Просмотров в теме 2008   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 16.11.2019, 18:41 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of LG 21700 M50T 5000mAh (Gray)
Official specifications:
  • Nominal energy: 18.20 Wh
  • Minimum energy: 17.60 Wh
  • Minimum capacity: 4850mAh
  • Nominal voltage: 3.63V
  • Standard charging current: 1,455A
  • Max charging current: 3.395A
  • Charging voltage: 4.2V
  • Charge interrupt current: 50 mA
  • Max discharge current: 7.275A
  • Switch-off voltage: 2.5V
  • Weight: 68 ± 1 g
  • Protected: No.
  • Rechargeable: Yes
  • Dimensions: 21.1mm x 70.2mm
This is a high capacity 21700 cell with about 5000mAh, the cell is not for high current.
The two cells are well matched.
Conclusion
This is a very good high capacity cell, but I got slightly less capacity compare the M50.
Notes and links
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
fnksb (16.11.2019), WallE (18.11.2019), Сумской (17.11.2019)
Время генерации страницы 0.07625 секунды с 15 запросами
