6713
Регистрация: 26.04.2011 Последняя активность: 10.11.2015 10:40
DX/KAI Single-Stage 1AA Cree/SSC shootout: BEAMSHOTS + RUNTIMES
Keeping in the tradition of my Multi-stage 1AA Review - Part III: Runtimes, beamshots & more!, here's a round-up of some of the current <$20 single-stage 1AA and 2AA Cree/SSC lights available at DealExtreme and Kaidomain. Note that although I've generally given the links & sku numbers for DX, many of these lights are also available at Kai's site. For comparison sake, I've also included the results of some my mods. I'm not advocating modding here - just giving you an idea of what to expect compared to the current crop on Cree/SSC lights. The 1AA contenders: ![]() From left to right: SKU.1993 UltraFire C3 Cree 1xAA 1x14500 Flashlight (with Holster) $17.00 SKU.1995 MTE 1xAA SSC-P4 42180-U Flashlight $14.50 SKU.4596 Aluminum 1.25W Cree Flashlight (AA) $10.95 SKU.1892 DX Cree 1-Mode Enhanced Flashlight (1xAA) $13.95 SLU.4949 DX Simply Cree Flashlight (1xAA) $8.95 SKU.927 1W Ultrafire 1AA Green Tail Black $14.71 modded with DX SSC U-bin SWO SKU.1120 1W 1-AA MXDL "ELLY" Flashlight Silver $7.24 modded with DX Cree P4 WD Note the Elly can be bought already upgraded to a Cree here: SKU.2098 The 2AA contenders: ![]() From left to right: SKU.4452 UltraFire Cree C3 Flashlight with 2xAA Extension Tube Bundle $20.50 SKU.927 1W Ultrafire 1AA Green Tail Black $14.71 modded with DX SSC U-bin SWO and C3 extension tube SKU.889 3W Ultrafire 601A 2AA Black $16.18 modded with Kai Edison Opto KLC8 Kai SKU.2081 Optical 1.5W Nichia LED Flashlight (2AA) $15.78 modded with DX Cree P4 (FYI, this is the same stock light at the Aurora/RiverRock 2AA Nichia) Note the extension tube for the Ultrafire C3 (which also fits the 602A1 tail) can be purchased separately here: SKU.4438 1AA Beamshots: All beamshots are taken in the same order as the lights up above. ![]() As you can see, there's a lot more tint variability on these cheap lights compared to the premium tints on my multi-level 1AA review. Here's a lower exposure to show you the hotspots better: ![]() The Simply Cree beamshot is missing since the first unit I was shipped had the wrong emitter (replaced by DX). I haven't bothered to re-take the beamshots, since it doersn't look appreciably different from the other lights 2AA Beamshots: ![]() Note that I sputtered the reflector of the 601A modded with the KLC8 slightly, to help with very noticeable yellow corona. The Aurora-Cree mod throws the Cree die "space invader" image as shown in this mod review thread. Again, here's a lower exposure to show you the hotspots better: ![]() Summary Chart for 2500mAh Sanyo NiMH ![]() ![]() Method: All my output numbers are relative for my home-made light box setup, a la Quickbeam's FR.com method. My relative overall output numbers are typically similar to his, although generally a little lower. You can directly compare all my review graphs - i.e. an output value of "10" in one graph is the same as "10" in another. Throw values are the square-root of lux measurements taken at 1m using a light meter. Runtimes: ![]() ![]() Note: Although the output looks lower on Aurora Cree-mod, I suspect that's just because the light is such a thrower. I find my home-made lightbox doesn't accurately report output for extremely tightly focused throw lights like this. From a ceiling bounce test, it's not that much dimmer than the others. Key Observations: Build Quality
Output vs Runtime
Output vs Throw
Modded vs stock
Conclusion:
Hope that was a helpful comparison. I have a number of the recent cheap multi-stage lights from DX and Kai, and may do a review of these if I have time. FYI, build quality is typically similar to single-stage versions shown here. I still recommend the higher quality multi-stage lights.
