Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 4643   Ответов в теме 1   Подписчиков на тему 2   Добавили в закладки 0
Старый 15.08.2019, 18:40 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/review of Charger Basen BO-4
Charger Basen BO-4
This is a fairly simple quad cell LiIon charger from Basen.
It arrived in a cardboard box with a lot of specification on it.
The box contained the charger, a usb cable and a instruction sheet.
The charger is usb powered with a micro usb input.
There is only one button and a couple of leds. The button will change selected current, default is 0.5A.
During power on all the leds will shortly turn on. During charge the blue leds are animated and only one green led is on.
The specifications are on the bottom of the charger, but rather hard to read.
The charger uses the classic slider construction and will handle batteries from 28mm to 70.4mm, this will give problem with the longest protected cells.
The charger can handle up to 70mm long batteries,
Measurements
  • Power consumption from usb when idle with no batteries is 13mA
  • Below 0.5V the charger will not detect a battery
  • Between 0.5 and 2.8V the charger will charge with low current
  • Above 2.8V the charger will use full current.
  • Will restart charging if voltage drops below 4.15V, but it may need some time to react.
  • Will restart charging if battery is inserted or power cycled.
Nice CC/CV charge curve with a 70mA termination current
Oops, the charger voltage is way to high on this slot.
The two last slots looks fine enough.
These two cells looks fine.
Even the old cell is charged fine.
No problem with 0.5A charging current.
This old and worn out cells drops significantly in voltage when charging terminates and the charger restart.
I have selected 2A charging current and with one cell in the charger the current is 2A.
This high current cells looks about the same during charging.
With two cells it will only be 1A
And with four cells 0.5A
Adding 0.5ohm resistance in series with the power supply to simulate a long cable or weak supply shows that the charger will reduce usb and charge current, but the charging works fine.
M1: 31.2°C, M2: 32.5°C, M3: 31.9°C, M4: 30.4°C, M5: 33.9°C, M6: 39.6°C, HS1: 44.5°C
HS1: 47.4°C
Being a fairly simple charger I could draw the current profile.
The charger is very fast to start, it needs less than a second.
It is possible to change current at any time.
Conclusion
I like the simple user interface, it is very easy to select current and see how much the batteries are charged. The CC/CV charge curve is good and termination is at a fairly low current
But slot #2 is problematic with the high charge voltage and for this reason I will only give the charge an acceptable rating.
Notes
Here is an explanation on how I did the above charge curves: How do I test a charger
РШ (15.08.2019)
Старый 22.12.2019, 05:06   2
Ramonajef
Последняя активность: 29.11.2021 02:40
По умолчанию Test/review of Charger Basen BO 4
I dont know. It does not tell its rated amps. I am currently using a 20 amp charger I got at TSC on clearance last fall to charge my forklift batteries when the sun has not been out in days. I run the HF generator for 6 hours on a gallon of gas to pump 120 amps into the battery bank as needed.
But I have always looked for a higher current charger for a faster top off
Ramonajef вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.10021 секунды с 15 запросами
