. How is the test done and how to read the charts
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
