4020
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
The minimum charger
This is a combined charger and power bank in the minimum possible size. ![]() It arrived in a cardboard box. The box contained the charger, two usb cables and a instruction sheet. ![]() Power input is a micro usb socket on the side of the charger. ![]() There is a indicator led hidden behind a hole, in will flash a number of times depending on the battery voltage. At the minus side is a micro usb shaped hole, it is for storage, there is no connection inside it. Here the hole is used to place the charger in storage position. The minus side is flat and the plus side has a hole in the connection, this makes it possible to use button top cells. ![]() It is possible to plug the charger (Power bank) directly into a phone. ![]() But it is better to use the supplied extension cable, then there is less stress on the connectors. The charge current may be slightly lower due to cable resistance. The charger is designed for 18650 batteries. Measurements
Charging ![]() A nice CC/CV charge curve with about 200mA termination current. ![]() This is a good charge. ![]() For this worn battery the termination current is a bit high and the voltage drops significantly when charging is terminated. ![]() This battery is even older and the charger started by draining the battery a bit, because it went into power bank mode. When the current was turned on the charger very fast got the battery up in voltage and turned into constant current mode. The charging is fine enough. ![]() A 0.5ohm resistor in series with the usb power to simulate a long cable or weak supply will reduce the charger rate significantly. ![]() M1: 35.3°C, HS1: 54.2°C ![]() M1: 46.5°C, HS1: 57.2°C ![]() Being a fairly simple charger I could draw the current profile. ![]() The charger is need a few seconds to start. Power bank
![]() The charger can deliver about 1.9A with a full battery before output drops. ![]() When powered from usb it will pass the current straight through. ![]() Also with a battery in the charger it will pass the current straight through when powered from usb. ![]() The voltage starts dropping shortly before the battery is empty, the actual termination is not very good, it will reconnect every time the voltage increases. ![]() At 1A the voltage drops a bit earlier and the reconnect is much worse. ![]() At 0.5A the noise is 23mV rms and 101mVpp ![]() At 1A the noise is 36mV rms and 236mVpp ![]() Power consumption from LiIon battery when idle. Conclusion This is a small charger, that is limited to battery with 18mm diameter and can handle 1.8A charge current, i.e. 18650 batteries. In addition to the charger one or two loose cables are also needed. The charging works fine for good batteries. It also works fine as a power bank, but the coding is a bit optimistic compare to its abilities. The noise is low. The charger do not handle it well when the battery is running low (The battery will not be damaged). I will rate it as good for charger, and fairly good for power bank functionality. Notes Here is an explanation on how I did the above charge curves: How do I test a charger [url=https://lygte-info.dk/info/usbPowerSupplyTestHow%20UK.html]How do i test usb charger and power banks[/size]
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Регистрация: 03.03.2015 Последняя активность: 09.04.2020 17:15
Сказал(а) спасибо: 1070
Изврат какой-то с этим разъемом.
Регистрация: 26.07.2019 Последняя активность: 18.12.2019 14:59
1st, 2nd and 3rd time charge my lipo 3s just according his manual given....it is look great charger with that price offered....huhuhu..BUT now, every time want to charge the battery either lipo, NicAd, NiMah & Lead Acid Battery, the device sounding with "connection break".... check all cable supply input & output indicated good conductivity....
I dont know who is wrong either the device, battery, cable OR ME.... Tomorrow try to sent bank to RC Smart to get clarification.... |
