2614
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Keeppower 14500 1000mAh P1450C2 (Black) 2019
![]() Official specifications:
![]() This is high capacity protected 14500 LiIon batteries from Keeppower. ![]() ![]() ![]() ![]() ![]() ![]() The two cells match nicely and can easily deliver the rated 1.9A ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Conclusion This cell has good capacity and the length is fairly short for a protected cell. It can be used in most equipment that requires a 14500 LiIon cell (length may be a problem in a few cases), it a very good candidate for equipment that can run on both 1.5V and LiIon cells (This type of equipment usual needs protected LiIon cells). Notes and links The battery was supplied by Keeppower for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Graphical comparison to other LiIon batteries Table with all tested LiIon batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ [Исправлено: HKJ, 06.07.2019 в 10:20] |
Ветеринар Фонаревки
Регистрация: 19.03.2013 Последняя активность: 14.12.2025 21:47
Сказал(а) спасибо: 10202
Есть такие в пользовании , правда пришлось удалить защиту, не входит в фонарь по длине.There are those in use, though I had to remove the protection,
In Fino verytas |
Регистрация: 25.07.2019 Последняя активность: 05.08.2019 12:13
Nicely done. Would be interesting to see someone run the same test on Dragon. I recall the ND being fairly neutral at one point in time. I miss having a motion mount just for the ND.
