Просмотров в теме 5576   Ответов в теме 24   Подписчиков на тему 4   Добавили в закладки 0
Старый 08.06.2019, 18:13 Автор темы   1
Последняя активность: 13.11.2019 16:22
Поблагодарили: 17 раз(а) в 17 сообщениях
По умолчанию Request: visualization change for high capacity batteries
Посмотреть сообщение Сообщение от HKJ :
These are impressive high current battery.
In which (M1B), the characteristics have deteriorated compared to M1A, because on the same loads the voltage of the M1B sags much more. This means that due to the cut-off threshold in some devices, replacing the 'M1A 2300' with the 'M1B 2500' will not be possible, and a slight increase in capacity on average loads is completely useless here. Not very successful update from A123.
The disadvantage of these batteries is lower voltage...
This fact indicates that on the main page with the discharge graph it is time to change the graduation of the vertical line from 2.8v voltage to a vertical line with a lower limit of 2.0v. Otherwise, universal charts (with a limitation of up to 2.8v) look quite strange on it and you can’t see the details of the behavior of these A123
Название: м1А 2300 на токе 20А и всех.jpg
ID:	221362 Нажмите на изображение для увеличения
Название: м1В 2500 на токе 20А и всех.jpg
ID:	221363 Нажмите на изображение для увеличения
Название: ни тот ни другой не видно.jpg
elecom вне форума   Ответить с цитированием Вверх
Старый 08.06.2019, 18:28   2
HKJ
Модератор своих разделов
Аватар для HKJ
По умолчанию Re: Test/review of A123 ANR26650M1B 2500mAh (Green)
Посмотреть сообщение Сообщение от elecom :
That would degrade the normal LiIon comparison and I believe that it more important that a few LiFePO4 cells once in a while.
Старый 08.06.2019, 18:42 Автор темы   3
elecom
Okay, master HKJ, especially since I am not a fan of these low-voltage cells
(although, you are the world leader in tests, which are watched and respected by a large number of interested people, many of whom evaluate A123 and other low-voltage LiFePO4)
Старый 08.06.2019, 18:44   4
HKJ
Аватар для HKJ
It is still possible to check the actual review, where the scale is adjusted for LiFePO4.
Старый 09.06.2019, 12:06 Автор темы   5
elecom
Today, the Chinese make LiFePO4 with a capacity of 6500mAh and the new Li-Ion cylinders 32700 reach more than 8000mAh (8.5Ah). I have already shown you a link to such models, but I suggest you look at them again. In another forum, one participant purchased a McNair 7500mAh model, which, under a load of 33 amps, showed an unusually large capacity (7714mAh). You, the master of HKJ, and other forum users can see a photo of this test, taken with the help of ZKE-Tech electronic load right here
ID:	221371 Нажмите на изображение для увеличения
ID:	221372 Нажмите на изображение для увеличения
Название: 32650 - 7,7Ah.jpg
ID:	221373 Нажмите на изображение для увеличения
Название: 32650 (70mm)4.jpg
ID:	221374 Нажмите на изображение для увеличения
Название: 32700 7,5Ач на 33А = 7,7Ач.jpeg
Старый 09.06.2019, 12:13   6
Надо ему ещё срочно дать ссылку на электронную нагрузку, ящитаю.
Rimlyanin (09.06.2019)
Старый 09.06.2019, 12:17 Автор темы   7
elecom
Now about the main thing. As you already understood, you will have to upgrade the ability of your schedule to expand its ability to measure higher capacities (up to 8.5 .... 10Ah). It will also increase the convenience of using the graph to work with the mouse with the right hand, without making unnecessary movements with the mouse on the computer or on the laptop. Approximately such an arrangement, which is shown here in the figure, would be very convenient for widescreen monitors (16: 9) and all other modern ones
Старый 09.06.2019, 15:39 Автор темы   8
elecom
What do you think about the possibility of comparing four batteries at the same time?
[Исправлено: elecom, 09.06.2019 в 15:50]
Старый 09.06.2019, 16:16   9
Ну так возьми и сделай. Там весь код доступен, там есть и картинка фона,
и картинки элементов по разным токам, с прозрачностью
Которые накладываются на фон в зависимости от выбора элемента и тока.
Старый 09.06.2019, 18:14   10
HKJ
Аватар для HKJ
The charts are build by stacking pictures, there is the background and one for each current and each curve.
All the curves are regenerated each time I add a new battery, this means I just have to modify the background and I could regenerate everything with a new scale, but it is not really needed. All larger batteries are duplicated in the 26650 comparator that has a longer scale, I will only change the scale if I get a couple of batteries where I need a longer scale.
I do not really want to add more batteries due to the time it takes to regenerate the curves and for 4 curves it would double.
Dnv (10.06.2019), Rimlyanin (09.06.2019)
Старый 09.06.2019, 18:43 Автор темы   11
elecom
Ты же знаешь, что это не для средних умофф, поэтому мастер HKJ сам должен принять соответствующие меры для данного прогресса.
Посмотри, что мы видим, когда приходим на тестовую страницу. Нам приходится делать ненужные движения мышкой, чтобы пропустить отвлекающую информацию, имеющую второстепенное значение, а потом посмотри на более практичный вариант, когда всё будет расположено более удобно. Также посмотри на то, что мы видим сегодня, когда уже начали появляться нормальные элементы, у которых ёмкость превышает ограничение нынешнего графика 6000mAh
Название: сейчас выглядит так.jpg
ID:	221382 Нажмите на изображение для увеличения
Название: них не видно результаты-.jpg
ID:	221383 Нажмите на изображение для увеличения
Старый 09.06.2019, 19:26   12
Да? Ну извини. Как по мне, там все не настолько сложно.
Сложность будет лишь парсить периодически чтобы отслеживать новые добавления.
Ты не учитываешь соотношение дестктопного и мобильного трафика.
Тебе уже выше ответили
Старый 09.06.2019, 20:00 Автор темы   13
elecom
Если сможешь, то и организуй. Тогда нужно будет просить у господина HKJ разрешение на дублирование его материалов в изменённом виде, но уже на твоей странице. Естественно, что там должна быть ссылка на оригинал, а люди потом сами смогут выбрать, где им будет удобнее ориентироваться при выборе наиболее подходящего им аккумулятора.
If you can, then organize. Then it will be necessary to ask Mr. HKJ for permission to duplicate his materials in a modified form, but on your page. Naturally, there should be a link to the original, and then people themselves will be able to choose where it will be more convenient for them to navigate when choosing the most suitable battery.
Для человека, в основном живущего темой об аккумуляторах, разве это будет сложно? Ведь, должен же ты хоть что-то оставить о себе достойного на этой земле, кроме своих грехов?
Во-первых, даже представить трудно, что по такой серьёзной и кропотливой теме, как выбор нужного аккумулятора, кто-то будет ограничиваться своим мелким телефончиком.
Во-вторых, даже если и есть такие люди, то любой современный телефон или планшет при повороте его в горизонтальное положение автоматически меняет картинку со своей геометрией на соответствующую. И тогда тем более необходимо поднять график как можно выше, убрав при этом сверху страницы всю второстепенную информацию, которая только мешает.
Firstly, it is even difficult to imagine that on such a serious and painstaking topic as choosing the right battery, someone will be limited to his small telephone.
Secondly, even if there are such people, then any modern phone or tablet when turning it to the horizontal position automatically changes the picture with its geometry to the corresponding one. And then it is all the more necessary to raise the schedule as high as possible while removing all the background information from the top of the page, which only hinders.
Ну, вспомни или хотя бы подумай. Когда ты выбираешь себе аккумулятор, то возникает необходимость сравнивать его с большим количеством других разных элементов. У одного элемента ёмкость намного меньше, а у другого намного больше, но все они должны умещаться в одном и том же объёме графика. Это необходимое условие для оперативного сравнения. Также для этого желательно добавить ещё выбор двух дополнительных элементов, чтобы их стало четыре. Выбрав наиболее интересный нагрузочный ток, будет очень оперативно, наглядно и детально видно, что из себя представляет тот или иной аккумулятор, если его сравнить с другими аналогами.
Well, remember, or at least think. When you choose a battery, it becomes necessary to compare it with a large number of other different elements. One element has a much smaller capacity, while the other has a lot more, but they all have to fit in the same volume of the graph. This is a prerequisite for rapid comparison. Also for this purpose it is desirable to add another choice of two additional elements so that there are four of them. Choosing the most interesting load current will be very quickly, clearly and in detail shows what a particular battery is, if you compare it with other analogues.
[Исправлено: elecom, 09.06.2019 в 20:01]
Старый 09.06.2019, 21:24   14
Во1х, не указывай, во2х, мне это зачем?
А я не живу только аккумуляторами. Не стоит свой ограниченный субъективный опыт распространять на всех окружающих.
Конечно должен, и уже оставил, но не думаю что тут подходящее место для обсуждения этого.
А что не так? Почему телефон или плашет не подходят для выбора нужного аккумулятора ?
Это Вы считаете что она мешает, это она Вам мешает, не стоит свой ограниченный субъективный опыт распространять на всех окружающих.
И да, Вам Выше уже ответили на это :
Если Выкинуть всех перепаковщиков да всякие левые элементы, то выбора остается не так и много, поэтому сравнение из двух вариантов мне видится наиболее подходящим. Просто идем по списку и сравниваем, худший меняем на следующий по списку.
Старый 09.06.2019, 22:14 Автор темы   15
elecom
Теперь уже точно видно, что в аккумуляторах ты почти не разбираешься, если тебе ни о чём не говорят линии, отображающие их поведение во время самого процесса разряда. Как максимум тебя интересует только финал, т.е. окончание разряда (какую в итоге ёмкость отдал тот или иной элемент). Естественно, что из-за отсутствия какого-либо внутреннего стимула (да и откуда ему взяться) тебе и не интересно взять такую планку, как усовершенствованный график разряда с гораздо более удобной загрузочной страницей (пусть это будет график будущего времени, нового поколения). Или, на самом деле, реально сделать не в силах то, о чём здесь выше хвалился.
Ладно, проехали, тем более, что мы находимся в гостях у мастера HKJ, а не у тебя в огороде.
Старый 09.06.2019, 23:23   16
Мдя, как я уже писал выше
И да, снова выдаешь свои влажные фантазии за реальность?
Мне то они как раз говорят, в отличии от тебя. Более того, ты так долго упирался в емкость и амперы левых элементов, что упустил три других, не менее, а то и более важных, параметра.
Один уже вскользь упоминался тобой, но два других - нет.
А, ну-ну, продолжаешь свои влажные фантазии переносить проецировать на меня? Либо подтверди свои слова цитатой, либо я буду называть тебя балабол. 48часов для поиска подходящей цитаты среди мои сообщений достаточно?
Ого, вот это проекция... Ну-ну... Расскажи мне про мои стимулы?
Ну, тут ты уже совсем заврался. Если нужен "усовершенствованный график разряда", то это вон проси у HKJ, т.к. данные необходимые для того, чтобы построить новые графики, только у него, так что мимо в этот раз.
Тем более что ты упорно не замечаешь что
Ну а если " более удобной загрузочной страницей", то мне не сложно, но совершенно не интересно.
У меня сейчас есть другие интересы и стимулы, на которые я и предпочту тратить свое личное время
Да все реально. Фон я тебе уже выше показывал.
Вот его адрес: https://lygte-info.dk/pic/B...
Ну и вот на примере Efest IMR18650 1600mAh V1 (Red) 2014
вот его картинки разряда, с прозрачностью А вот они же, но для выбора из правого списка: Видишь, там все банально, в папке https://lygte-info.dk/pic/B... лежат файлы в которых название это
%name%-Capacity-%current%%L/R%.png
У них есть прозрачность, и при накладывании на фон, получаем график.
Т.е. по выпадающему списку выбирается элемент,
Код HTML:
<select class="s1" id="selectL" size="1" onChange="showHide('L');">
с ним также выбирается список файлов по токам, и дальше по выбору чекбокса того или иного тока
Код HTML:
<input type="checkbox" id="option30" value="30.0" onClick="update()">30A</input>&nbsp;&nbsp;&nbsp;&nbsp;
включается или выключатся отображение файла.
Код:
function showHide(side)
Да-да, просто накладывают на фоновую картинку графики разряда того или иного элемента тем или иным током.
Вот так вот, банально.
И да, именно поэтому там внизу написана вот такая сноска
To make a copy (when using Windows) use Alt-PrtScr, then paste the screen dump into Paint. Mark the picture and crop it. The best format to save it in is PNG, this secures full quality and minimal picture size. Note: It is not possible to save the picture directly.
Так что, похоже я разбираюсь и в этом вопросе лучше тебя ?
Старый 10.06.2019, 00:04 Автор темы   17
elecom
я буду называть тебя балабол[/B].
А кто-то только недавно обещал тщательно вылизанное вычищенное ведро с яблочками https://forum.fonarevka.ru/...
Вот его...
Плохо, когда тугоухость прогрессирует в нежном возрасте, но так уж видимо повелось, что приходится повторять одно и тоже. Пойми, такая у меня, по всей видимости, судьба, но чаще я думаю не только о себе, но и о многих других людях, просто умея ставить себя на их место. И людям этим, которые знают о компьютерном деле столько же, сколько и ты разбираешься в балете, а предложенное тобой умеют делать не лучше, чем ты умеешь танцевать бальные танцы, хотят не показанных выше 100500 ссылок, а всего-лишь одну единственную, которая приводит на уже готовую страницу загрузки Battery test, comparator:
на рис.1 - выглядит сейчас, а на рис.2 - модернизированная.
Всего дел-то для профессионала
ID:	221407 Нажмите на изображение для увеличения
Старый 10.06.2019, 14:52   18
Перечитай, никто тебе ничего не обещал.
Но 48 часов быстро пролетят, и если ты не предоставишь доказательств, то так и будет.
И снова проецируешь?
Ну, твоя судьба тут малок кому интересна, как и твои влажные фантазии на тему как тебе хотелось бы видеть сравнение аккумов.
Вы хотите обсудить отличия Pas de deux от Pas de trois и Pas de quatre ?
Пытаетесь взять меня на слабо, как школьника?
Ещё раз:
P.S.
Когда человек ленив и считает, что ему могут дать на блюдечке решение, которое он должен принять сам все узнав, разобравшись и взвесив - это так печально. Причем в 99% случаев уверен, что ситуация одна из:
а) или человек уже принял решение и ждет подтверждения
или
б) тупо перекладывает ответственность на незнакомых людей и не развивается
в) просто хочет поговорить "попи*деть" на тему "что лучше, красный или длинный"
г) реально ищет помощи так как у него нет рук, ног, интернета чтобы загуглить видео, обзоры, цены и почитать
Выбери свой вариант.
Старый 10.06.2019, 19:08 Автор темы   19
elecom
Опять ты? От тебя не спрячешься, везде ты со своим абсурдом втыкаешься, даже в заграничной теме
Старый 10.06.2019, 21:35   20
Я же уже писал что
Это форум. Не Вам решать кому можно писать в этой теме, а кому - нет.
Время генерации страницы 0.21209 секунды с 16 запросами
