4756
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Xtar PB2S Charger & power bank
This is a 18650/21700 LiIon charger and power bank from Xtar with support for QC. It arrived in a white cardboard box with specification on it. ![]() The box contained the charger, a usb cable (A to C) and a instruction sheet. ![]() The charger is usb powered with a USB-C input and a USB-A output for the power bank function. With the supplied cable it can be charger from a USB-A charger and charge a phone that uses USB-C input. What is not specified is that the USB-C input can also works as a 5V output (With USB-C direction can be automatic selected). On some PB2S the USB-C is marked "in/out". ![]() This button is can be used to turn the power bank on and to change between different information on the display. When used as a power bank the display can be turned off by holding the button down. ![]() Default display, here I am using QC at 12V. ![]() And 5V, I am loading with above 2A. ![]() Here I am using the USB-C for output (OUT2). ![]() Charging, display shows input voltage and current. ![]() First battery (B1) is full. ![]() Second battery (B2) is charging with 2.1A. ![]() ![]() The lid uses magnets, this makes it fairly easy to open when you stick you nail into a small slot. The magnets are strong enough that you can easily lift the box in the lid, when it is filled with batteries. ![]() The specifications are listed on the bottom, but are not fully correct, the box can also deliver QC 12V output, but has trouble maintaining that voltage when loaded, the USB-C connector can supply 5V. ![]() The slots are only designed for 18650, 20700 and 21700. The negative end is spring loaded and handles lengths from 63mm to 71.5mm. ![]() There is a strip to put below the batteries, this makes it easy to get the batteries out. ![]() Xtar gave me two batteries, I can use them here to show the battery space, but with only one of each I cannot test them. Measurements
![]() The charger uses a CC/CV charge curve and it looks like it do some sort of test after 10 minutes. ![]() The charger generally starts at a fairly high current, this may be fine for 21700 and high current 18650, but it not ideal for high capacity 18650. ![]() ![]() ![]() ![]() There is not much to say about the charging, it works nicely for all tested batteries. ![]() Using a QC charger and a single battery did not change anything. ![]() Adding 0.5ohm resistance in series with the power supply to simulate a long cable or weak supply shows that the charger will reduce usb and charge current, but the charging works fine. ![]() With two batteries the charger increased the input QC voltage to 9V and maintained a high charge current. The charger do a couple of on/off cycles at the end of charging. ![]() M1: 40.0°C, M2: 38.1°C, M3: 53.8°C, HS1: 55.7°C ![]() HS1: 62.3°C There is some electronic inside the charger that gets a bit warm. ![]() The charger starts in about a second. ![]() The charger has a very low discharge current when not used, except if the batteries are completely empty, then it will drain them too much. This means it is a bad idea to leave batteries in the charger/power bank when not used. ![]() This charger works fine with a unstable input voltage. Power bank
![]() The output current display is not very well calibrated, but it gives an idea about the current consumption or the connected device. The output voltage display is also be too low with heavy loads on the output. ![]() The power bank can easily deliver the rated 2A with fresh batteries and it has overload protection around 2.7A. ![]() At 9V it can "only" deliver about 1.7A, not the rated 2A. ![]() At 12V the output is down to 1.2A, but as can be seen below the output is depend on battery charge state. ![]() USB-C can deliver about the same current as USB-A (QC) output on 5V. ![]() With a single 18650 battery the charger can easily deliver 0.5A for nearly 4 hours. It shunts down the output when the battery is down to 3V ![]() Using two batteries the time is nearly 8 hours. ![]() It can even deliver 2A from one battery, but only for about 45 minutes. The output voltage is stable, there is no drop when the battery is nearly empty. ![]() With two 18650 batteries it will run for nearly two hours with 2A output. ![]() QC9V is also stable until the battery is nearly empty. ![]() The box can also do QC12V, but here the converter has some trouble with a 10ohm (1.2A @ 12V) load, maybe that is the reason it is not listed in the specifications. It maintains the voltage above 11V, this means it will work with most (if not all) devices requiring QC12V and not using more than 1.2A. ![]() USB-C output at 2A works fine. ![]() There is 8mV rms noise and 76mVpp noise. ![]() There is 24mV rms noise and 248mVpp noise. ![]() There is 24mV rms noise and 262mVpp noise. ![]() There is 39mV rms noise and 307mVpp noise. ![]() There is 71mV rms noise and 556mVpp noise. Conclusion This is a very nice upgrade to the PB2 charger and power bank with QC and USB-C support. I like the size of the charger and the magnetic lid is easy to open. The charging looks good, but batteries must be able to handle 2A charge current. The voltage and current values are not that precise, but good enough to give an idea. The power bank can deliver a fair amount of power, but not the full QC2/QC3 18W, more like 15W, the coding is fairly universal, this means most device will be able to fast charge from it With support for both 18650 and 21700 batteries it is possible to configure it for light weight or high capacity very easily (50g and 3000mAh difference). I will rate is as a good power bank and charger. Notes The charger was supplied by XTAR for a review. Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
| Поблагодарили: 7 раз(а) |
ilyaapp (12.09.2019), MaksVasilev (12.09.2019), nsk1979 (12.09.2019), nurlanchm (13.09.2019), Romanko (12.09.2019), Алексей Михайлович (15.09.2019), Ходэн (15.09.2019)
Регистрация: 09.01.2011 Последняя активность: 17.03.2022 15:19
Сказал(а) спасибо: 274
Hi. Does it discharge batteries if leave inside power bank for a long time?
ZL H600Fc Mk IV, H32w, H53fw, H53fc/ Nitecore D10 XM-L2 NW/ 47 Quark Mini AA High CRI, QP2A, QPA/ Olight S10L2 NW, S15 + extention tube/FENIX CL20O. 6 X 18650, 2 X AW R123A(750 mAH), 20 х AA ENELOOP, 31 X cr123a, 50 * AA LR6 DURACELL PROCELL, 68 * AA ENERGIZER L91 Ultimate Lithium. В планах: HDS Executive 2*AA, ZL SC5w MKII, H53w |
The PB2S is slow enough when the batteries are charged, but it has a problem with fully discharged batteries, where it draws some current. This means if you run the PB2S empty it is best to remove the batteries and never let it lay around for weeks with discharged batteries. |
Romanko (15.09.2019)
Регистрация: 17.07.2014 Последняя активность: 09.11.2025 21:55
Сказал(а) спасибо: 1413
Romanko, в режиме простоя девайс кушает 70 мкА с каждой банки при неактивном дисплее.
Nitecore HC33 - кастом от Tamagotchi; Skilhunt: H03 NW, Н03R CW, DS16 (с заменой рефлектора на TIR); Sunwayman C23C (+ carclo 10196); Manker: MK34 (на Nichia 219C и Cree xp-g3), E03H; Relight RX60 NW и еще всякое разное... |
