3160
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Charger Xtar VC4S
The is a automatic charger for LiIon and NiMH batteries, it also has a test function and a store function. The automatic part means battery chemistry and charge current is selected automatically, user cannot affect them. I got the charger in a white cardboard box with the specifications printed on it. Inside the box is a fabric bag with the charger in, this bag can be useful for traveling and to keep the manual, charger and cable together. The bag contained the charger, a USB cable, a warranty card and a instruction sheet in many languages. The charger is USB powered, it can work with either regular USB or a Quick Charge supply, I will recommend using a QC supply. There is a display, some red/green indicators (Not visible on the picture) and two buttons. One button to select display function (Show Capacity, current, IR) and the other to select mode (Charge, Grade, Store). ![]() During power on all the segments is shown. ![]() Charger ready with no batteries in it. ![]() Charging one NiMH and two LiIon batteries. ![]() The specifications on the back of the charger is nearly unreadable The charger uses the sliding connections style and will work with batteries from 30mm to 70.3 mm long, i.e. protected 20700 will not fit and a few very long protection 18650 may also have problems. ![]() ![]() ![]() The charger can handle 70 mm long batteries, including flat top cells. Measurements charger
Charging LiIon regular USB ![]() ![]() ![]() ![]() Charging a LiIon battery from regular USB will limit the current, here it is 0.5A for all four slots with a nice CC/CV charge curve and about 150mA termination current. Display shows for slot #1: 2829mAh 180mOhm Display shows for slot #2: 3196mAh 0mOhm Display shows for slot #3: 2910mAh 101mOhm Display shows for slot #4: 2960mAh 181mOhm ![]() With four batteries the current dropped to 250mA, this means a very long charge time. ![]() It did handle the test for unstable supply fairly well, except it stayed at low current in one case. Charging LiIon from Quick Charge ![]() With more voltage and power available the charge current is much higher, here 2A is used with a nice CC/CV charge curve and 150mA termination. Batteries are only rated for a standard charge current of 1.7A. Display shows: 3125mAh 55mOhm ![]() ![]() ![]() The charge current varies between the slots, this also means varying charge time. Display shows for slot 2: 2919mAh 95mOhm Display shows for slot 3: 2996mAh 59mOhm Display shows for slot 4: 2938mAh 142mOhm ![]() ![]() The PA cell is a bit old, but charger decided to use 2A on it. Display shows for SA: 2499mAh 80mOhm Display shows for PA: 2658mAh 57mOhm ![]() This cell is rather old and the charge current is 0.5A. Display shows: 1788mAh 286mOhm ![]() My old and worn down cell goes to CV phase very fast and the charger uses about minimum charge current, termination current is not changed. Display shows: 88mAh 301mOhm ![]() This smaller cell is charged at 0.5A, but due to the 150mA termination there is a significant voltage drop at the end. Display shows: 619mAh 168mOhm ![]() A larger high current cell is charged at 3A, this is fine. Display shows: 2939mAh 38mOhm ![]() With four cells the current is 1A on each cell. Display shows for slot 1: 3045mAh 68mOhm Display shows for slot 2: 3114mAh 31mOhm Display shows for slot 3: 3226mAh 32mOhm Display shows for slot 4: 3238mAh 31mOhm ![]() M1: 36.7°C, M2: 40.0°C, M3: 40.1°C, M4: 37.3°C, HS1: 43.8°C ![]() M1: 37.0°C, M2: 34.1°C, HS1: 49.3°C ![]() During startup it will pulse the charge current, this is probably to measure the internal resistance. Grading LiIon ![]() The grading function will charge the battery, then discharge it and finally charge it again, it reports the discharged capacity. The discharge current is fairly moderate at 300mA and it discharges to around 2.65V. Display shows: 2874mAh ![]() ![]() ![]() Display shows for slot 2: 2945mAh Display shows for slot 3: 2913mAh Display shows for slot 4: 2872mAh ![]() The charger can grade four at a time. Display shows for slot 1: 2997mAh Display shows for slot 2: 2953mAh Display shows for slot 3: 2994mAh Display shows for slot 4: 3038mAh ![]() M1: 38.0°C, M2: 40.4°C, M3: 40.9°C, M4: 38.0°C, HS1: 52.3°C There is not much heat when discharging the batteries. ![]() M1: 42.7°C, HS1: 62.0°C Storing LiIon The store function will place the batteries in a half charged state, this is the best way to maintain stored batteries (Keep them in a cool place will also extend their life). ![]() A empty battery is charged. ![]() A full battery is discharged. Charging NiMH from regular USB ![]() This cell is charged with 1.5A and charging is stopped with a -dv/dt termination and there is no trickle charge. Display shows: 2043mAh 55mOhm ![]() With this cell is charge current is only 0.75A Display shows: 2224mAh 75mOhm ![]() Charge current is 1.5A Display shows: 2132mAh 60mOhm ![]() Charge current is 0.75A. Display shows: 2090mAh 67mOhm ![]() Using -dv/dt termination it takes some time to detect a full battery, but this charger do it rather fast, only 8 minutes. It can also be seen that the first 3 minutes are done a low current, this may be to detect a over discharged LiIon battery. Display shows: 140mAh 29mOhm ![]() With four batteries the current is only about 350mA for each cell. Display shows for slot 1: 2296mAh 49mOhm Display shows for slot 2: 2186mAh 25mOhm Display shows for slot 3: 2401mAh 28mOhm Display shows for slot 4: 2373mAh 30mOhm ![]() And the charger uses below 1A from USB. Charging NiMH from Quick Charge ![]() ![]() ![]() ![]() More available power did not increase the charge speed for a single NiMH battery. Display shows for slot 1: 2073mAh 50mOhm Display shows for slot 2: 2338mAh 94mOhm Display shows for slot 3: 2109mAh 64mOhm Display shows for slot 4: 2067mAh 57mOhm ![]() ![]() ![]() The 3 high capacity batteries are charged nicely. Display shows for Fujitsu: 2598mAh 91mOhm Display shows for Leise: 2862mAh 66mOhm Display shows for Pro: 2697mAh 64mOhm ![]() The charge current for the AAA is on the high side at 1.5A Display shows: 785mAh 58mOhm ![]() Again the full battery is detected fairly fast. Display shows for slot 1: 154mAh 30mOhm ![]() With more input power the four battery can be charged faster. Display shows for slot 1: 1793mAh 69mOhm Display shows for slot 2: 2153mAh 33mOhm Display shows for slot 3: 2214mAh 28mOhm Display shows for slot 4: 2150mAh 26mOhm ![]() M1: 33.3°C, M2: 35.4°C, M3: 34.9°C, M4: 32.4°C, HS1: 38.1°C ![]() Again the charger pulses charge current at the start to measure internal resistance. during charge the current is stopped at regular intervals to check voltage. Grading NiMH ![]() Grading NiMH works slightly different than LiIon, again the battery is charged, discharge, but then only partially charged (This must be a software bug). Display shows: 1874mAh ![]() ![]() ![]() The 3 other slots are similar, the final charge varies a bit, but is between 500mAh and 1000mAh Display shows for slot 2: 1914mAh Display shows for slot 3: 1895mAh Display shows for slot 4: 1857mAh ![]() There is no problem doing four batteries at a time. Display shows for slot 1: 1898mAh Display shows for slot 2: 1875mAh Display shows for slot 3: 1854mAh Display shows for slot 4: 1872mAh ![]() M1: 33.8°C, M2: 34.4°C, M3: 34.2°C, M4: 32.9°C, HS1: 39.5°C Storing NiMH ![]() An empty NiMH will not really charge anything in the store function. ![]() A full cell will get slightly discharged, but not much. Internal resistance measurement ![]() The internal resistance function gives very consistent results for LiIon, but is a bit low (I measured the battery to 35-38mOhm). ![]() NiMH is also very consistent, but again the values are on the low side (I measured the battery to 61-69mOhm). Conclusion This charge do not have the usual discharge function, but instead has a "grade" that will charge, discharge and charge battery again to measure capacity and a store that will half charge a battery, it may either charge or discharge the battery to get there. The store function is for LiIon and do not really work for NiMH. Charging and grading works well for both LiIon and NiMH (The bug is a minor annoyance). But the automatic current for small batteries can sometimes be a problem, because the current is based on the measured internal resistance in the battery and some small batteries have a fairly low resistance without being designed for high charge current! Xtar shows some good ideas in this charger, but the automatic current selection is not always perfect, for people that has many LiIon batteries the store function will help prolong the life of unused cells. Due to the automatic current selection that sometimes will use higher current that the batteries are rated for I will only rate the charger fairly good. Notes The charger was supplied by XTAR for a review. Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
| Поблагодарили: 3 раз(а) |
